NI RF Signal Generators 2024 Q3 Win11 32/64bitEng NI RF信号发生器NI-RFSG24.5.0
NI-RFSG
NI-RFSG 2024 Q3
发布日期:2024/7/16
包含的版本:2024 Q3完整版,版本号24.5.0
文件大小: 5544302592 字节 (5.16 GB)
修改日期: 2024-07-26 20:49
MD5: 70f2d7eb866307bc755e8ec184cd1ea0
SHA1: fbca7f12edb8f3e7971c8683907a6350b50df8b6
SHA256: 1906e9e4576d490c88b0b9bee27b4de7ac940a548627c111476bb019c8860e91
CRC32: 5e50e9e0
请注册登录机器视觉论坛账号,购买附件查看下载地址
RFSG2024Q3.txt
(568 Bytes, 下载次数: 0, 售价: 10 圆)
2024Q3版未更新自述文件,参考2023Q3版
NI-RFSG 2023 Q3 ReadmeJuly 2023 This file contains installation instructions and compatibility information for NI-RFSG 2023 Q3. You can find more release information on ni.com. - NI-RFSG Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- NI-RFSG Documentation: New features, behavior changes, and other documentation
New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Accessing the API Finding Examples Accessing the Documentation Product Security and Critical Updates Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 Unsupported Windows Operating Systems New FeaturesNI-RFSG 2023 Q1 Patch 1 includes the following new feature: - Support for PXIe-5842 VST with 54 GHz Frequency Extension
NI-RFSG 2023 Q1 includes the following new feature: - Support for LabVIEW 2023 Q1
NI-RFSG 2022 Q4 includes the following new feature: Supported HardwareVisit NI Hardware and Software Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
- Type your hardware model number in the dropdown list on the web page to filter the list of available devices.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. MXI Express and MXI-4 are supported on Windows 10. Note You must install the same version of the NI-RFSA/NI-RFSG Runtime for PXIe-5644/5645/5646 and NI-RFSA/NI-RFSG Runtime for PXIe-5820/5830/5831/5832/5840/5841/5842 if you choose to install the runtimes independently. Note For best memory performance on the PXIe-5831/5832, NI recommends using only 64-bit applications. System RequirementsNI-RFSG has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM*
- Any supported OS, with all available critical updates and service packs
*Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Note Guest accounts are not supported under any OS. Note NI-RFSG 2023 Q3 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2023 Q3. Supported Operating SystemsNI-RFSG and NI-RFSG SFP support the following operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
- NI Linux® Real-Time
Application Software SupportNI-RFSG supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSG. To add support for application software installed after installing NI-RFSG, modify your NI-RFSG installation or launch the NI-RFSG installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by NI-RFSG | | LabVIEW | 2020 and later | | LabWindows/CVI | 2019 and later | | LabVIEW Real-Time Module | 2021 and later |
Note Install any toolkits or add-on software you intend to use with the NI-RFSG instrument driver after NI-RFSG installation is complete. Refer to the getting started guide for your device for more information about software and hardware installation. Note MXI users must install the software included with the MXI hardware. Microsoft Visual Studio SupportIf you are using the NI-RFSG .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSG .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. For more information on .NET development using NI .NET drivers, visit ni.com/info and enter Info Code NETAPIdriversupport. To install the NI-RFSG .NET Class Library, ensure that you select .NET Framework 4.5 Languages Support or .NET Framework 4.0 Languages Support in the NI-RFSG installer. Installation InstructionsDownload the NI-RFSG installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Accessing the APILabVIEWNI-RFSG VIs are available in LabVIEW from the Functions»Measurement I/O»NI-RFSG palette. LabWindows/CVINI-RFSG functions are available in LabWindows/CVI from the Instrument menu. To load the NI-RFSG function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niRFSG\niRFSG.fp. .NET FrameworkYou can use the NI-RFSG .NET Class library by adding a reference to NationalInstruments.ModularInstruments.NIRfsg.Fx40 or NationalInstruments.ModularInstruments.NIRfsg.Fx45 and any dependent class libraries from within the Solution Explorer in Visual Studio. CYou can use the NI-RFSG C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSG.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSG_64.dll for 64-bit development. NI-RFSG SFPTo launch the NI-RFSG SFP, navigate to Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Soft Front Panel. Updated LabVIEW Compatibility PolicyThe "NI-RFSG Support for LabVIEW" package supports applications using NI-RFSG with LabVIEW 2023 Q1 or later. When installing NI-RFSG, this package will be recommended if you have already installed LabVIEW 2023 Q1 or later and installs to the LVAddons directory. LVAddons directory location: C:\Program Files\NI\LVAddons Finding ExamplesSelect Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output»Modular Instruments»NI-RFSG. You can also select the Search tab to search all installed examples by keyword. You can access all the installed NI-RFSG examples at Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Examples. Accessing the DocumentationDocumentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. This documentation set is composed of the following documents. Document | Format | Description | | NI RF Signal Generators Help | HTML/Windows Help | Contains primary help content for NI-RFSG products. The help is an HTML version of a traditional user manual that includes the following information:- An introduction to RF fundamentals
- Hardware device overviews
- How to get started with application development
- The NI-RFSG Soft Front Panel Help
- A complete reference for all NI-RFSG VIs, properties, and functions, as well as the NI-RFSG .NET Class Library Help
Other documentation for NI-RFSG can be found in Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents. Document | Format | Description | | Introduction to niRFSG | HTML | Contains information about driver documentation, examples, connecting to your instrument, configuring instrument settings, and known issues. | | NI-RFSG IVI Compliance Document | TXT | Contains information about IVI compliance. |
For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. Unsupported Windows Operating SystemsNI-RFSG no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport. |
