查看: 626|回复: 0
[Cognex] 康耐视Cognex IN-SIGHT PATCH RELEASE 3.4.1 PR1 FOR 1720 SERIES WAFER READERS (FOR JAVA INSTALLATIONS)
    昨天 08:45
  • 签到天数: 3641 天
     楼主| 发表于 2024-11-13 15:33:43 | 显示全部楼层 |阅读模式 来自:广东省深圳市 电信
    Download this file if you are using the Javagraphical interface. Patch Release 3.4.1 PR1 provides a critical fix for In-Sight 1720 Series wafer readers currently running 3.4.0 or 3.4.1 firmware. This fix prevents the improper access and erasure of non-volatile flash memory that can occur after an image acquisition, which could render the reader inoperable. All 1720, 1721, and 1721 readers currentlyrunning 3.4.0 or 3.4.1 should be upgraded to 3.4.1 PR1 to prevent this failure from occuring. Release 3.4.1 should be uninstalled before installing patch release 3.4.1 PR1. also providesthe critical fix described above, with additional changes and fixes not included in 3.4.1 PR1. L
    文件类型: exe
    文件大小: 23.4MB
    版本: 3.4.1 PR1
    发布日期: 2008/4/22
    文件名: InSightWaferID_341PR1_J.exe
    文件大小: 24515056 字节 (23.38 MB)
    修改日期: 2021-02-14 23:04
    版本: 11.0.0.28844
    MD5: c4551b390f5cca8f1308439cc71dd233
    SHA1: 284b24959ddec20c999586f7d59084cfeb7733b8
    SHA256: 084c217103345d259f2035af021501d120b2e9cf0da4bac6573e8b63cbc46929
    CRC32: 7687f7e2
    康耐视官方下载:
    通过百度网盘分享的文件:InSightWaferID_341PR1_J.exe
    链接:https://pan.baidu.com/s/19_p5Hh-pPnHFJOsCOnS6wA
    --来自百度网盘超级会员V7的分享
    GMT+8, 2025-9-4 06:08
