查看: 599|回复: 0
[Cognex] 康耐视Cognex IN-SIGHT OPC SERVER 5.3
    昨天 08:45
  • 签到天数: 3641 天
     楼主| 发表于 2024-11-22 14:18:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Installer for In-Sight OPC Server 5.3.0
    You must disable User Account Control (UAC) before installing the In-Sight OPC Server. For instructions on how to disable UAC, do the following:
    Windows 7/Windows Sever 2008 R2
    Click Start > Help and Support.
    In the search box, type: Turn off UAC
    Press ENTER.
    View the first search result topic entitled "Turn User Account Control on or off".
    Windows 10
    You must disable UAC from Registry Editor by manually changing the value.
    Note: Disabling UAC from the Control Panel (User Accounts) will not allow you to install the In-Sight OPC Server on Windows 10.
    Press the Windows key + R on your keyboard. The Run dialog opens.
    Type regedit and click OK. Registry Editor opens.
    Select HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > Current Version > Policies > System.
    Right-click on EnableLUA, and select Modify. The Edit DWORD Value dialog opens.
    Change the Value data to 0.
    Click OK to close the dialog.
    Restart your PC. Now you can install the In-Sight OPC Server.
    After installation, you may re-enable UAC; however, in order to uninstall the In-Sight OPC Server you will need to disable it temporarily again.
    文件类型: .exe
    文件大小: 31.0MB
    版本: 5.3.0
    发布日期: 2016/11/1
    文件名: Cognex In-Sight OPC Server 5.3.0.exe
    文件大小: 32543024 字节 (31.04 MB)
    修改日期: 2021-02-14 23:05
    版本: 5.3.860.0
    MD5: d87601cee8770f9582b013a123ea9e9d
    SHA1: 6c2d5a5430b8aac5e97f04af08e913e4a565d4c8
    SHA256: fdfca1f180aa1bd159ca2640c9d92c1667810a798f1f6477dcc2f1f985397fef
    CRC32: 3ca11d99
    康耐视官方下载:
    通过百度网盘分享的文件:Cognex In-Sight OPC Server 5.3.0.exe
    链接:https://pan.baidu.com/s/1FxuGtcV7YoA-wHz-2h0FPw
    --来自百度网盘超级会员V7的分享
    GMT+8, 2025-9-4 07:05
