查看: 903|回复: 0
[NI软件产品] NI RFmx VNA 2024 Q4 Win11 64bitENG RFmx矢量网络分析仪24.8.0
     楼主| 发表于 2024-10-30 14:30:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx VNA
    RFmx VNA可通过PXIe-5633矢量网络分析仪(VNA)测量单端口或双端口S参数。
    RFmx VNA是一款测量专用软件,扩展了NI RF仪器软件的功能,可帮助您使用PXIe-5633矢量网络分析仪测量散射参数(S参数)。借助RFmx VNA,您可以对典型RF前端模块中的RF组件(如放大器、天线、滤波器、衰减器和其他DUT)执行复杂的单端口和2端口S参数测量。
    NI RFmx VNA 2024 Q4
    发布日期:2024/10/8
    包含的版本:2024 Q4完整版/运行版,版本号24.8.0
    64位完整版校验和:
    文件大小: 2140813312 字节 (1.99 GB)
    修改日期: 2024-10-17 11:39
    MD5: f72caf71115f6fc483301e9182a9d4b2
    SHA1: d4579e9affc2d0fa5b7fbc9b38732ac378414aa7
    SHA256: 34d84bae1081dca64b5d871bbe1e2401677a0c74288d3a389e43ec25c4c8aa9d
    CRC32: fef8e17f
    请注册登录视觉机器论坛用户,购买附件查看下载地址
    RFmx VNA2024Q4RTE.txt (639 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 856432640 字节 (816.76 MB)
    修改日期: 2024-10-17 11:37
    MD5: ad8a61dbef67c4013e47d3b989580b30
    SHA1: 184e0fb6adf760b6f77cb0ba354a35872237f56a
    SHA256: 01458ef04c0abc79205df6f6031c6afe6ec4ae8dfc6dcf644768e687a3976d4b
    CRC32: fcd8ee08
    RFmx VNA2024Q4Full.txt (591 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx VNA 2024 Q4 New Features and Changes
    • Support to specify polar format for S-parameters and Waves.
    • Support to query S-parameters and waves in concise notation.
    • Support for interpolation of corrected S-parameters and waves measurements.
    • Support to query correction state.
    Changes
    • The following fetch VIs are deprecated:
      • RFmxVNA SParams Fetch Real Data.vi
      • RFmxVNA SParams Fetch Complex Data.vi
      • RFmxVNA Waves Fetch Real Data.vi
      • RFmxVNA Waves Fetch Complex Data.vi
    • TipUse the following VIs to fetch measurement data:
      • RFmxVNA SParams Fetch Y Data.vi
      • RFmxVNA Waves Fetch Y Data.vi
      TipUse the following VIs to fetch measurement frequency:
      • RFmxVNA SParams Fetch X Data.vi
      • RFmxVNA Waves Fetch X Data.vi
    • The PXIe_DStarB option for Pulse Generator Trigger terminal export is deprecated.NoteUse PXIe_DStarC instead.
    • The Undefined Thru Using Defined Thru option for Correction:Calibration:Thru:Method is deprecated.
    • The Delay Thru Using Defined Thru option for Correction:Calibration:Thru:Method has been replaced by vCal Thru as Unknown Thru
    RFmx VNA 2024 Q3 New Features and Changes
    • Support for List, Linear, and Segmented Sweep types
    • Support for exporting S-parameter measurement results as SnP files
    • Support for SWR, Impedance, and Admittance formats for S-parameters
    • Support for exporting Pulse Generator events
    • Support for aborting an ongoing calibration step
    • Deprecated RFmxVNA Configure Frequency List (Start Stop Points).vi.NoteTo work around this change, configure Sweep Type to Linear, and configure Start Frequency (Hz), Stop Frequency (Hz), and Number of Frequency properties.
    • You can no longer obtain the underlying list of aggregated frequencies across all active segments using the Sweep:Frequency List attribute.NoteUse the Sweep:X-Axis Values read-only attribute instead.
    • The Complex format in InstrumentStudio is no longer plotted as a Smith Chart. It is now plotted as a polar chart.NoteTo plot a Smith chart, set the format to Smith Impedance or Smith Admittance.
    RFmx VNA 2024 Q2 New Features and Changes
    • Support for external triggers for VNA measurements
    • Support for saving and loading stimulus settings along with Calset
    • Support for enabling and disabling automatic scaling down of Intermediate Frequency Bandwidth (IFBW) at low frequencies for measurement speed
    • Support for caching multiple signal switch for measurement speed
    • Support for guided calibration using Mechanical Calkits defined by NI Calkit files (.nckt )
    • Support for basic pulsed S-parameter and waves measurements with internal pulse-trigger
    • Support for embed fixtures to Calsets
    • Support for creating and editing Calkit files for Mechanical Calkits using the standalone Calkit Editor application.
    • Obsoleted the RFmxInstr Load All Configurations VI. Use the RFmxInstr Load Configurations VI along with the appropriate RFmxInstr Load Options property, instead.
    RFmx VNA 2024 Q1 New Features and Changes
    • Calibration: User-defined orientation for Cal-5501
    • Calsets
      • Load one or more named calsets from calset files previously saved
      • Select an active calset from the pool of loaded named calsets
      • Query the names of all loaded named calsets
      • Create a named copy of another named or unnamed calset
      • Query the error terms stored in a calset
    • Support for RFmxVNA SParams and RFmxVNA Waves measurements to perform as composite measurements
    • Added port extension support to specify electrical-length as delay (in seconds) and compensate for constant loss
    • IVI simulation support for PXIe-5633
    RFmx VNA 2023 Q4 Features Overview
    • Measure corrected and uncorrected 1-port or 2-port S-parameters and receiver waves for non-frequency-converting RF devices over a list of frequencies
    • Fixture de-embedding
    • Point averaging
    • Automatic Short-Open-Load (SOL) and Short-Open-Load-Through (SOLT) calibration using Cal-5501 Vector Calibration Module
    • Saving and loading calibration error terms as a calset file
    • Support for PXIe-5633
    • Support for obtaining unprocessed I/Q data utilized for RFmx measurements
    GMT+8, 2025-12-8 07:36
