查看: 1100|回复: 0
[LabVIEW] NI LabVIEW 2021 SP1 f6 x64Win10 64bitEng LV2021SP1Patch6英文版离线安装包下载-64位21.1.6
     楼主| 发表于 2024-7-13 10:25:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2021 SP1 f6
    发布日期:24-5-8
    包含的版本:2021 SP1 f6专业版,版本号21.1.6
    语言:英文
    程序位数:64位
    文件大小: 2511812608 字节 (2.34 GB)
    修改日期: 2024-07-12 15:53
    MD5: 1cd652dad8baaf243e1c10d4ec652b65
    SHA1: b562024a47aa7c53c2c1f4cbd3a3081e5a0a48d4
    SHA256: b49c9c2b162f5c760256044017fd84df94e40a63516a4dfee5f50388d476bc75
    CRC32: 863de60a
    注册登录视觉论坛会员,购买附件查看
    LV2021SP1Patch6x64En.txt (545 Bytes, 下载次数: 10, 售价: 10 圆)
    LabVIEW 2021 SP1 Readme for Windows
    January 2022
    LabVIEW 2021 SP1 (64-bit)
    LabVIEW 2021 SP1 has the following requirements:
    Operating SystemWindows 10
    Windows Server 2019
    Windows Server 2016
    Windows 10
    Windows Server 2019
    Windows Server 2016
    Note  You cannot access LabVIEW using a Guest account on Windows.
    • Use the serial number that is included with your software to activate LabVIEW. For more information on LabVIEW activation, refer to Activating a Product.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2021 SP1.
    LabVIEW 2021 SP1 adds two Place VI Contents VIs to the Functions palette. OpenSSH Exec and PuTTY SSH Exec execute a system command on an SSH server specified by user@host with OpenSSH or PuTTY (plink) respectively.
    Use the LabVIEW Platform media to install modules and toolkits supported by LabVIEW 2021 SP1 (32-bit) and LabVIEW 2021 SP1 (64-bit). When run on Windows (64-bit), LabVIEW (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW (64-bit) is available in English only.
    Refer to the NI website for information about drivers compatible with LabVIEW 2021 SP1 (64-bit). For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW (64-bit).
    LabVIEW 2021 SP1 (64-bit) supports a limited number of modules and toolkits. The following table compares the modules and toolkits supported by LabVIEW (32-bit) and LabVIEW (64-bit).
    ✓1
    Database Connectivity Toolkit
    Digital Filter Design Toolkit
    FPGA Module
    MathScript Module
    ✓2
    Real-Time Module
    Sound and Vibration Toolkit
    Unit Test Framework Toolkit
    VI Analyzer Toolkit
    Vision Development Module
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2021 SP1.
    LabVIEW no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    374715T-01
    GMT+8, 2025-12-8 08:02
