查看: 1094|回复: 0
[LV工具模块] LabVIEW 2023 Q1 Unit Test Framework Toolkit Win11 32bitEng LV2023Q1单元测试框架工具包UTF23.1.0
    前天 16:03
     楼主| 发表于 2024-9-18 15:04:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    UTF2016版开始,支持64位的LabVIEW,即有UTF2016-64bit的版本。最后几年的LV专业版中都已经包含了UTF软件,可在安装LV时选择安装,无需要另外下载安装单独的UTF。
    LabVIEW单元测试框架工具包可自动执行LabVIEW VI单元测试,帮助您轻松进行功能验证。
    LabVIEW单元测试框架工具包是一个LabVIEW附加软件,可帮助您自动完成功能验证,并验证应用程序是否正常运行。您可以生成单元测试或者导入使用Microsoft Excel等编辑器创建的文本文档里的测试参数。测试可包含多种测试用例,这些用例决定了各种数据类型(包括数组和簇) 的输入值和预期输出。您将可识别错误输出的来源、跟踪代码覆盖率,并生成HTML、ATML/XML或ASCII格式的验证文档。
    LabVIEW 2023 Q3单元测试架构工具包
    发布日期:2023/1/7
    包含的版本:2023 Q1完整版,版本号23.1.0
    应用程序位数:32位
    文件大小: 273768448 字节 (261.09 MB)
    修改日期: 2024-09-15 16:08
    MD5: 9d1e11df1b8cf5247ee3cbe7845ada5d
    SHA1: 9c891fc01f0e7e146cb67b43820ccff6722f5d9d
    SHA256: 4bb9450dc44945f64b33423f653a73b9162ca7f02e90265328eae15bfdcfeb4b
    CRC32: e22b17dc
    UTF2023Q1x86.txt (726 Bytes, 下载次数: 0, 售价: 10 圆)
    2023Q1版自述文件未更新,参考2021版
    NI LabVIEW 2021 Unit Test Framework Toolkit Readme
    July 2021
    This file contains installation instructions and compatibility information for NI LabVIEW 2021 Unit Test Framework Toolkit.
    • Manuals: New features, behavior changes, and other documentation
    The Unit Test Framework Toolkit provides interactive tools to create, configure, manage, and execute tests that check VIs for functional correctness.
    In addition to the system requirements for the LabVIEW Development System, LabVIEW 2021 Unit Test Framework Toolkit has the following requirements:
    • LabVIEW 2021 Base, Full, or Professional Development System
    • At least 64 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2021.
    LabVIEW 2021 Unit Test Framework Toolkit supports the following operating systems:
    Download the LabVIEW Unit Test Framework Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate LabVIEW Unit Test Framework Toolkit. For more information on LabVIEW Unit Test Framework Toolkit activation, refer to NI Software Activation.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Unit Test Framework Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Unit Test Framework folder to access the example. You also can find the examples for the Unit Test Framework Toolkit in the labview\examples\Unit Test Framework directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW Unit Test Framework Toolkit no longer supports Windows 7/8.1, Windows Server 2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2008–2021 National Instruments Corporation. All rights reserved.
    375338H-01
    GMT+8, 2026-2-25 01:02
