NI RFmx SpecAn/Power Amplifier/Phase Noise/Niose Figure 2024 Q2 Win11 64bitENG RFmx频谱分析仪/功率放大器/相位噪声/噪声系数24.3.0
RFmx SpecAn
RFmx SpecAn为时域和频谱分析提供互动和自动测量。
发布日期:2024/4/10
包含的版本:2024 Q2完整版/运行版,版本号24.3.0
64位完整版校验和:
文件大小: 1511208960 字节 (1.41 GB)
修改日期: 2024-04-11 09:43
MD5: a7955d52e0bcb056ca9b34bbce095cfa
SHA1: 401a47a549d235b9e2d8c274a9c05f1e167c90e1
SHA256: 24713db377d3dde8d5687c44837e434a4da0cba7e07e64b6c1a63bebf0911990
CRC32: ad20794d
请注册登录视觉论坛账号,购买附件查看下载地址
RFmx SpecAn2024Q2Full.txt
(580 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 936642560 字节 (893.25 MB)
MD5: 53d59413f1d06be7264f6798cde306b5
SHA1: 13f19416933eb48856cdc2b3a413e2bfbc410985
SHA256: f289bb34df5ac4e2532be5ec8aba2bef8d4cb47a84f4a5e306cbbcbc71c326bf
CRC32: 13f9f42f
RFmx SpecAn2024Q2RTE.txt
(604 Bytes, 下载次数: 0, 售价: 5 圆)
2024Q2版本未更新自述文件,参考2023Q3版本
RFmx SpecAn 2023 Q3 ReadmeJuly 2023 This file contains important information about the RFmx SpecAn, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx SpecAn Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx SpecAn Manuals: New features, behavior changes, and other documentation
New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 New FeaturesRFmx SpecAn 2023 Q3 includes the following new features: - Iterative Learning Control for DPD measurement
- Support for Noise Compensation in ACP measurement for Sequential FFT mode
RFmx SpecAn 2023 Q2 includes the following new features: - Support for Detectors in CHP and ACP measurements
- Speed improvements for Composite and Spectral measurements
RFmx SpecAn 2023 Q1 includes the following new feature: - Support for LabVIEW 2023 Q1 (64-bit)
Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
- Type your hardware model number in the dropdown list on the web page to filter the list of available devices.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx SpecAn has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx SpecAn 2023 Q3 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note RFmx SpecAn no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx SpecAn 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx SpecAn 2023 Q3 to an unsupported OS. Additionally, after installing RFmx SpecAn 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx SpecAn supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx SpecAn. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx SpecAn | LabVIEW | 2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1, 2023 Q3 | LabWindows™/CVI™ | 2019 or later | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
- NI-RFSG 14.0.1 or later
- NI-RFSG Playback Library 19.1 or later (for DPD examples)
Microsoft Visual Studio SupportIf you are using the RFmx SpecAn .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx SpecAn .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0. Installation InstructionsDownload the RFmx SpecAn installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
- RFmx SpecAn installs the following licensed products
- RFmx Noise Figure: This will enable the Noise Figure measurement in RFmx SpecAn.
- RFmx Phase Noise: This will enable the Phase Noise measurement in RFmx SpecAn.
- RFmx Power Amplifier: This will enable the AMPM and DPD measurements and the Crest Factor Reduction (CFR) support in RFmx SpecAn.
Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate the product. Refer to the NI Software Activation for more information on product activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File LocationsItem | Installed Location | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | DLLs | | Header files | \Shared\ExternalCompilerSupport\C\include | Import Library files | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| .NET Class Libraries | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.SpecAnMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments » InstrumentStudio to launch the InstrumentStudio. Accessing the APIRFmx SpecAn palette VIs are available from the Functions » Measurement I/O » NI-RFmx » SpecAn palette. Accessing the DocumentationDocumentation for RFmx SpecAn is located at Start » National Instruments » RFmx SpecAn Documentation. Finding ExamplesSelect Help » Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output » Modular Instruments » NI-RFmx » SpecAn. You can also select the Search tab to search all installed examples by keyword. You can access all the installed RFmx SpecAn examples at Start » National Instruments » RFmx SpecAn » RFmx SpecAn Examples. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following is the behavior change in RFmx SpecAn 2023 Q3 from RFmx SpecAn 2023 Q2 - Added support for saving and loading RFmx configurations into/from rfmxconfig files. Load from TDMS is supported but save into TDMS files is discontinued.
The following is the behavior change in RFmx SpecAn 2022 Q4 from RFmx SpecAn 2022 Q3: - RFmx SpecAn drops support for 32-bit user mode.
The following is the behavior change in RFmx SpecAn 2022 Q3 from RFmx SpecAn 21.8.2: - The RFmx Soft Front Panel has been replaced by InstrumentStudio.
The following are the behavior changes in RFmx SpecAn 20.7 from RFmx SpecAn 20.6. - Obsoleted the RFmxInstr Configure Automatic SG SA Shared LO API and the RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. |
