查看: 945|回复: 0
[NI驱动程序] NI-SWITCH 2024 Q4 Win11 32/64bitEng/Jpn NI开关产品驱动程序24.8.0下载
     楼主| 发表于 2024-10-30 16:26:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    NI-SWITCH 2024 Q4
    发布日期:2024/10/8
    包含的版本:2024 Q4完整版,版本号24.8.0
    语言:英语,日语
    文件大小: 2596147200 字节 (2.42 GB)
    修改日期: 2024-10-17 14:30
    MD5: abd395d3d5881d71e2b71751a61e4a74
    SHA1: 815d1d1837f466e4736a3e71c55e4b46ff840eb0
    SHA256: 69ba8432a198b3341be5802a9db16b0d39bff483017c24185774548583a9b9a9
    CRC32: da087e76
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    SCOPE2024Q4.txt (573 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q4版未更新自述文件,请参考2023Q3版。
    NI-SWITCH 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-SWITCH 2023 Q3.
    • NI-SWITCH Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-SWITCH Documentation: Detailed documentation about how to use your product
    Include this section if your product supports Phar Lap ETS. NI no longer supports Phar Lap ETS Real-Time Operating System
    NI-SWITCH 2023 Q3 has the following requirements:
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for your version of LabVIEW.
    NI-SWITCH 2023 Q3 supports the following operating systems:
    • NI Linux® Real-Time
    NI-SWITCH 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-SWITCH 2023 Q3
    LabVIEW2020 and later
    LabVIEW Real-Time Module 32-bit2020 and later
    LabVIEW Real-Time Module 64-bit2021 and later
    LabWindows™/CVI™ Real-Time Module2019 and later
    If you are using the NI-SWITCH .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-SWITCH 2023 Q3 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Python Support
    For more information on installing and using the NI-SWITCH Python API, refer to the niswitch module.
    Download the NI-SWITCH installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    The "NI-SWITCH Support for LabVIEW" package supports applications using NI-SWITCH ​with LabVIEW 2022 or later. When installing NI-SWITCH, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    Refer to the NI-SWITCH documentation, accessible from Start»National Instruments»NI-SWITCH»NI-SWITCH Documentation, for information about the NI-SWITCH.
    You can access all the installed NI-SWITCH examples at Start»National Instruments»NI-SWITCH»NI-SWITCH Examples.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SWITCH are located in the labview\examples\instr\niSwitch directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate examples by task at Hardware Input and Ouput»Modular Instruments»NI-SWITCH or by directory structure at instr»niSwitch.
    • Click the Search tab to search all installed examples by keyword. For example, search for "SWITCH" to locate all NI-SWITCH examples.
    NI-SWITCH no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    NI No Longer Supports Phar Lap ETS Real-Time Operating SystemInclude this section if your product supports Phar Lap ETS.
    GMT+8, 2025-12-8 08:20
