查看: 478|回复: 0
[NI软件产品] NI RFmx WLAN 2024 Q2 Win11 64bitENG RFmx无线局域网络24.3.0
  • 签到天数: 3538 天
    连续签到: 8 天
     楼主| 发表于 2024-6-3 10:44:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:2024/4/10
    包含的版本:2024 Q2完整版,版本号24.3.0
    64位完整版校验和:
    文件大小: 1510133760 字节 (1.41 GB)
    修改日期: 2024-04-11 09:45
    MD5: 215936950de6f577e06684c57c603b63
    SHA1: 06a257b62a02c8adbaa9e4bae041d27329144e0b
    SHA256: 13231e07db4b36e207af2c906be062e2d319b7b921439e570f4ca28453bd10b1
    CRC32: 299bf7a6
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFmx WLAN2024Q2Full.txt (537 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 953722880 字节 (909.54 MB)
    MD5: a839fdd6d3cd08b327742d3b13f15a5f
    SHA1: 0838592ace69e1af650a29877f3b4b8a146e23c1
    SHA256: 0e1fe05a80eca719e85ee82225e98da878a8c5b80de4881d7433d46ad4b04a10
    CRC32: b08472bf
    RFmx WLAN2024Q2RTE.txt (561 Bytes, 下载次数: 0, 售价: 5 元)
    2024Q2未更新自述文件,参考2023Q3版
    RFmx WLAN 2023 Q3 Readme
    RFmx WLAN 2023 Q3 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D3.2
    • Support for auto detection of signal in Analysis-Only Mode
    RFmx WLAN 2023 Q2 includes the following new features:
    • Support for Combined Signal Demodulation across all MIMO standards
    • Support for 802.11be Standard IEEE P802.11be/D3.0
    RFmx WLAN 2023 Q1 includes the following new features:
    • Support for Fields Gated Power for 802.11be standard
    • Support for 802.11be Standard IEEE P802.11be/D2.3
    RFmx WLAN 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WLAN 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WLAN (64-bit only)
    Item
    Installed Location
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN Documentation.
    You can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN Examples.
    The following is the behavior change in RFmx WLAN 2023 Q3 from RFmx WLAN 2023 Q2
    The following are the behavior changes in RFmx WLAN 2022 Q3 from RFmx WLAN 21.8.2:
    • EVM Noise compensation includes support to work for Linear, Wiener and Triangular Smoothing channel estimation interpolation types
    The following are the behavior changes in RFmx WLAN 21.8 from RFmx WLAN 21.5.
    • RFmx WLAN drops support for 32-bit user mode.
    • When you set the OFDMModAcc Noise Comp Enabled property to True:
      • Noise compensation applied limit check is now skipped if OFDMModAcc EVM Ref Data Symbols Mode property is set to Reference Waveform
      • EVM per Subcarrier and the EVM per Symbol traces now follow the noise compensation applied result
    GMT+8, 2025-5-14 05:49
