NI RFmx W-CDMA/HSPA+ 2024 Q3 Patch 1 Win11 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试24.5.1
RFmx W-CDMA/HSPA+
RFmx W-CDMA/HSPA+为W-CDMA、HSPA和HSPA+蜂窝测试应用提供信号生成和分析功能。
RFmx W-CDMA/HSPA+是一款测量专用软件,旨在扩展NI RF仪器生成和分析W-CDMA、HSPA和HSPA+蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对W-CDMA、HSUPA和HSUPA+上行链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
发布日期:2024/8/20
包含的版本:2024 Q3Patch1完整版/运行版,版本号24.5.1
64位完整版校验和:
文件大小: 2064887808 字节 (1.92 GB)
修改日期: 2024-10-12 14:20
MD5: 47e454860ca4d18a0c9c08d5405fdc4d
SHA1: e11adc9bdb9d811bc2d4a0fc888268b44868ff83
SHA256: 75a8cbf08abf54aac4214ceb0c56186d268b0048aaee6176810189f98e9417c8
CRC32: 64458af2
请注册登录视觉论坛账号,购买附件查看下载地址
RFmx WCDMA2024Q3Patch1.txt
(616 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 934490112 字节 (891.20 MB)
修改日期: 2024-10-12 14:19
MD5: c51984246ba1e545b96876eafc08c6fe
SHA1: 2aa8890eb20a580a3f780366f2a82b7c994224d3
SHA256: 39fecacb26d38261e28aae238e84cc892f1f8e2f8cc4ed7efc052deecdbc3e37
CRC32: 81eab0f9
RFmx WCDMA2024Q3Patch1RTE.txt
(646 Bytes, 下载次数: 0, 售价: 5 圆)
2024Q3版未更新自述文件,参考2023Q3版本。
RFmx WCDMA 2023 Q3 ReadmeJuly 2023 This file contains important information about the RFmx WCDMA, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx WCDMA Manuals: New features, behavior changes, and other documentation
New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 New FeaturesRFmx WCDMA 2023 Q2 includes the following new feature: - Speed improvements for Composite and Spectral measurements
RFmx WCDMA 2023 Q1 includes the following new feature: - Support for LabVIEW 2023 Q1 (64-bit)
RFmx WCDMA 2022 Q4 includes the following new feature: Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
- Type your hardware model number in the dropdown list on the web page to filter the list of available devices.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx WCDMA has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx WCDMA 2023 Q3 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx WCDMA (64-bit only) | | LabVIEW | 2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1, 2023 Q3 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx WCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File LocationsItem | Installed Location | | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | | DLLs | | | Header files | \Shared\ExternalCompilerSupport\C\include | | Import Library files | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| | .NET Class Libraries | | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.WcdmaMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments » InstrumentStudio to launch the InstrumentStudio. Accessing the APIRFmx WCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » WCDMA palette. Accessing the DocumentationDocumentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA Documentation. Finding ExamplesYou can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following is the behavior change in RFmx WCDMA 2023 Q3 from RFmx WCDMA 2023 Q2 - Added support for saving and loading RFmx configurations into/from rfmxconfig files. Load from TDMS is supported but save into TDMS files is discontinued.
The following is the behavior change in RFmx WCDMA 2022 Q4 from RFmx WCDMA 2022 Q3 - RFmx WCDMA drops support for 32-bit user mode.
The following is the behavior change in RFmx WCDMA 2022 Q3 from RFmx WCDMA 21.8.2 - The RFmx Soft Front Panel has been replaced by InstrumentStudio.
The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6. - Obsoleted the RFmxInstr Configure Automatic SG SA Shared LO API and the RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. |
