查看: 907|回复: 0
[NI软件产品] NI RFmx CDMA2000 2024 Q3 Patch 1 Full/Runtime Win11 64bitENG RFmxCDMA2K完整版运行版24.5.1下载
    9 小时前
     楼主| 发表于 2024-10-15 10:24:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:2024/8/20
    包含的版本:2024 Q3Patch1完整版/运行版,版本号24.5.1
    64位完整版校验和:
    文件大小: 1049210880 字节 (1000.61 MB)
    修改日期: 2024-10-15 10:00
    MD5: 75501ce2ea48504352bc3511a8f8b523
    SHA1: d4700b47d179bc4af57dc220046bba0eda4e4bed
    SHA256: dc81849fb3cb29b271bcc41df30dc03f4d1c40e4e166d074c9f7cf0c1c1ef82a
    CRC32: a705e843
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2K2024Q3Patch1.txt (619 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 934447104 字节 (891.16 MB)
    修改日期: 2024-10-15 10:01
    MD5: e24aadb10201dd943379931b384b3d0d
    SHA1: b565e316742ab654efe0f179f58bf30d90307bed
    SHA256: 6278986c4d22b6b3fce9714c0ae3146109ea81aee39740cea38e92d99dd31eb6
    CRC32: 62095593
    RFmx CDMA2K2024Q3Patch1RTE.txt (645 Bytes, 下载次数: 0, 售价: 5 圆)
    2024Q3Patch1版未更新自述文件,参考2023Q3版本
    RFmx CDMA2k 2023 Q3 Readme
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    RFmx CDMA2k 2023 Q2 includes the following new feature:
    RFmx CDMA2k 2023 Q1 includes the following new feature:
    RFmx CDMA2k 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for Downlink link direction in CDMA2k ModAcc measurement.
    RFmx CDMA2k 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2023 Q3 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Versions Supported by RFmx CDMA2k (64-bit only)
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following is the behavior change in RFmx CDMA2k 2023 Q3 from RFmx CDMA2k 2023 Q2
    The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3
    • RFmx CDMA2k drops support for 32-bit user mode.
    The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    GMT+8, 2025-12-8 18:28
