查看: 472|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2024 Q1 Win11 64bitENG RFmx蜂窝测试TD-SCDMA24.0.0
  • 签到天数: 3538 天
    连续签到: 8 天
     楼主| 发表于 2024-5-31 11:49:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:2024/1/22
    包含的版本:2024 Q1完整版/运行版,版本号24.0.0
    64位完整版校验和:
    文件大小: 1399588864 字节 (1.30 GB)
    修改日期: 2023-10-12 09:45
    MD5: f80bee79d0344f562d21fa271060e500
    SHA1: 4e2baf0352f4b872828b959fcc1d0025ea9ea7ce
    SHA256: a3e0791ba947c59e78c8472742a99981fd3901184aad44590e07be9a43f24498
    CRC32: d1ca05ed
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA2024Q1Full.txt (550 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 682426368 字节 (650.81 MB)
    MD5: 0e1af264caa707d7a9d20a194177d1ce
    SHA1: f4ff6744c3896f07015053509b6861db6c43964a
    SHA256: a2b544261da4c8bc94234bd338f48fb80d69249496ed19f3e0b555745e124adb
    CRC32: 0c3977e3
    请注册登录视觉机器论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA2024Q1RTE.txt (574 Bytes, 下载次数: 0, 售价: 5 元)
    2024Q1未更新自述文件,参考2023Q3版本
    RFmx TD-SCDMA 2023 Q3 Readme
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    RFmx TD-SCDMA 2023 Q2 includes the following new feature:
    RFmx TD-SCDMA 2023 Q1 includes the following new feature:
    RFmx TD-SCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx TD-SCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx TD-SCDMA (64-bit only)
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 2023 Q3 from RFmx TD-SCDMA 2023 Q2
    The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
    • RFmx TD-SCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
    GMT+8, 2025-5-14 07:32
