查看: 384|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2024 Q2 Win11 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试24.3.0
    10 小时前
  • 签到天数: 3517 天
    连续签到: 5 天
     楼主| 发表于 2024-6-3 10:38:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    RFmx W-CDMA/HSPA+为W-CDMA、HSPA和HSPA+蜂窝测试应用提供信号生成和分析功能。
    RFmx W-CDMA/HSPA+是一款测量专用软件,旨在扩展NI RF仪器生成和分析W-CDMA、HSPA和HSPA+蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对W-CDMA、HSUPA和HSUPA+上行链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2024/4/10
    包含的版本:2024 Q2完整版/运行版,版本号24.3.0
    64位完整版校验和:
    文件大小: 1400363008 字节 (1.30 GB)
    修改日期: 2024-04-11 09:45
    MD5: e2f78c5808e5e17eed97a5af8ee22295
    SHA1: 8a1cb7de1fe56ec0fe0fe7911daea5ff76f16f57
    SHA256: 2bab92ca211862c978b2bca7946372769a400de511f185b02ab55f6bed50e421
    CRC32: 03a33e77
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx W-CDMA-HSPA 2024Q2Full.txt (548 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 929150976 字节 (886.11 MB)
    修改日期: 2024-06-03 10:26
    MD5: 40a4e196311860745d8a757505bfa6df
    SHA1: a224b87c5d46083a5d9724ebd644dbe16a504841
    SHA256: 3d78e0e92b47262c1bfbe4a8b8a7c738c6f9e0a102d02fa92548a328029f94c3
    CRC32: 08b4fdd9
    RFmx W-CDMA-HSPA 2024Q2RTE.txt (572 Bytes, 下载次数: 0, 售价: 5 元)
    2024Q2版未更新自述文件,参考2023Q3版本。
    RFmx WCDMA 2023 Q3 Readme
    This file contains important information about the RFmx WCDMA, including system requirements, and installation instructions.
    • RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx WCDMA Manuals: New features, behavior changes, and other documentation
    RFmx WCDMA 2023 Q2 includes the following new feature:
    RFmx WCDMA 2023 Q1 includes the following new feature:
    RFmx WCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx WCDMA has the following requirements:
    RFmx WCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WCDMA (64-bit only)
    If you are using the RFmx WCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.WcdmaMX.Fx40.dll
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA Documentation.
    You can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA Examples.
    The following is the behavior change in RFmx WCDMA 2023 Q3 from RFmx WCDMA 2023 Q2
    The following is the behavior change in RFmx WCDMA 2022 Q4 from RFmx WCDMA 2022 Q3
    • RFmx WCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx WCDMA 2022 Q3 from RFmx WCDMA 21.8.2
    The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6.
    GMT+8, 2025-4-18 18:33
