查看: 898|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2023 Q3 Patch 2 Win11 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试23.5.2
    9 小时前
     楼主| 发表于 2024-10-12 16:07:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    RFmx W-CDMA/HSPA+为W-CDMA、HSPA和HSPA+蜂窝测试应用提供信号生成和分析功能。
    RFmx W-CDMA/HSPA+是一款测量专用软件,旨在扩展NI RF仪器生成和分析W-CDMA、HSPA和HSPA+蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对W-CDMA、HSUPA和HSUPA+上行链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2023/9/8
    包含的版本:2023 Q3Patch2完整版/运行版,版本号23.5.2
    64位完整版校验和:
    文件大小: 1389455360 字节 (1.29 GB)
    修改日期: 2024-10-12 14:17
    MD5: 54130f5b7c2e31e9032e769cb24fedda
    SHA1: 67af1bd93533da81ea321c2c3424f33466e82a64
    SHA256: c019bab697dea0b6babb15ee661023572ee08d5370bc6ff2b6e1cf2865894847
    CRC32: ce489bc7
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx WCDMA2023Q3Patch2.txt (616 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 671234048 字节 (640.14 MB)
    修改日期: 2024-10-12 14:14
    MD5: cce568d1d7ce846394aebfde77357ec0
    SHA1: 11e3236893161c6fb14d077c40b4297c05047cee
    SHA256: 08efcd6c4717625ed5742d623afd62826b1df7ca713ae31a798b8f92fcbe7ad1
    CRC32: c7ddf23e
    RFmx WCDMA2023Q3Patch2RTE.txt (646 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WCDMA 2023 Q3 Readme
    This file contains important information about the RFmx WCDMA, including system requirements, and installation instructions.
    • RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx WCDMA Manuals: New features, behavior changes, and other documentation
    RFmx WCDMA 2023 Q2 includes the following new feature:
    RFmx WCDMA 2023 Q1 includes the following new feature:
    RFmx WCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx WCDMA has the following requirements:
    RFmx WCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WCDMA (64-bit only)
    If you are using the RFmx WCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.WcdmaMX.Fx40.dll
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA Documentation.
    You can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA Examples.
    The following is the behavior change in RFmx WCDMA 2023 Q3 from RFmx WCDMA 2023 Q2
    The following is the behavior change in RFmx WCDMA 2022 Q4 from RFmx WCDMA 2022 Q3
    • RFmx WCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx WCDMA 2022 Q3 from RFmx WCDMA 21.8.2
    The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6.
    GMT+8, 2025-12-8 18:28
