查看: 901|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 2024 Q3 Patch 1 Win11 64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件24.5.1
    9 小时前
     楼主| 发表于 2024-10-15 18:58:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE+
    发布日期:2024/8/20
    包含的版本:2024 Q3 Patch 1完整版/运行版,版本号24.5.1
    64位完整版校验和:
    文件大小: 2043125760 字节 (1.90 GB)
    修改日期: 2024-10-15 18:29
    MD5: 1971f8df5d52a301776247dc947ebc94
    SHA1: 0c4491b80b9a0c452367a1d1dbc14cefa6328fa1
    SHA256: e0a0c8f97257a45ae7abee5967595ca563b2d76aa62ff42d4b20e5830ea1e8f4
    CRC32: e3b0cb2c
    NI官方下载和百度网盘下载地址:
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM EDGE 2024Q3Patch1.txt (605 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 919222272 字节 (876.64 MB)
    修改日期: 2024-10-15 18:27
    MD5: e656488b602bf0e1e01ca531c4de1093
    SHA1: e21d1d45abdd27900e7dab10044049198110ad48
    SHA256: a7cd3e8078f5ab92a7fe74905828b3ff8110c2bf5ea4844e0082ce459a4bda53
    CRC32: d0fdd6bc
    NI官方下载和百度网盘下载地址:
    RFmx GSM EDGE 2024Q3Patch1RTE.txt (637 Bytes, 下载次数: 0, 售价: 5 圆)
    2024Q3Patch1版未更新自述文件,参考2023Q3版本
    RFmx GSM 2023 Q3 Readme
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    • RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx GSM Manuals: New features, behavior changes, and other documentation
    RFmx GSM 2023 Q2 includes the following new feature:
    RFmx GSM 2023 Q1 includes the following new feature:
    RFmx GSM 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for configurable RBW in PVT measurement.
    RFmx GSM has the following requirements:
    RFmx GSM 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 2023 Q3 to an unsupported OS. Additionally, after installing RFmx GSM 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx GSM (64-bit only)
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » National Instruments » RFmx GSM Documentation.
    You can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM Examples.
    The following is the behavior change in RFmx GSM 2023 Q3 from RFmx GSM 2023 Q2
    The following is the behavior change in RFmx GSM 2022 Q4 from RFmx GSM 2022 Q3
    • RFmx GSM drops support for 32-bit user mode.
    The following is the behavior change in RFmx GSM 2022 Q3 from RFmx GSM 21.8.2
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    GMT+8, 2025-12-8 18:28
