查看: 860|回复: 0
[NI驱动程序] NI RFmx CDMA2000 2024 Q3 Full/Runtime Win11 64bitENG RFmxCDMA2K完整版运行版24.5.0下载
     楼主| 发表于 2024-10-15 10:21:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:2024/7/16
    包含的版本:2024 Q3完整版/运行版,版本号24.5.0
    64位完整版校验和:
    文件大小: 1049202688 字节 (1000.60 MB)
    修改日期: 2024-07-27 17:22
    MD5: bd123dbadbc0cfe89ad229d88d4e15d6
    SHA1: 4b81910ef29a65cabacf7edb148e91c0ea3b1d45
    SHA256: d1efca0f103b19fbda5eff4561daadf9f5235f96639958326326308125375387
    CRC32: b996423d
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2K2024Q3.txt (611 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 934438912 字节 (891.15 MB)
    修改日期: 2024-07-26 15:52
    MD5: 61cb6d5ff1de414818461be1ab899f97
    SHA1: 3aea2b46538d48bea8be2c12b04410c158685e92
    SHA256: a49b8372f2976c78950e39d339c71698c8eb8b486ef6d8a4bd362a8f8050145e
    CRC32: be6ed859
    RFmx CDMA2K2024Q3RTE.txt (637 Bytes, 下载次数: 0, 售价: 5 圆)
    2024Q3版未更新自述文件,参考2023Q3版本
    RFmx CDMA2k 2023 Q3 Readme
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    RFmx CDMA2k 2023 Q2 includes the following new feature:
    RFmx CDMA2k 2023 Q1 includes the following new feature:
    RFmx CDMA2k 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for Downlink link direction in CDMA2k ModAcc measurement.
    RFmx CDMA2k 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2023 Q3 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Versions Supported by RFmx CDMA2k (64-bit only)
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following is the behavior change in RFmx CDMA2k 2023 Q3 from RFmx CDMA2k 2023 Q2
    The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3
    • RFmx CDMA2k drops support for 32-bit user mode.
    The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    GMT+8, 2025-12-8 08:20
