查看: 628|回复: 0
[Cognex] 康耐视Cognex IN-SIGHT 3.4.4 FOR 1720 SERIES WAFER READERS (FOR .NET INSTALLATIONS)
    昨天 08:45
  • 签到天数: 3641 天
     楼主| 发表于 2024-11-13 15:37:30 | 显示全部楼层 |阅读模式 来自:广东省深圳市 电信
    Download this file if youare using the .NET graphical interface and have already installed the Microsoft .NET Framework on your PC. Release 3.4.4 provides a critical fix for In-Sight 1720 Series wafer readers currently running 3.4.0 or 3.4.1 firmware. This fix prevents the improper access and erasure of non-volatile flash memory that can occur after an image acquisition, which could render the reader inoperable. All 1720, 1721, and 1721 readers currentlyrunning 3.4.0 or 3.4.1 firmware shouldbe upgraded to 3.4.4 toprevent this failure from occuring. P dir=ltr NOTE :1720 Series readers running 3.4.0 or 3.4.1 firmware canalso beupgraded to patch release 3.4.1 PR1, which provides only the critical fix described above. Customers whocontinue to usethe Java graphical interface must upgrade using 3.4.1 PR1 because release 3.4.4 does not support Java. Release 3.4.4also p rovidesadditional changes and fixes that are not containedin 3.4.1 PR1, including: TheOnline/Offline state of the .NET user interface is always synchronized with the actual Online/Offline state of the reader. After a no-read occurs, the imagefrom the highest scoring Configis automatically displayed and/or saved. TheLight Power control in the graphical interface is now a horizontal scroll bar. The SetConfigEnable Native Mode command enables and disables multiple Configs simultaneously. Error handling has been improved when logging on to a reader running older 3.2.x firmware from the 3.4.4 user interface, READ and TUNE commands work correctly forConfigs 10 - 24. L
    文件类型: exe
    文件大小: 50.9MB
    版本: 3.4.4
    发布日期: 2008/4/22
    文件名: InSightWaferID_344.exe
    文件大小: 53424112 字节 (50.95 MB)
    修改日期: 2021-02-14 23:04
    版本: 11.0.0.28844
    MD5: a94e08ffb697dafcc3708eba5268a2c5
    SHA1: ad36540f66fcf732ca53d0c1af82910f000e04cd
    SHA256: 2ff1b040d0e18b574c811903b41b66e58725e7880c0355c54d7027497b3a4cdc
    CRC32: 74845da2
    康耐视官方下载:
    通过百度网盘分享的文件:InSightWaferID_344.exe
    链接:https://pan.baidu.com/s/1BPqbJ4rUFcibAhYwm9cpdg
    --来自百度网盘超级会员V7的分享
    GMT+8, 2025-9-4 06:05
