查看: 1042|回复: 0
[Cognex] 康耐视Cognex IN-SIGHT TRACK & TRACE 1.0.1 PATCH RELEASE 2
    昨天 08:45
  • 签到天数: 3641 天
     楼主| 发表于 2024-11-19 11:06:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    The Track & Trace 1.0.1 Patch Release 2 (PR2) fixes a few minor issues discovered in the Track & Trace 1.0.1 RTM release and in the 1.0.1 Patch Release 1 (PR1): • ID CODE 1 and ID CODE 2 are no longer trained by default (CR 69108). Previously, the Track & Trace job was saved with the ID codes in a trained state, requiring the user to switch the Code Type and then switch it again to Data Matrix before learning a new code. • Several dialogs in the Track & Trace job have been adjusted in order to prevent the need for horizontal scrolling when using VisionView 700 or VisionView VGA (CR 69109). • The amount of time it takes to load the Track & Trace job using the Cognex HMI Display Control has been reduced by nearly 4 seconds (CR 69226). • The Cognex HMI Display Control now references the correct In-Sight DLL (CR 69380). In Track & Trace 1.0.1 PR1 an “Invalid AutoConnectString” error message would occur when trying to connect to an In-Sight system using the Cognex HMI Display Control. After running the Cognex In-Sight Track & Trace 1.0.1 PR2 installer, an updated Track_Trace_Single.job file (build 2434, as indicated in cell Z0) and several files used by the Cognex HMI Display Control will be copied to your PC. NOTE: • In-Sight Track & Trace 1.0.1 RTM and Track & Trace 1.0.1 PR1 must be installed before installing 1.0.1 PR2. • Applications created and compiled against Track & Trace 1.0.1 (or 1.0.1 RTM with 1.0.1 PR1) using Cognex.InSight.dll or Cognex.Cnx.InSight.dll must be recompiled using the files included in 1.0.1 PR2.
    文件类型: zip
    文件大小: 1.8MB
    版本: 1.0.1 PR2
    发布日期: 2010/10/14
    文件名: Cognex In-Sight Track & Trace 1.0.1 PR2.zip
    文件大小: 1851490 字节 (1.77 MB)
    修改日期: 2021-02-14 23:19
    MD5: b8aada6c6cd31e35a105047925e72da5
    SHA1: fa2b36a8c284e4fb9091a098f6389eab2e7ca0e0
    SHA256: 408fdad3ff9eafc9082cb6e2219d825158ae98b718cba752562ca83896ba1b3e
    CRC32: 7081273a
    康耐视官方下载:
    通过百度网盘分享的文件:Cognex In-Sight Track & Trace 1.0.1...
    链接:https://pan.baidu.com/s/1A9q1ikYROBslXS20J-NOrg
    --来自百度网盘超级会员V7的分享
    GMT+8, 2025-9-4 04:25
