查看: 959|回复: 0
[NI软件产品] NI RFmx 2023 Q3 Patch 1 Win11 64bitEng NI Wireless Test Standard Software ni-rfmx-suite_23.5.1
    9 小时前
     楼主| 发表于 2024-10-16 16:00:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期:2023/9/2
    包含的版本:2023 Q3 Patch 1完整版,版本号23.5.0(Patch 1只有完整版,没有运行版)
    RFmx Full完整版
    文件大小: 3132987392 字节 (2.92 GB)
    修改日期: 2024-10-16 15:09
    MD5: 181ad773ec5ccfd9b50fabf236622c11
    SHA1: a52f5ba375f569cfeced07cc5df9846b7a365b7a
    SHA256: e59c678af658f4fb751e06d1ffab3d1b645c256d07d7c1bd04e873a7869e610e
    CRC32: 70ddc1e4
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx2023Q3Patch1.txt (631 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx 2023 Q3 Readme
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx for Bluetooth® Test
    • RFmx NR
    • RFmx LTE
    • RFmx Pulse
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    RFmx 2023 Q3 supports the following 64-bit operating systems:
    RFmx 2023 Q3 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by RFmx (64-bit Only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1, or 2023 Q3
    GMT+8, 2025-12-8 18:28
