查看: 961|回复: 0
[NI驱动程序] NI RF Signal Generators 2023 Q1 Patch 4 Win11 32/64bitEng NI RF信号发生器NI-RFSG23.0.4
  • 签到天数: 3734 天
    连续签到: 61 天
     楼主| 发表于 2024-9-29 16:59:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2023 Q1 Patch 4
    发布日期:2023/10/26
    包含的版本:2023 Q1 Patch 4完整版,版本号23.0.4
    文件大小: 4454379520 字节 (4.15 GB)
    修改日期: 2024-09-28 18:46
    MD5: ac743e9d639c913e3f91fc7564fab9ea
    SHA1: 9eb52ac7f810aa9477c63b834b0a13294a2ed647
    SHA256: 4dacc3a2a1d40ce07e8897c180ebc42788d16b48074c66841d79385bdf7d340a
    CRC32: b400d0ed
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFSG2023Q1Patch4.txt (576 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG 2023 Q1 Patch Readme
    March 2023
    This file contains installation instructions and compatibility information for NI-RFSG 2023 Q1 Patch.
    • NI-RFSG Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Documentation: New features, behavior changes, and other documentation
    NI-RFSG 2023 Q1 Patch includes the following new feature:
    NI-RFSG 2023 Q1 includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSG 2022 Q4 includes the following new feature:
    NI-RFSG 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022 Q3
    • 4 GB RAM*
    Note  NI-RFSG 2023 Q1 Patch is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2023 Q1 Patch.
    NI-RFSG and NI-RFSG SFP support the following operating systems:
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    The "NI-RFSG Support for LabVIEW" package supports applications using NI-RFSG ​with LabVIEW 2023 Q1 or later. When installing NI-RFSG, this package will be recommended if you have already installed LabVIEW 2023 Q1 or later and installs to the LVAddons directory.
    You can access all the installed NI-RFSG examples at Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Examples.
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSG no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-6 17:22
