查看: 1403|回复: 0
[NI驱动程序] NI RF Signal Generators 2024 Q2 Patch 1 Win11 32/64bitEng NI RF信号发生器NI-RFSG24.3.1
     楼主| 发表于 2024-9-29 16:46:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2024 Q2 Patch 1
    发布日期:2024/5/4
    包含的版本:2024 Q2 Patch1完整版,版本号24.3.1
    文件大小: 4969482240 字节 (4.63 GB)
    修改日期: 2024-09-28 17:03
    MD5: b2dd2a70cf34e79fa2d3e68e6430a854
    SHA1: d8c5f791167fa9fd3c9390eabf12fc5700937ed5
    SHA256: 5e368b1798befefaec861b41367a6f11353a3b170f7c1d51ba45685d0525f9d2
    CRC32: beb2b293
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFSG2024Q2Patch1.txt (576 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q2Patch1版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-RFSG 2023 Q3.
    • NI-RFSG Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Documentation: New features, behavior changes, and other documentation
    NI-RFSG 2023 Q1 Patch 1 includes the following new feature:
    NI-RFSG 2023 Q1 includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSG 2022 Q4 includes the following new feature:
    Note  You must install the same version of the NI-RFSA/NI-RFSG Runtime for PXIe-5644/5645/5646 and NI-RFSA/NI-RFSG Runtime for PXIe-5820/5830/5831/5832/5840/5841/5842 if you choose to install the runtimes independently.
    • 4 GB RAM*
    Note  NI-RFSG 2023 Q3 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2023 Q3.
    NI-RFSG and NI-RFSG SFP support the following operating systems:
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    The "NI-RFSG Support for LabVIEW" package supports applications using NI-RFSG ​with LabVIEW 2023 Q1 or later. When installing NI-RFSG, this package will be recommended if you have already installed LabVIEW 2023 Q1 or later and installs to the LVAddons directory.
    You can access all the installed NI-RFSG examples at Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Examples.
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    • Hardware device overviews
    Other documentation for NI-RFSG can be found in Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSG no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-8 08:25
