NI System Configuration 2024 Q4 Win11 32/64位多国语言 NI系统配置nisyscfg24.8.0
System Configuration系统配置
发布日期:202/10/8
包含的版本:2024 Q4完整版,版本号24.8.0
语言:中文/德语/日语/法语/英文/韩语
文件大小: 1274038272 字节 (1.19 GB)
修改日期: 2024-10-17 11:58
MD5: 86ef68eb1d1c8a0c3514c188c16e8074
SHA1: 8ccd50edc5b3f0c6e5d28674858e1627e944e995
SHA256: fe02b2816d6bb0c98eb018a8daf0bb15dd8b1b14a7ef8fd114a293318862cca0
CRC32: cf177b4c
请注册登录机器视觉论坛账号,购买附件查看下载地址
系统配置2024Q4.txt
(628 Bytes, 下载次数: 0, 售价: 10 圆)
2024Q4版未更新自述说明,参考2023Q2
System Configuration 2023 Q2 ReadmeApril 2023 This file contains installation instructions and compatibility information for System Configuration. You can find more release information on ni.com. - Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
Overview Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Unsupported Windows Operating Systems NI no longer supports Phar Lap ETS Real-Time Operating System Legal Information OverviewSystem Configuration includes the following products: - NI Measurement & Automation Explorer (MAX) is a configuration utility that provides access to your NI devices.
- NI Hardware Configuration Utility is a utility that enables visualizing and configuring the hardware in your systems.
- Web-Based Configuration and Monitoring is a utility that enables remote configuration and monitoring of your NI devices.
- NI I/O Trace is an application that monitors, records, and displays NI API calls made by applications.
- NI Device Monitor is a utility for launching applications when a system detects an NI device.
System Configuration contains an API that can be used to programmatically control various NI devices in a system. Refer to the Application Software Support section of this document for more information on the API. Supported Operating SystemsSystem Configuration and components support the following operating systems: - Windows 11 (x64)
- Windows 10 (x64)
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
- NI Linux® Real-Time
Note System Configuration no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes. Application Software SupportSystem Configuration supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by System Configuration | | LabVIEW | 2019, 2020, 2021, 2022 Q3 and later | | LabWindows™/CVI™ | 2012 and later | Microsoft Visual Studio SupportSystem Configuration supports the following Microsoft Visual Studio versions and associated programming languages. Programming Language | Visual Studio Versions Support by System Configuration | Location of Visual Studio Examples on Windows 10 | .NET Framework 4.0 Languages
(Visual C#) | 2010 | C:\Users\Public\Documents\National Instruments\MStudioVS2010\DotNET\Examples | .NET Framework 4.5 Languages
(Visual C#) | 2012 | C:\Users\Public\Documents\National Instruments\MStudioVS2012\DotNET\Examples | Installation InstructionsDownload the System Configuration installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager. Updated LabVIEW Compatibility PolicyThe "System Configuration Support for LabVIEW" package supports applications using System Configuration with LabVIEW 2022 Q3 or later. When installing System Configuration, this package will be recommended if you have already installed LabVIEW 2022 Q3 or later and installs to the LVAddons directory. LVAddons directory location: C:\Program Files\NI\LVAddons Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. New Web-Based Configuration and Monitoring Features- Added Application Web Server configuration
- Added Web Service publishing
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. Unsupported Windows Operating SystemsSystem Configuration no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport. NI No Longer Supports Phar Lap ETS Real-Time Operating SystemNI Software no longer supports Phar Lap ETS Real-Time Operating System. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi. Legal InformationCopyright © 2010–2023 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. |
