查看: 547|回复: 0
[MVTEC] MVTEC Halcon 18.11.4.0 Runtime 64位Linux系统运行时版本
    昨天 08:45
  • 签到天数: 3641 天
     楼主| 发表于 2024-11-1 10:39:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    HALCON 18.11.4.0 Linux Runtime运行版 (x64-linux)
    文件名: halcon-18.11.4.0-linux-runtime.tar.gz
    文件大小: 168717677 字节 (160.90 MB)
    修改日期: 2021-12-03 00:07
    MD5: 449ee018de24ccf2c5b493a67ac430b5
    SHA1: 76362c3d0e5dadc31e860bec4d8e2e8af025bc77
    SHA256: 2c252f4662fc2ea332dfc818e6be96db40957bfa196345765fcc36487ae79cbe
    CRC32: 7e309b94
    百度网盘下载地址:
    通过百度网盘分享的文件:halcon-18.11.4.0-linux-runtime.tar.gz
    链接:https://pan.baidu.com/s/1lvKuRkqrYSPTyyMWAb4DeQ
    --来自百度网盘超级会员V7的分享
    Release Notes for HALCON 18.11.4 Steady
    This document provides the release notes for MVTec HALCON 18.11.4.0 Steady, as released in December 2021.
    HALCON 18.11.4.0 Steady is primarily a maintenance release that fixes all known bugs in HALCON 18.11.3; besides, it provides added functionality.
    Contents
    • Compatibility
      • Licenses
      • HALCON Library
      • HALCON Applications
      • Digital I/O Interfaces
      • Extension Packages
    • Supported Operating Systems
    • Detailed Description of Changes in HALCON 18.11.4.0 Steady
      • HDevelop
        • Bug Fixes
      • HDevEngine
        • Bug Fixes
      • HALCON Library
        • New Functionality
        • Bug Fixes
      • HALCON/C++
      • HALCON/.NET
      • HBench
      • Documentation
      • Installation
    CompatibilityLicenses
    HALCON 18.11 Steady licenses are also valid for HALCON 18.11.4.0 Steady. In contrast, all HALCON 13.0 licenses or licenses of earlier versions must be replaced or upgraded. Please contact your local distributor.
    HALCON Library
    HALCON 18.11.4.0 Steady is fully compatible with HALCON 18.11 Steady, HALCON 18.11.2, and HALCON 18.11.3 except for the changed behavior of some operators owing to bug fixes. Compared to HALCON 13.0, many extensions have been introduced. Thus, the HALCON 18.11 Steady libraries are not compatible with HALCON 13.0 or earlier versions.
    In detail, please note the following incompatibility with respect to HALCON 18.11.3 :
    • Due to changes in merging scanlines, find_bar_code might return different results if the barcode parameter 'merge_scanlines' is set to 'true'. More information.
    • The orientation returned by text_line_orientation can differ slightly from previous results. More information.
    HALCON Applications
    Applications (i.e., executables) developed with HALCON 18.11 Steady, HALCON 18.11.2, or HALCON 18.11.3 can be used with HALCON 18.11.4.0 Steady, i.e., HALCON 18.11.4.0 Steady is binary compatible with HALCON 18.11 Steady, HALCON 18.11.2, and HALCON 18.11.3.
    All programs (C, C++ or .NET) that have been developed with HALCON 13.0 must be recompiled. The incompatibility with HALCON 13.0 or earlier versions mainly concerns the binaries, with only few changes in the language interfaces. If you encounter problems during recompiling your programs, please check the detailed description of changes below and for HALCON 18.11 Steady, HALCON 18.11.2, and HALCON 18.11.3, respectively.
    Please note that applications using HALCON/.NET (and HDevEngine/.NET) have local copies of the corresponding assemblies (halcondotnet.dll etc.). After installing HALCON 18.11.4.0 Steady, these applications would therefore use the old version of the HALCON/.NET interface together with the new version of the HALCON library. In order to benefit from the bug fixes in the HALCON/.NET interface as well, you must either replace the assemblies manually or recompile the projects. If you do not recompile the application, you need to add an application configuration file mapping the application's expected assembly version to the new version. See the Programmer's Guide for more information.
    In general, image acquisition interfaces of HALCON 18.11.4.0 Steady are library compatible to those of HALCON 18.11 Steady, HALCON 18.11.2, and HALCON 18.11.3, as well as HALCON 13.0.x.
    HALCON 18.11.4.0 Steady includes only a subset of available image acquisition interfaces. Image acquisition interfaces that are included are: BitFlow, DirectFile, DirectShow, Ensenso-NxLib, File, GenICamTL, GigEVision2, GStreamer, LinX, MILLite, MultiCam, O3D3xx, pylon, SaperaLT, SICK-3DCamera, SiliconSoftware, uEye, USB3Vision, and Video4Linux2. You can download additional interfaces from our web server.
    In general, digital I/O interfaces of HALCON 18.11.4.0 Steady are library compatible to those of HALCON 18.11 Steady, HALCON 18.11.2, and HALCON 18.11.3, as well as HALCON 13.0.x.
    HALCON 18.11.4.0 Steady includes only a subset of available digital I/O interfaces. Digital I/O interfaces that are included are: Linux-GPIO, OPC_UA, and Hilscher-cifX. You can download additional interfaces from our web server.
    Extension Packages
    Extension packages developed with HALCON 18.11 Steady, HALCON 18.11.2, or HALCON 18.11.3 can be used with HALCON 18.11.4.0 Steady without further action. Extension packages developed with HALCON 13.0 or earlier versions must be re-generated. Note that the old makefiles for HALCON/C++ must be adapted according to the sample makefile under extension_packages/halconuser.
    With HALCON 20.11, the x86-win32 platform version for Windows was discontinued. Switch any existing x86-win32 applications to the x64-win64 platform version for Windows to be able to use HALCON 20.11 or later.
    HALCON 18.11.4.0 Steady has been compiled for the following Windows platform versions:
    • x86-win32 platform version for Windows 7/8.1/10 or Windows Server 2008 R2/2012 R2/2016/2019 on Intel Pentium 4 or AMD Athlon 64 with SSE2
    • x64-win64 platform version for Windows 7/8.1/10/11 or Windows Server 2008 R2/2012 R2/2016/2019/2022 x64 Edition on Intel 64 or AMD 64 processors
    The setup process checks whether it is running on a 32- or 64-bit system and provides a suitable list of platform versions that can be installed. During the installation, the environment variable HALCONARCH is set to x86sse2-win32 or x64-win64 to indicate the installed platform version. Please note that if you want to switch to another platform version, you must first install it. Then, you must adapt the environment variable HALCONARCH (see the Installation Guide for more information).
    Linux
    HALCON 18.11.4.0 Steady has been compiled for the following Linux platform versions:
    • x64 platform version for Linux x86_64, GLIBC_2.17, GLIBCXX_3.4.15, on Intel 64 or AMD 64 processors
    • armv7a platform version for Linux armv7a, Kernel with hidraw support, hard-float ABI, GLIBC_2.7, GLIBCXX_3.4.15 on Armv7-A processors with NEON support
    • aarch64 platform version for Linux aarch64, Kernel with hidraw support, GLIBC_2.17, GLIBCXX_3.4.20 on AArch64 processors
    macOS
    HALCON 18.11.4.0 Steady has been compiled for the x64 platform version of macOS 10.13/10.14/10.15 on Intel 64.
    The changes in HALCON 18.11.4.0 Steady are described with respect to HALCON 18.11.3 .
    HDevelopBug FixesAssistants
    • Deleting individual calibration images in the Calibration Assistant, followed by adding new images could yield incorrect calibration results as not all images were used in the calibration process. This problem has been fixed.
    Code Export
    GUI
    • HDevelop crashed when either a zoom window received keyboard input or the content of a zoom window was moved by dragging. This problem has been fixed.
    • In certain cases, HDevelop's autocompletion obscured the line that was currently being edited. This happened if a procedure was running in a subthread during editing. This problem has been fixed.
    • Double-clicking in the HDevelop graphics window could result in incorrect coordinates when using interactive operators like get_mposition. This problem has been fixed.
    • HDevelop could crash when using the magnify mode in a graphics window. This problem has been fixed.
    IDE
    Miscellaneous
    HDevEngineBug Fixes
    • Failing to initialize a vector output parameter of a procedure caused the return values for all subsequent output parameters to be ignored as well if the call was made using par_start. This problem has been fixed.
    • Initializing HDevEngine in a multi-threaded context could cause a crash in rare cases. This problem has been fixed.
    Data Code
    Bug Fixes3D
    • Some files in the binary PLY format could not be read by read_object_model_3d. This problem has been fixed.
    • When using find_surface_model with 'ReturnResultHandle' set to 'true', a memory leak occurred. This problem has been fixed.
    • triangulate_object_model_3d with 'Method' set to 'greedy' crashed in very rare cases. This problem has been fixed.
    • binocular_disparity, binocular_distance, and reconstruct_surface_stereo for a stereo model with 'disparity_method' set to the default 'binocular' may have crashed in rare cases when applied to large images. This problem has been fixed.
    • pose_compose, pose_invert, serialize_pose, write_pose, set_metrology_model_param, create_calib_descriptor_model, create_planar_calib_deformable_model, create_planar_calib_deformable_model_xld, refine_surface_model_pose, refine_surface_model_pose_image, and set_surface_model_param did not raise an error when an input pose contained an invalid pose type in its last entry. This problem has been fixed. Now, the operators return the error 8427 ("Wrong type in Pose (rotation / translation)").
    • segment_object_model_3d could crash if the input 3D object model contained triangles that were topologically invalid. This problem has been fixed. Now, the operator returns an error when encountering such a topology.
    • simplify_object_model_3d in rare cases generated meshes that subsequently could not be segmented by segment_object_model_3d but raised an error. This problem has been fixed.
    • disp_object_model_3d, display_scene_3d, and render_object_model_3d in rare cases might have crashed for ObjectModel3D containing primitives not of type plane. get_object_model_3d_params with GenParamName set to 'has_primitive_rms' or 'primitive_rms' in rare cases did not work correctly for primitives of type plane. These problems have been fixed.
    • set_scene_3d_instance_param did not work correctly if (unrelated) instances had been removed from the scene before. This problem has been fixed. Note that this change affects the compatibility. Read more.
    Bar Code
    • When in training mode, find_bar_code sometimes returned results that could not be decoded with the trained parameter afterwards. This problem has been fixed.
    • In very rare cases, find_bar_code could have caused a deadlock if the barcode parameter 'merge_scanlines' was set to 'true'. This problem has been fixed. Note that this change affects the compatibility. Read more.
    • In find_bar_code, the training of the parameter 'barcode_width_min' could lead to wrong results when training multiple different images. This problem has been fixed.
    • In rare cases, find_bar_code could misread certain GS1 Databar Limited barcodes, resulting in a slightly wrong symbol region and an incorrectly decoded string. This problem has been fixed.
    • For Pharmacodes with 16 bars, get_bar_code_result always returned the 'Decode' grade 0 ('quality_isoiec15416'). This problem has been fixed.
    Calibration
    • merge_regions_line_scan may have crashed in rare cases with empty output regions. This problem has been fixed.
    Classification
    • add_sample_class_train_data wrongly handled mixed float and integer values inside the parameter 'Features'. This problem has been fixed.
    Color Processing
    Compute Device
    • When used with large images of more than two gigapixels, some OpenCL operations (arithmetic image operations like abs_diff_image) were very slow or returned an error. This problem has been fixed.
    Data Code
    • For mirrored Data Matrix ECC 200 codes with a square shape, get_data_code_2d_objects returned wrong results for 'module_1_rois' and 'module_0_rois' in some cases. Additionally, get_data_code_2d_results returned wrong results for 'bin_module_data' for the same cases. These problems have been fixed.
    • In very rare cases, find_data_code_2d showed non-deterministic behavior if the Data Matrix ECC 200 code was located very close to the image borders. This problem has been fixed.
    • find_data_code_2d in rare cases could not find and decode mirrored Data Matrix ECC 200 codes if the parameter 'mirrored' was set to 'yes' but could if it was set to 'any'. This problem has been fixed.
    • For mirrored Data Matrix ECC 200 codes with a square shape and multiple data fields, get_data_code_2d_objects returned wrong results for 'module_1_rois' and 'module_0_rois' in some cases. This problem has been fixed.
    • HALCON did not cope well with QR codes encoded in local encoding where a single character was split between two decoding modes. This problem has been fixed.
    • get_data_code_2d_objects leaked memory if the process and/or search image for candidates with a process and/or search image on pyramid level -1 was queried. This problem has been fixed.
    Deep Learning
    File
    Filter
    • abs_diff_image with image type 'byte' returned wrong results if the multiplication parameter was larger than 127 and at least one of the available SIMD optimizations (SSE41 or AVX2) were enabled. This problem has been fixed.
    • In rare cases, abs_diff_image returned wrong results for image type 'byte' and 'int1' on all supported platforms. The maximum difference was 1 gray value. This problem has been fixed.
    Graphics
    • get_drawing_object_iconic and get_drawing_object_params were not synchronized with window events. In rare cases, get_drawing_object_iconic thus returned the error 3513 ("Internal error: number of chords too big for num_max"). This problem has been fixed.
    Inspection
    Images
    • threshold in rare cases did not clip 'MinGray' and 'MaxGray' to the correct bounds for 'int4' images. set_grayval in rare cases did not clip 'Grayval' to the correct bounds for 'int8' images. gen_image_proto, paint_region, and overpaint_region in some cases for large values did not paint the correct 'Grayval' for 'int8' images. These problems have been fixed.
    Matching
    Measure
    • In rare cases, fuzzy_measure_pairs crashed with cyclic measure objects (i.e., spanning 360 degrees) if no edges were found. This problem has been fixed.
    Morphology
    • gray_range_rect crashed in rare cases if operator parallelization was disabled. This problem has been fixed.
    OCR
    • In multi-threading applications, HALCON could crash during the execution of do_ocr_word_cnn, do_ocr_word_mlp, do_ocr_word_svm, or do_ocr_word_knn. This problem has been fixed.
    • In some cases, text_line_orientation used uninitialized values outside of the input region, which led to inaccurate results. This problem has been fixed. Note that this change affects the compatibility. Read more.
    • In some cases, find_text returned overlapping or duplicate regions when using text models created with mode 'auto'. This problem has been fixed.
    Region
    • rectangularity, as well as region_features and select_shape for the feature 'rectangularity', sometimes unnecessarily ran out of memory for very large regions. This problem has been fixed.
    Segmentation
    • The operators watersheds and watersheds_threshold did not always return the correct watersheds when passing an image of type 'real' with a reduced domain. This problem has been fixed.
    System
    • In rare cases, HALCON could crash when resetting a program in HDevelop with F2 while a mutex or another synchronization object was destructed. This problem has been fixed.
    Transformation
    • In rare cases, projective_trans_image_size could have crashed or resulted in undefined behavior. This problem has been fixed.
    Tuple
    • When calling the operators get_handle_tuple, get_handle_object, or get_handle_param simultaneously from two different threads for the first time, HALCON could return an incorrect error code or in crash in rare cases. This problem has been fixed.
    • Serializing the same dictionary or message either through write_dict, write_message, or serialize_handle from multiple threads at the same time could lead to incorrect serializations, error messages or, in rare cases, crashes. This problem has been fixed. The serialization of dictionaries and handles is now fully reentrant.
    • When calling integer_to_handle with multiple input integers and if some of those integers did not represent a handle or represented a cleared handle, the operator could leave the other handles in a defective state. This problem has been fixed.
    • If the handle legacy mode was enabled and either clear_handle was called twice on the same handle, or handle_to_integer was called on an already cleared handle, HALCON could show undefined behavior and crash in rare cases. These problems have been fixed. handle_to_integer now raises an exception when called on an already cleared handle.
    XLD
    • When connecting both ends of two contours to each other, union_cotangential_contours_xld sometimes connected the wrong endpoints. This problem has been fixed.
    • gen_cube_map_mosaic and gen_spherical_mosaic may have crashed in rare cases. This problem has been fixed.
    • Certain excessively large values of 'Lookaround' for get_contour_angle_xld were not detected as invalid, resulting in a crash. This problem has been fixed.
    • gen_contour_nurbs_xld crashed if an empty tuple was passed to the parameter 'Weights'. This problem has been fixed. Now, if an empty tuple is passed, the default value 'auto' is used.
    • union_collinear_contours_xld did not unite almost collinear contours for large values of 'MaxAngle' in rare cases. This problem has been fixed.
    HALCON/C++Functionality
    HALCON/.NETFunctionality
    HBenchBug Fixes
    Miscellaneous
    • GStreamer Image Acquisition Interface was not listed when requesting the parameter 'Name' of the operator info_framegrabber or open_framegrabber via the operator get_param_info.
      Linux-GPIO I/O Interface was not listed when requesting the parameter 'IOInterfaceName' of the operator control_io_interface, open_io_device, or query_io_interface via the operator get_param_info. These problems have been fixed.
    • The MVTec GigE Vision Streaming Filter version 2.2.8.4, which is part of the Windows installer, fixes two problems:
      • With the streaming filter, EventTransferEnd was only fired for successfully received blocks but not for undeliverable ones.
      • In rare cases, if an application did not shutdown gracefully while streaming was underway, automatic unloading of the streaming filter could lead to a crash of the operating system.
    Miscellaneous
    • The documentation did not mention that HALCON Variable Inspect cannot inspect objects located in GPU but only those in CPU memory. The Programmer's Guide has been updated accordingly.
    User Guides
    • The list of reserved words in the HDevelop User's Guide was not complete. This problem has been fixed.
    Solution Guides
    Reference Manual
    • The reference manual entries of add_scene_3d_camera, disp_object_model_3d, object_model_3d_to_xyz, and project_object_model_3d now explain more about using camera distortion on faces and primitives.
    Miscellaneous
    • The Installation Guide mentioned Visual Studio support up to version 2017. This has been extended to include version 2019 as well.
    Installation
    GMT+8, 2025-9-4 03:27
