查看: 861|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 2024 Q3 Win11 64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件24.5.0
    9 小时前
     楼主| 发表于 2024-10-15 18:56:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE+
    发布日期:2024/7/16
    包含的版本:2024 Q3完整版/运行版,版本号24.5.0
    64位完整版校验和:
    文件大小: 2043103232 字节 (1.90 GB)
    修改日期: 2024-07-26 13:06
    MD5: 6ebc0b201705368a8023184a69622585
    SHA1: 03b11955eaab90ff1dbe483723cc77651844a008
    SHA256: c8d96759fdcb8b6cb6f184369494925c430b899322422bd44ddbf9828fedd0cf
    CRC32: 12f91e38
    NI官方下载和百度网盘下载地址:
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM EDGE 2024Q3.txt (597 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 919216128 字节 (876.63 MB)
    修改日期: 2024-07-26 12:01
    MD5: db5566f1385e31abaf97e2113aef4864
    SHA1: a6d3bd394f0882da2182719723d392f1290fe52e
    SHA256: 1b76d23bbbeb99a87c86cdc0210d5f0102f758eb28eb266cbf9b4570c78e20eb
    CRC32: 36026b97
    NI官方下载和百度网盘下载地址:
    RFmx GSM EDGE 2024Q3RTE.txt (629 Bytes, 下载次数: 0, 售价: 5 圆)
    2024Q3版未更新自述文件,参考2023Q3版本
    RFmx GSM 2023 Q3 Readme
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    • RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx GSM Manuals: New features, behavior changes, and other documentation
    RFmx GSM 2023 Q2 includes the following new feature:
    RFmx GSM 2023 Q1 includes the following new feature:
    RFmx GSM 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for configurable RBW in PVT measurement.
    RFmx GSM has the following requirements:
    RFmx GSM 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 2023 Q3 to an unsupported OS. Additionally, after installing RFmx GSM 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx GSM (64-bit only)
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » National Instruments » RFmx GSM Documentation.
    You can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM Examples.
    The following is the behavior change in RFmx GSM 2023 Q3 from RFmx GSM 2023 Q2
    The following is the behavior change in RFmx GSM 2022 Q4 from RFmx GSM 2022 Q3
    • RFmx GSM drops support for 32-bit user mode.
    The following is the behavior change in RFmx GSM 2022 Q3 from RFmx GSM 21.8.2
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    GMT+8, 2025-12-8 18:29
