查看: 664|回复: 0
[Cognex] 康耐视Cognex IN-SIGHT 3.4.4 FOR 1720 SERIES WAFER READERS (FULL CD INSTALL)
    昨天 08:45
  • 签到天数: 3641 天
     楼主| 发表于 2024-11-13 16:53:59 | 显示全部楼层 |阅读模式 来自:广东省深圳市 电信
    Release 3.4.4 provides a critical fix for In-Sight 1720 Series wafer readers currently running 3.4.0 or 3.4.1 firmware. This fix prevents the improper access and erasure of non-volatile flash memory that can occur after an image acquisition, which could render the reader inoperable. All 1720, 1721, and 1721 readers currently running 3.4.0 or 3.4.1 firmware should be upgraded to 3.4.4 to prevent this failure from occuring. 720 Series readers running 3.4.0 or 3.4.1 firmware can also be upgraded to patch release 3.4.1 PR1, which provides only the critical fix described above. Customers who continue to use the Java graphical interface must upgrade using 3.4.1 PR1 because release 3.4.4 does not support Java. EM Release 3.4.4& also p rovides& additional changes and fixes that are not contained& in 3.4.1 PR1, including: the Online/Offline state of the .NET user interface is always synchronized with the actual Online/Offline state of the reader. After a no-read occurs, the image& from the highest scoring Config& is automatically displayed and/or saved. the Light Power control in the graphical interface is now a horizontal scroll bar. The SetConfigEnable Native Mode command enables and disables multiple Configs simultaneously. Error handling has been improved when logging on to a reader running older 3.2.x firmware from the 3.4.4 user interface, READ and TUNE commands work correctly f Configs 10 - 24.
    文件类型: zip
    文件大小: 181.2MB
    版本: 3.4.4
    发布日期: 2008/4/23
    文件名: InSight344WaferID.zip
    文件大小: 190006232 字节 (181.20 MB)
    修改日期: 2021-02-14 23:04
    MD5: bc4eb6351c79a68d84bf1d73364fee65
    SHA1: 2e35016f1113b8a581879916b7f3152c3625a15d
    SHA256: a0452ac832b5aaa5e1c0929be8d9d19484dba94d21e0db494265e4e10b09cdad
    CRC32: af8d20d6
    康耐视官方下载:
    通过百度网盘分享的文件:InSight344WaferID.zip
    链接:https://pan.baidu.com/s/1A4lTBvc2g8DrhrSof0kVBw
    --来自百度网盘超级会员V7的分享
    GMT+8, 2025-9-4 06:07
