TA的每日心情 | 怒 6 小时前 |
签到天数: 3804 天 连续签到: 1 天 [LV.Master]2000FPS
楼主 |
发表于 2024-11-28 11:23:04
来自:广东省东莞市 电信
瑷荔德Allied Vision Tech(AVT) 工业相机驱动和二次开发包Vimba_v5.1_ARM64 The SDK for AVT cameras
文件名: Vimba_v5.1_ARM64.tgz
文件大小: 53021211 字节 (50.56 MB)
修改日期: 2024-10-25 10:51
MD5: 4c148caf57ee43a9c9a41d531ab78fe7
SHA1: 20f5931e226d25d0ede406081441e5ef70f61018
SHA256: 6905dc6e178acabc1a4e854fbc6437c8c27a40be2a4364ff47958fc40a7da6f2
CRC32: 64213b14
AVT官方下载:
链接:https://pan.baidu.com/s/1j_THrla2h557TAdPSw9JSw
Changes in Vimba 5.1.0:
VimbaC
- New feature: Support for Alloc And Announce frame allocation mode
- Feature endianess related fixes (corresponding to GigE TL)
VimbaCPP
- New feature: Supports Alloc And Announce frame allocation mode
VimbaNET
- New target framework version: .NET 4.7.2
VimbaPython
Vimba Viewer
- Supports Alloc And Announce frame allocation mode
- Chinese localization
- Supports changes of GigE TL and VimbaC
- Fixed: IP labels not updated after changing the IP via GevCameraForceAddressSend
- Fixed: Auto ROI tab always resets ROI at startup
Firmware Updater
- Supports Git hash representation
Firmware Updater Console
GigETL
- Changed behaviour of endianess handling (values must match host endianness in little-endian),
for better compatibility with third-party software.
Affected features that now have a changed byte order:
- Config Mode
- IP-related features including MulticastIPAddress
- Action Commands
- New feature DeviceUpdateTimeout (only applicable if GigE discovery is switched to Broadcast)
- New GVSPMaxLookBack default value (0 instead of 1) for improved packet resend handling
- Fixed: High memory usage during performance bottleneck (Nonpaged pool growing with multiple GigE cameras)
- Fixed: Action commands caused an error message in the console log
- Fixed: Multicast IP address range, better compatibility with third-party software
GigE Filter Driver
- Reduced memory allocations
- Hidden statistics
USB TL
- Fixed: Reset cameras streaming state when opened (Endpoint Halt)
- Updated 3rd-party libraries |
