查看: 733|回复: 0
[Cognex] 康耐视Cognex IN-SIGHT 1700 PATCH RELEASE - 2.71 PR1
    昨天 08:45
  • 签到天数: 3641 天
     楼主| 发表于 2024-11-12 08:49:40 | 显示全部楼层 |阅读模式 来自:广东省深圳市 电信
    Executive Summary - Contains the documentation, PC Host, and upgrade files for In-Sight 1700 1701 patch release 2.71 PR1. This is not a general release. Users who don't require the features below do not need to upgrade their system. New Features and Changes: The default behavior of Telnet sessions has been updated to prevent half open sessions from using all three available sessions. If an Admin or Operator Level Telnet session is open, then an Admin or Operator Level browser interface session is opened, the browser interface Access is no longer Locked. If an Admin or Operator Level Telnet session is open, then an Admin or Operator Level browser interface session is refreshed or the user clicks on System from the Option tab or FTP from the File tab, the browser interface Access is no longer Locked. The Get Connections Native Mode command now returns an additional hexadecimal representation to indicate if a user is logged on using a Java applet connection. The Java applet hexadecimal value is 0x80. Previously, the Get Connections command only returned each user's FTP Read/Write permissions and Access Level. (CR# 37805) The Time To Live (TTL) field within the Internet Protocol portion of a multicast packet (as used by EtherNet/IP) is now set to 1. (CR# 37247) The Native Mode command, ReadConfig, now returns the correct XML output. (CR# 37179) The Native Mode command, GetConfigResult, now returns the correct XML output. (CR# 36970) / /
    文件类型: exe
    文件大小: 13.3MB
    版本: 1
    发布日期: 2006/9/21
    文件名: In-Sight_2_71_00_PR1_1700.exe
    文件大小: 14293012 字节 (13.63 MB)
    修改日期: 2022-07-26 16:17
    MD5: ccf91e83ff3923f2519534a87d56817e
    SHA1: 608157afab564ca9dde535492fbb2d32ad6285ba
    SHA256: 1db2eec3b3be6fd8a2e9ef909a5673663ed2c66eb21c81eddf70b0cfbc377c2f
    CRC32: 769be361
    康耐视官方下载:
    通过百度网盘分享的文件:In-Sight_2_71_00_PR1_1700.exe
    链接:https://pan.baidu.com/s/18dP2j-1nrwIVQm5iBVw2vQ
    --来自百度网盘超级会员V7的分享
    GMT+8, 2025-9-4 06:05
