查看: 1142|回复: 0
[LV工具模块] LabVIEW 2023 Q1 Desktop Execution Trace Toolkit Win11 32/64bitENG LabVIEW2023Q1桌面执行跟踪工具包DETT23.1.0
    前天 16:03
     楼主| 发表于 2024-9-18 15:48:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    DETT2015版本之前的版本,仅适用32位的LabVIEW,DETT2016版本之后的版本,则32位和64位同时适配,但是仅一个安装文件,不另外区分安装版本。
    LabVIEW桌面执行跟踪工具包可以帮助您执行高级调试所需的动态代码分析。
    LabVIEW桌面执行跟踪工具包可以在运行时跟踪LabVIEW VI在Windows系统中的执行情况,以检测和定位代码中可能会影响性能或导致意外行为的问题。该工具包提供了VI事件、队列操作、参考泄漏、内存分配、未处理的错误和子VI执行的时间顺序图。借助这个工具包,即可根据LabVIEW程序的框图,通过编程方式生成用户定义的事件。
    LabVIEW 2023 Q1桌面执行跟踪工具包DETT23.1.0
    发布日期:2023/1/7
    包含的版本:2023 Q1 版本号23.1.0
    文件大小: 402561024 字节 (383.91 MB)
    修改日期: 2024-09-15 16:26
    MD5: e81c9a6cf7390be877857a6ca89dc2f5
    SHA1: 07649945b98fc981921b71c3e2adca2a7dae614b
    SHA256: 50d635518e4163b1de0a825dce89b533252e95c9c465c68858ee3ef16c81305d
    CRC32: 6d3d8808
    DETT202Q1暂未更新自述文件,参考2021版自述文件
    NI LabVIEW 2021 Desktop Execution Trace Toolkit for Windows Readme
    July 2021
    This file contains installation instructions and compatibility information for NI LabVIEW 2021 Desktop Execution Trace Toolkit.
    • Manuals: New features, behavior changes, and other documentation
    The Desktop Execution Trace Toolkit for Windows captures execution data from LabVIEW applications running on the desktop. The toolkit displays the data it captures, called trace data, as events in a table pane that you can browse, save, or export to a text file. For each execution event, the table pane displays the type of event, the time the event occurs, the VI in which the event occurs, and any additional details that are available. Use trace data to debug and optimize large LabVIEW applications, including those with multiple loops, client-server architectures, dynamically loaded VIs, and so on.
    In addition to the system requirements for the LabVIEW Development System, the LabVIEW 2021 Desktop Execution Trace Toolkit has the following requirements:
    • LabVIEW 2021 Base, Full, or Professional Development System
    • Pentium 4 processor or equivalent
    • At least 1 GB of disk space
    Note  The LabVIEW 2021 Professional Development System license activates the LabVIEW 2021 Desktop Execution Trace Toolkit.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2021.
    LabVIEW 2021 Desktop Execution Trace Toolkit supports the following operating systems:
    Download the LabVIEW Desktop Execution Trace Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate LabVIEW Desktop Execution Trace Toolkit. For more information on LabVIEW Desktop Execution Trace Toolkit activation, refer to NI Software Activation.
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help from LabVIEW, for information about the Desktop Execution Trace Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Desktop Execution Trace folder to access the examples. You also can find the examples for the Desktop Execution Trace Toolkit in the labview\examples\Desktop Execution Trace directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW Desktop Execution Trace Toolkit no longer supports Windows 7/8.1, Windows Server 2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2008–2021 National Instruments Corporation. All rights reserved.
    375337H-01
    GMT+8, 2026-2-25 00:53
