查看: 986|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2023 Q3 Patch 2 Win11 64bitENG RFmx蜂窝测试TD-SCDMA23.5.2
    9 小时前
     楼主| 发表于 2024-10-16 15:13:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:2023/9/8
    包含的版本:2023 Q3 Patch 2完整版/运行版,版本号23.5.2
    64位完整版校验和:
    文件大小: 1386655744 字节 (1.29 GB)
    修改日期: 2024-10-16 11:56
    MD5: af99b3bc5b6ebc0bc262383eb503bf28
    SHA1: 6f80b7bb314622a3726874959579dd789a8f2525
    SHA256: 224fc4813617c1a7f7a703d5b97921f9f5deb0c429d4bb81447bf2afbd4be47c
    CRC32: 400ec38a
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA2023Q3Patch2.txt (620 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 671371264 字节 (640.27 MB)
    修改日期: 2024-10-16 11:54
    MD5: e7900fbd70dd0bb5627c179d963ba107
    SHA1: cc7cc945a250fa452c7ffd81a6ac40a85011d146
    SHA256: f7209ced880f75c83b2a89fb252d0537c8e3b7a3ae6c77ea273008d383d30dc4
    CRC32: 0d425f4e
    请注册登录视觉机器论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA2023Q3Patch2RTE.txt (648 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx TD-SCDMA 2023 Q3 Readme
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    RFmx TD-SCDMA 2023 Q2 includes the following new feature:
    RFmx TD-SCDMA 2023 Q1 includes the following new feature:
    RFmx TD-SCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx TD-SCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx TD-SCDMA (64-bit only)
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 2023 Q3 from RFmx TD-SCDMA 2023 Q2
    The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
    • RFmx TD-SCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
    GMT+8, 2025-12-8 18:28
