查看: 731|回复: 0
[驱动] 宝视纳Basler-pylon 7.3.0相机软件套装Linux x86 (64位)- Debian安装软件包~pylon_7.3.0.27189_linux-x86_64_debs
    4 小时前
  • 签到天数: 3724 天
    连续签到: 51 天
     楼主| 发表于 2024-11-29 18:13:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    pylon 7.3.0相机软件套装Linux x86(64位)- Debian安装软件包
    文件名: pylon_7.3.0.27189_linux-x86_64_debs.tar.gz
    文件大小: 314658361 字节 (300.08 MB)
    修改日期: 2024-03-12 21:51
    MD5: 3283b00a48071b19f246d27af280b67d
    SHA1: 4d68f53b90662903f8d0c269f4fd70223efabd20
    SHA256: df45bcd80f5a9529271214d7ec308fe69f921c1acf8eccd647c936377f892fa0
    CRC32: 4faab544
    Basler官方下载:
    链接:https://pan.baidu.com/s/1DzO5ZBV6bGukMrJkD6QA_w
    pylon 7 Camera Software Suite for Linux
    RELEASE NOTES
    Note: Patch versions of pylon for Linux OS are not released publicly.
    RELEASE DATE:       2023-04-26
    VERSION:            7.3.0 (x86_64, aarch64)
    BINARY COMPATIBILITY
    * pylon C++ API = 7.3.0: Applications built with earlier versions of the pylon C++
      API are incompatible.
    * pylon C API = 7.3.0: Applications built with earlier versions of the pylon C API
      are incompatible.
    * pylon Data Processing API = 1.2.0: Applications built with earlier versions of
      the pylon Data Processing API are incompatible.
    NEW FEATURES / CHANGES
    * CXP: [240824] Added support for Basler boost quad-channel CoaXPress cameras with
           GMAX sensors. These cameras are for use with the Basler CXP-12 Interface Card 4C
           or imaWorx CXP-12 Quad acquisition cards, which require a host interface
           with PCIe Gen 3 x8 (Direct Memory Access) or better.
    * CXP/GenTL: [246795] The CXP GenTL Producer, ProducerCXP.cti, has been updated to
                 version 5.11. It supports the EVENT_NUM_IN_QUEUE event info now.
    * CXP: [246795] The applet for Basler CXP-12 Interface Card 1C with static version
           S1.2 has been updated to version 5.0.5.
    * CXP: [246795] The applets for Basler CXP-12 Interface Card 2C, 4C, and imaWorx
           CXP-12 Quad with static version S1.0 have been updated to version 2.1.6. The
           internal applet structures have been updated for a better overflow and memory
           bandwidth handling.
    * vTools: The following licensable vTools have been added:
              - Barcode Reader Starter
              - Data Matrix Code Reader Starter
              - QR Code Reader Starter
              - Template Matching Starter
              - Image Alignment
              - ROI Creator
              - Image Smoothing Basic
              - Image Morphology Basic
              - Gray Value Transformer Basic
              - Image Combiner Basic
              - Line Measurements Pro
              - Circle Measurements Pro
              - Ellipse Measurements Pro
              - Rectangle Measurements Pro
    * vTools: The functionality of the following vTools has been extended. They now provide
              alignment transformation data (via the AlignmentTf output pin). This can be
              used for aligning images using the Image Alignment vTool:
              - Template Matching Basic
              - Geometric Pattern Matching Basic
              - Geometric Pattern Matching Pro
    * vTools: The following vTools accept inverse transformation data (via the InverseTf input pin)
              from the Image Alignment vTool to provide real world coordinates:
              - Measurements Basic
    * vTools: The following vTools accept a region of interest (ROI) as input to restrict
              the image area processed:
              - Barcode Reader Basic
              - QR Code Reader Basic
              - Data Matrix Code Reader Basic
              - Absolute Thresholding Basic
              - Auto Thresholding Basic
              - Relative Thresholding Basic
              - Color Classifier Basic
              - Barcode Reader Pro
              - Data Matrix Code Reader Pro
              - QR Code Reader Pro
    * vTools: [8589, 8945] For Region Selection, Absolute Thresholding Basic, and
              Relative Thresholding Basic, the behavior of range sliders and value handling
              has been improved.
    * vTools: [10341] For Region Morphology, mask sizes can only be entered in increments of
              x.0 and x.5.
    * vTools: [10325] For Region Morphology, the maximum possible mask size has been set to
              1001. Also, only odd mask sizes are allowed now.
    * vTools: [9419] The free Image Loading vTool has been added. It enables loading of images
              from the hard drive.
    * vTools: [10430] Added support for multithreading in the Image Format Converter vTool.
    * vTools - Measurements Basic [11429]: Renamed the "Length" and "Width" parameters to
                                  "Width" and "Height" to be consistent with all other vTools.
                                  In case you have already programmed against these parameters,
                                  you will have to adapt your code accordingly.
    * vTools: [11605] New recipe templates have been added.
    * Data Processing: [9347] Added the CircleF, EllipseF, and LineF data types (as single
                       values and arrays).
    * Data Processing: [8276] Added support for programmatically creating and modifying
                       recipes via the CBuildersRecipe class in the Data Processing SDK.
    * pylon Viewer: [11410] The pylon Camera API Generator tool has been added
                    in the Tools menu of the pylon Viewer. This GUI tool provides
                    functionality to easily create specialized camera classes.
    * pylon Viewer: [9162] The pylon Viewer GUI tools have been updated to Qt 5.15.5.
    * pylon Viewer: [7509] The pylon Static Defect Pixel Correction tool has been
                    localized into Simplified Chinese, Japanese, and Korean.
                    Languages can be switched via the Tools > Options menu.
    * pylon Viewer: [7249] Improved the overall performance of the pylon Viewer.
    * pylon Viewer: The New Features tab in the 'Welcome to pylon' dialog has been updated.
    * Workbench: [11411] Added zooming to the Workbench pane. You can use the zoom buttons and
                 slider in the lower left corner of the Workbench or the mouse wheel + CTRL/CMD key.
    * Workbench: [10167] Increased the size of the context menu of the Workbench pane.
    * pylon: All GUI tools, e.g., pylon Viewer, pylon IP Configurator, etc., have been built
             against Ubuntu 20.04 LTS. Use Ubuntu 20.04 LTS or above to be able to use the
             pylon GUI tools.
    * pylon: [236190, 267192, 264293] The CImageFormatConverter supports multithreding now.
             By default, the CImageFormatConverter uses four threads. Under certain circumstances,
             a further increase of the number of threads may be required. This may reduce
             the latency and improve the performance but may cause higher CPU load. Using
             the CImageFormatConverter with enabled multithreading is recommended when using
             Basler ace 2 5GigE and CoaXPress cameras.
    * SDK: [264292] The Utility_ImageFormatConverter SDK sample has been updated to
           demonstrate the use of multithreading with the CImageFormatConverter.
    * SDK: [256690] The following C++ SDK samples have been updated to support the new boost
           quad-channel CoaXPress cameras:
           - ParametrizeCamera_GenericParameterAccess
           - ParametrizeCamera_NativeParameterAccess
           - GUI_Sample
           - GUI_SampleMultiCam
           - ParametrizeCamera_LoadAndSave
           Note: Other SDK samples may not work due to the different camera feature sets.
    * SDK: [245850, 266733] The pylon SDK samples can be built with CMake now. Use the
           PylonFinder.cmake to do so.
    * SDK: [246793] The CBaslerUniversalInstantCamera class has been updated.
    * Camera Emulation: [247315, 247316] The pylon Camera Emulation has been updated with
                        multiple new parameters to better reflect the behavior of recent
                        Basler cameras, e.g., ace 2 camera models.
    * BPD: [253752] The use of the Static Defect Pixel Correction camera feature when
           used via the pylon API has been documented.
    * BPD: Updated the offline Basler Product Documentation.
    DISCONTINUATION NOTICE
    * Linux Ubuntu 18.04 LTS is no longer supported.
    CORRECTIONS
    * vTools: Measurements Basic:
              - [8947] Fixed the output reset on input image error.
              - Fixed the output in world coordinates.
    * vTools: [9766] All vTools with image editors: The scrolling behavior has been
              improved.
    * vTools: [10676] Barcode Reader Pro: Spaces in the identifier of enum entries have
              been removed.
    * vTools: [8588] Calibration Basic: Fixed trigger of machine calibration in settings
              dialog.
    * Workbench: Fixed a bug which caused the pin data view to not show any data when
                 only a subset of selected vTool pins provided valid data.
    * Data Processing: [11365] Fixed an issue when removing certain vTools.
    * pylon Viewer: Improved support for high-resolution displays.
    * CXP/GenTL: [265133] The GenTL CXP Producer has been improved to better support
                 multithreaded applications.
    * CXP/GenTL: [246795] The behavior after a device removal has been improved.
    * CXP/GenTL: [246795] Fixed an issue with PoCXP not being able to be turned off.
    * CXP/GenTL: [246795] The vantage point is reset and set to unavailable while
                 AutomaticROIControl is active.
    * CXP/GenTL: [246795] SensorHeight and SensorWidth are set to unavailable while
    * CXP/GenTL: [246795] Fixed an issue with FG_HEIGHT and FG_WIDTH not following
                 the camera's SensorHeight and SensorWidth.
    * CXP/GenTL: [265890] The GenTL Consumer returns detailed information in case of
                 image acquisition errors now.
    * GigE: [265902] The error message reported in case of image loss has been updated
            to account for buffer underrun, too.
    * SDK: [266608] An issue with PylonTerminate() after calling EnumerateDevices()
           has been fixed.
    * SDK: [267955] An issue with the Static Defect Pixel Correction feature has been
           fixed.
    * SDK: [255638] Minor general improvements have been made.
    * pylon C: [225060] Some spelling corrections in the pylon C SDK samples have
               been made.
    RESTRICTIONS
    * GigE Vision: [259058] For optimum use of Basler's ace 2 5GigE and 1GigE cameras,
                   Basler recommends using dual-channel DDR4-3600 RAM or better.
                   Using slower RAM may cause buffer underruns and image loss.
                   In addition, Basler recommends using the pylon GigE Configurator
                   tool to optimize the complete setup.
    * CXP: The Basler CXP-12 Interface Card 1C/2C/4C and imaWorx CXP-12 Quad acquisition cards
           require a host interface with PCIe Gen 3 x8 (Direct Memory Access) or better.
           Using slower host interfaces may reduce the camera's asquisition frame rate
           and cause image loss.
    * Workbench: Using multiple pin data views actively displaying data in the Workbench may cause
                 an increase of the CPU load and degradation of the overall performance. Basler
                 recommends using fewer pin data views whenever possible.
    * Workbench: The Statistics feature of the Workbench measures the execution times of vTools.
                 The times measured in the Statistics feature may vary depending on the configuration of your
                 system and the overall CPU load. This is so, because CPUs may run with different frequencies
                 depending on the current load (e.g., due to dynamic frequency scaling).
    * Workbench: In case of display errors or missing symbols in the Workbench, check and update
                 your graphics card driver or install the OpenGL software emulation softpipe/llvmpipe.
    * CXP: Using secure boot (UEFI mode) with Linux requires a driver that is signed with a trusted
           certificate. Since the driver is provided as source code, there is no way to sign it
           with a trusted Basler certificate. To work with the driver, secure boot can be disabled.
           Alternatively, the driver can be self-signed as described in this Ubuntu blog entry:
           https://ubuntu.com/blog/how-to-sign-things-for-secure-boot
    * CXP: When camera parameters are changed during image acquisition, the change is
           not reflected in the interface card.
    * CXP: If images are lost on the interface card due to a buffer overflow, e.g., when
           the user application doesn't (re)queue buffers fast enough to deliver the images,
           the images lost are indicated by the next delivered buffer. The lost images are marked as INCOMPLETE,
           their file size will be 0, and the custom error code BUFFER_INFO_BASLER_XAPI_ERROR_CODE
           is set to 42. Additionally, one lost frame is added to the stream info. Note that
           exactly one lost frame is added regardless of how many frames were lost due to
           the overflow.
    * CXP: According to the GenTL standard, the device ID should remain constant between two sessions.
           However, the GenTL device ID changes when the applet is changed. Therefore, the device ID that was
           queried with one applet can be used with a different board and a different applet only if the applet
           has the same name as the original one with which the device ID was generated.
    * CXP: The GenTL BUFFER_INFO_FRAME_ID, which can be queried via DSGetBufferInfo, doesn't
           contain the source tag from the CXP image header. Instead, it contains a counter for
           all frames that have been delivered to the computer.
    * CXP: During an applet change, the cameras attached to an interface card are still displayed
           in the devices list even though they are not accessible anymore. An attempt to open a
           camera in this state leads to an error message.
    * CXP: When the DeviceUserID of a camera is changed, a restart of the GenTL Producer is
           required for the change to be reflected via the GenTL API. When using a GUI to interact
           with the camera via GenTL (i.e., the pylon Viewer), a restart of that application is
           required for the change to become visible.
    * CXP: When the CXP link speed is changed frequently on one port, at some point a speed change
           has no effect anymore. In that case, the error messages "Failed to set bitrate of uplink
           transceivers" and "Failed to set bitrate of downlink transceivers" are logged.
           To work around that, either reload the applet by loading a different applet and then loading the original
           one again or set the value of the environment variable SISO_FORCE_RELOAD_APPLET to 'yes'.
    * CXP: In rare cases, the camera is not found after booting the computer. Power-cycle
           the camera to resolve this.
    * CXP: Grabbing with very high frame rates above 50000 fps using the Basler CXP-12
           Interface Card 1C is not supported.
    * CXP: When allocating buffers used for grabbing, the buffer address must be
           aligned to 8-byte increments. This is automatically the case, if you use
           heap memory.
    * CXP: If a version of the Basler Framegrabber SDK is installed on your computer,
           you may experience incompatibility issues when using CoaXPress cameras
           and interface cards. Therefore, Basler advises against installing pylon
           in parallel to the Framegrabber SDK.
    * 3D: Using Basler blaze 3D cameras requires the pylon Supplementary Package
          for blaze to be installed. The pylon Supplementary Package for blaze is
          available for download on the Basler website.
    * SDK: Some ace 2 cameras may use a Boolean parameter instead of the usual enumeration
           for event notifications. The following code snippets can be used to work around
           this issue.
           For C++ you can use:
             CBooleanParameter(camera.GetNodeMap(), "EventNotification").TrySetValue(true);
           in addition to:
    * pylon C: The pylon C API doesn't provide convenient functions to use GenDC
    * pylon C: For using the GenTL Consumer (e.g., with CoaXPress), additional functionality
               was added to pylon C to be able to start and stop streaming explicitly. This
               functionality has not been documented in the pylon C programmer's guides yet.
               Refer to the pylon C++ programmer's guide (see chapter "Migrating
               from Previous Versions - Changes in the IStreamGrabber API") or the
               pylonC OverlappedGrab programming sample.
    * pylon Viewer: To use the pylon Viewer, you must install the latest Mesa OpenGL driver for
                    your system. On Debian-based platforms, you also need to install the
                    following packages: libgl1-mesa-dri, libgl1-mesa-glx, libxcb-xinerama0,
                    and libxcb-xinput0.
    * GenTL: [133711] Limited GenTL support for producers with GenTL version 1.4
             and below.
    * MP4: MP4 video recording requires the pylon Supplementary Package for MPEG-4 to
           be installed in order to work. The pylon Supplementary Package for MPEG-4
           is available for download on the Basler website.
           may fail, if the Quality parameter is set to 80 % or more. As a workaround,
           set the Quality parameter to a lower value.
    * MP4: [139274] The Recording feature doesn't support the Compression Beyond
           feature in ace 2 Pro cameras. When recording is started and the Compression
           Beyond feature is enabled, pylon first disables the Compression Beyond
    * General: Under certain circumstances, e.g., a very slow or busy computer,
               the Color Calibrator may not work if the camera has already been opened in the
               pylon Viewer.
               To prevent this, close the camera before using the Color Calibrator.
    * SDK: Kernel 3.x or higher is required to use the pylon C API.
    * GenTL: The GenTL producer for GigE Vision does not support action commands.
    * GenTL: The GenTL producer for GigE Vision does not support multicast configurations.
    * GigE Vision: Multiple IP configurations on a single network interface are not
                   fully supported by the IP Configurator tool.
    * GigE Vision: Assigning a static IP address to a camera that is not in the same
                   subnet as the network adapter may make the camera unreachable. To prevent this,
                   set the rp_filter (reverse path filter) to 2 ("loose mode") on the camera's network
                   interface. For more information, see the Assigning an IP Address to a Camera topic
                   in the Basler Product Documentation.
    * BPD: The Basler Product Documentation (BPD) requires advanced JavaScript support. Open the
           Basler Product Documentation in a modern browser, e.g., Firefox 44 (or higher) or
           Chrome 49 (or higher).
    * BPD: On Ubuntu 22.04 (or newer), the offline Basler Product Documentation (BPD) may not be
           accessible when using Firefox due to permission restrictions. To work around that this issue, you can
           set the environment variable TMPDIR to a location in the user's home directory, use a
           different browser, or install Firefox from a different source than snap.
    GMT+8, 2025-11-26 12:46
