NI RFmx for Bluetooth Test 2024 Q3 Win11 64bitEng RFmx蓝牙测试NIRFmxBluetooth24.5.0
发布日期:2024/7/16
包含的版本:2024 Q3完整版/运行版,版本号24.5.0
语言:英文English
64位完整版校验和:
文件大小: 2110978048 字节 (1.97 GB)
修改日期: 2024-07-29 09:30
MD5: 694c69ce5b199cae92edca9d96c199a7
SHA1: 022900ef115aec5a3fe3670a6eef9154e7f8e8ec
SHA256: 39b744572a4572d3c91d2c92be9b06765f3aad7091054e8872b6d67052408beb
CRC32: 788a0513
请注册登录机器视觉论坛账号,购买附件查看下载地址
RFmx for Bluetooth Test2024Q3.txt
(630 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 978716672 字节 (933.38 MB)
修改日期: 2024-07-27 17:26
MD5: 3ab21bdfab46644e4d10cb987a85e38e
SHA1: 5c53e61354811c409ea96f1424fa1a0b5ea7343b
SHA256: aa3e0e24823659f70f9088f4c53d844847505bc952a893805da30663291d53c5
CRC32: ac8ef15c
RFmx for Bluetooth Test2024Q3RTE.txt
(656 Bytes, 下载次数: 0, 售价: 5 圆)
2024Q3版未更新自述文件,参考2023Q3版
RFmx for Bluetooth® Test 2023 Q3 ReadmeJuly 2023 This file contains important information about the RFmx for Bluetooth® Test, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx for Bluetooth® Test Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx for Bluetooth® Test Manuals: New features, behavior changes, and other documentation
New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 New FeaturesRFmx for Bluetooth® Test 2023 Q2 includes the following new features: - Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.4, and the Bluetooth RF PHY test specifications RF.TS.p30e2 and RF-PHY.TS.p15.
- Support for Low Energy Direction Finding physical layer conforming to Bluetooth Core Specification v5.4
- Speed improvements for Composite and Spectral measurements
RFmx for Bluetooth® Test 2023 Q1 includes the following new feature: - Support for LabVIEW 2023 Q1 (64-bit)
RFmx for Bluetooth® Test 2022 Q4 includes the following new feature: - Support for DF2 and CFO measurements for Bluetooth LE 500kbps (S=2) packets
- Support for PXIe-5842
Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
- Type your hardware model number in the dropdown list on the web page to filter the list of available devices.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx for Bluetooth® Test has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx for Bluetooth® Test 2023 Q3 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note RFmx for Bluetooth® Test no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx for Bluetooth® Test 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx for Bluetooth® Test 2023 Q3 to an unsupported OS. Additionally, after installing RFmx for Bluetooth® Test 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx for Bluetooth® Test supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx for Bluetooth® Test. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx for Bluetooth® Test (64-bit only) | | LabVIEW | 2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1, 2023 Q3 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx for Bluetooth® Test .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx for Bluetooth® Test .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx for Bluetooth® Test installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx for Bluetooth® Test. For more information on RFmx for Bluetooth® Test activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File LocationsItem | Installed Location | | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | | DLLs | | | Header files | \Shared\ExternalCompilerSupport\C\include | | Import Library files | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| | .NET Class Libraries | | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.BTMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments » InstrumentStudio to launch the InstrumentStudio. Accessing the APIRFmx for Bluetooth® Test palette VIs are available from the Functions » Measurement I/O » RFmx » BT palette. Accessing the DocumentationDocumentation for RFmx for Bluetooth® Test is located at Start » National Instruments » RFmx for Bluetooth® Test Documentation. Finding ExamplesYou can access all the installed RFmx for Bluetooth® Test examples at Start » National Instruments » RFmx for Bluetooth® Test Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following is the behavior change in RFmx Bluetooth® Test 2023 Q3 from RFmx Bluetooth® Test 2023 Q2 - Added support for saving and loading RFmx configurations into/from rfmxconfig files. Load from TDMS is supported but save into TDMS files is discontinued.
The following is the behavior change in RFmx for Bluetooth® Test 2022 Q4 from RFmx for Bluetooth® Test 2022 Q3: - RFmx for Bluetooth® Test drops support for 32-bit user mode.
The following is the behavior change in RFmx for Bluetooth® Test 2022 Q3 from RFmx for Bluetooth® Test 21.8.2: - The RFmx Soft Front Panel has been replaced by InstrumentStudio.
The following are the behavior changes in RFmx for Bluetooth® Test 21.3 from RFmx for Bluetooth® Test 20.7. - Obsoleted ConfigureFrequencyChannelNumber(string, int, int) method in .NET. Use ConfigureFrequencyChannelNumber(string, RFmxBTMXStandard, int) method instead.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. |
