查看: 855|回复: 0
[NI软件产品] NI RFmx WLAN 2024 Q3 Patch 1 Win11 64bitENG RFmx无线局域网络24.5.1
    9 小时前
     楼主| 发表于 2024-10-12 11:42:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:2024/8/20
    包含的版本:2024 Q3Patch1完整版,版本号24.5.1
    64位完整版校验和:
    文件大小: 2175477760 字节 (2.03 GB)
    修改日期: 2024-10-12 11:35
    MD5: 692a6eca43f6f59632fde802bba7f245
    SHA1: f25dd152a02572c5d6f7703c5bed47ad52ce4446
    SHA256: 5fec365c71439377e3ae7b4b8694357ce8d0fed52f4fe4ca1cc35992f1c1b1b7
    CRC32: 8a099429
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFmx WLAN2024Q3Patch1.txt (604 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 959053824 字节 (914.63 MB)
    修改日期: 2024-10-12 11:33
    MD5: aacca5ecfd36aaee9f4c2ea46455f93a
    SHA1: c728abb9d9316d233ed93121f4d9ca464e2d48b5
    SHA256: 44565b86c055e4ab9208a69cbf8fcda246a09b2bf7c45286aec9f6bf1a243154
    CRC32: 3146d002
    RFmx WLAN2024Q3Patch1RTE.txt (627 Bytes, 下载次数: 0, 售价: 5 圆)
    2024Q3Patch1未更新自述文件,参考2023Q3版
    RFmx WLAN 2023 Q3 Readme
    RFmx WLAN 2023 Q3 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D3.2
    • Support for auto detection of signal in Analysis-Only Mode
    RFmx WLAN 2023 Q2 includes the following new features:
    • Support for Combined Signal Demodulation across all MIMO standards
    • Support for 802.11be Standard IEEE P802.11be/D3.0
    RFmx WLAN 2023 Q1 includes the following new features:
    • Support for Fields Gated Power for 802.11be standard
    • Support for 802.11be Standard IEEE P802.11be/D2.3
    RFmx WLAN 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WLAN 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WLAN (64-bit only)
    Item
    Installed Location
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN Documentation.
    You can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN Examples.
    The following is the behavior change in RFmx WLAN 2023 Q3 from RFmx WLAN 2023 Q2
    The following are the behavior changes in RFmx WLAN 2022 Q3 from RFmx WLAN 21.8.2:
    • EVM Noise compensation includes support to work for Linear, Wiener and Triangular Smoothing channel estimation interpolation types
    The following are the behavior changes in RFmx WLAN 21.8 from RFmx WLAN 21.5.
    • RFmx WLAN drops support for 32-bit user mode.
    • When you set the OFDMModAcc Noise Comp Enabled property to True:
      • Noise compensation applied limit check is now skipped if OFDMModAcc EVM Ref Data Symbols Mode property is set to Reference Waveform
      • EVM per Subcarrier and the EVM per Symbol traces now follow the noise compensation applied result
    GMT+8, 2025-12-8 18:28
