查看: 1046|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 2023 Q3 Patch 2 Win11 64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件23.5.2
    9 小时前
     楼主| 发表于 2024-10-15 18:53:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE+
    发布日期:2023/9/8
    包含的版本:2023 Q3 Patch2完整版/运行版,版本号23.5.2
    64位完整版校验和:
    文件大小: 1367289856 字节 (1.27 GB)
    修改日期: 2024-10-15 18:25
    MD5: 49ac233947a9c66f3f5c40c80dfdce6e
    SHA1: b95259b6a822e82762c14fff756d6829f6b3202a
    SHA256: 994a56cd8c72ce4401e9b76dfdf1da54150c25465a6aac61b19b6d3e31ff7525
    CRC32: 03bb2563
    NI官方下载和百度网盘下载地址:
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM EDGE 2023Q3Patch2.txt (605 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 655970304 字节 (625.58 MB)
    修改日期: 2024-10-15 18:24
    MD5: 603d24f14d7bb79be0798b2d7bd9ac81
    SHA1: 1f85789288f92096167401571d9d059f4d700239
    SHA256: 6a36de17404239cd8ff7790f442b868020942bc91149dba755a63117be817a5a
    CRC32: 13fbba08
    NI官方下载和百度网盘下载地址:
    RFmx GSM EDGE 2023Q3Patch2RTE.txt (637 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 2023 Q3 Readme
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    • RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx GSM Manuals: New features, behavior changes, and other documentation
    RFmx GSM 2023 Q2 includes the following new feature:
    RFmx GSM 2023 Q1 includes the following new feature:
    RFmx GSM 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for configurable RBW in PVT measurement.
    RFmx GSM has the following requirements:
    RFmx GSM 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 2023 Q3 to an unsupported OS. Additionally, after installing RFmx GSM 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx GSM (64-bit only)
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » National Instruments » RFmx GSM Documentation.
    You can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM Examples.
    The following is the behavior change in RFmx GSM 2023 Q3 from RFmx GSM 2023 Q2
    The following is the behavior change in RFmx GSM 2022 Q4 from RFmx GSM 2022 Q3
    • RFmx GSM drops support for 32-bit user mode.
    The following is the behavior change in RFmx GSM 2022 Q3 from RFmx GSM 21.8.2
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    GMT+8, 2025-12-8 18:28
