查看: 1010|回复: 0
[NI软件产品] NI RFmx WLAN 2023 Q2 Patch 2 Win11 64bitENG RFmx无线局域网络23.3.2
    9 小时前
     楼主| 发表于 2024-10-12 14:00:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:2023/9/8
    包含的版本:2023 Q2Patch2完整版,版本号23.3.2
    64位完整版校验和:
    文件大小: 1487515648 字节 (1.39 GB)
    修改日期: 2024-10-12 11:48
    MD5: 80f85f5c7c662ea58f98183071347372
    SHA1: 954f7b02b7be960fe591be89f9dc3b18b761109f
    SHA256: dfa37e15b0283e37c600c6214b4d8fddd6606316f9483c3604a41ce42cc6dec0
    CRC32: 89b4fe7b
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFmx WLAN2023Q3Patch2.txt (604 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 683939840 字节 (652.26 MB)
    MD5: 11824bfc9a769185a20a0819abeba812
    SHA1: d55d45bb482755fc5fd027892578b00b30aa5a95
    SHA256: e5fd821a11d58a800da4eb7a7174740093828728c76c29debac40b66f5afb437
    CRC32: fa8e65a8
    RFmx WLAN2023Q3Patch2RTE.txt (636 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WLAN 2023 Q2 Readme
    April 2023
    RFmx WLAN 2023 Q2 includes the following new features:
    • Support for Combined Signal Demodulation across all MIMO standards
    • Support for 802.11be Standard IEEE P802.11be/D3.0
    RFmx WLAN 2023 Q1 includes the following new features:
    • Support for Fields Gated Power for 802.11be standard
    • Support for 802.11be Standard IEEE P802.11be/D2.3
    RFmx WLAN 2022 Q4 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D2.1.1
    • Support for calculating EVM for WLAN Preamble fields
    • Support for analyzing 320 MHz non-HT duplicate mode frame format
    • Support for PXIe-5842
    RFmx WLAN 2023 Q2 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 2023 Q2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 2023 Q2 to an unsupported OS. Additionally, after installing RFmx WLAN 2023 Q2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WLAN (64-bit only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    Item
    Installed Location
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN Documentation.
    You can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN Examples.
    The following are the behavior changes in RFmx WLAN 2022 Q3 from RFmx WLAN 21.8.2:
    • EVM Noise compensation includes support to work for Linear, Wiener and Triangular Smoothing channel estimation interpolation types
    The following are the behavior changes in RFmx WLAN 21.8 from RFmx WLAN 21.5.
    • RFmx WLAN drops support for 32-bit user mode.
    • When you set the OFDMModAcc Noise Comp Enabled property to True:
      • Noise compensation applied limit check is now skipped if OFDMModAcc EVM Ref Data Symbols Mode property is set to Reference Waveform
      • EVM per Subcarrier and the EVM per Symbol traces now follow the noise compensation applied result
    GMT+8, 2025-12-8 18:27
