TA的每日心情 | 无聊 4 小时前 |
签到天数: 3724 天 连续签到: 51 天 [LV.Master]2000FPS
楼主 |
发表于 2024-11-30 11:18:56
来自:广东省东莞市 电信
宝视纳Basler-pylon 7.5.0相机软件套装Linux ARM 64位 - tar.gz~pylon-7.5.0.15658-linux-aarch64_setup.tar.gz
pylon 7.5.0
2024年3月
7.5.0
文件名: pylon-7.5.0.15658-linux-aarch64_setup.tar.gz
文件大小: 370195960 字节 (353.05 MB)
修改日期: 2024-10-24 17:28
MD5: 7cdc72ad33bcfefd1455ff55128ba10b
SHA1: 02c43a20cf9f4c35672b9fa976fc0b9fde80a595
SHA256: 932d933beb67057d2bea05dae53768c283092ec784f44c93f53ea86897fbef75
CRC32: a126af3e
Basler官方下载:
链接:https://pan.baidu.com/s/1t40hqEri1LmkN6B1Rh6Ixw
pylon 7 Camera Software Suite for Linux
RELEASE NOTES
Note: Patch versions of pylon for Linux OS are not released publicly.
RELEASE DATE: 2024-05-21
VERSION: 7.5.0 (x86_64, aarch64)
BINARY COMPATIBILITY
* pylon C++ SDK = 8.0.0: Applications built with earlier versions of the pylon C++ SDK
are incompatible.
* pylon C SDK = 8.0.0: Applications built with earlier versions of the pylon C SDK
are incompatible.
* Data Processing SDK = 2.0.0: Applications built with earlier versions of the Data
Processing SDK are incompatible
NEW FEATURES / CHANGES
* General: The versioning scheme of some pylon modules, e.g., C++ SDK, has been changed
and has been decoupled from the pylon release version.
* CXP: Added support for Basler racer 2 L CoaXPress line scan cameras. These cameras
are for use with the Basler CXP-12 Interface Card 2C/4C or imaWorx CXP-12
Quad acquisition cards, which require a host interface with PCIe Gen 3x8
(Direct Memory Access) or better.
* CXP: Added support for Basler ace 2 V CoaXPress cameras. These cameras
are for use with the Basler CXP-12 Interface Card 1C/2C/4C or imaWorx CXP-12
* GigE: Added support for Basler dart M GigE Vision cameras.
* GenTL/CXP: New line scan applets (version 1.1.1.0) for Basler CXP-12 Interface
Card 1C/2C/4C and imaWorx CXP-12 Quad have been added.
* GenTL/CXP: The applets for Basler CXP-12 Interface Card 2C/4C and
imaWorx CXP-12 Quad with static version S1.0 have been updated to
version 2.3.7.
* GenTL/CXP: The applet for Basler CXP-12 Interface Card 1C with static
version S1.2 has been updated to version 5.3.7.
* CXP/GenTL: [269821] The CXP GenTL Producer, ProducerCXP.cti, has been updated to
version 1.0.2.
* GenTL/CXP: [269821] The CXP driver has been updated to version 5.4.0.
* CXP: The CoaXPress trigger packets have been updated to CoaXPress version 2.1.
* CXP: Some missing features for CXP 2.0 have been implemented.
* CXP: [292767] Added an alternative handler for IOCTL_QUEUE_BUFFER that is
called when a transfer length has been provided.
* CXP: Added firmware files to upgrade Interface Card 1C to Static 1.2 P0.
* GigE: [300043] The PylonGigEConfigurator now sets the interrupt moderation
rate of NICs to 'High' by default. This has shown to deliver a better
performance and a lower CPU load in some cases.
* pylon Viewer: [290156] The pylon Line Profile tool has been added in the
Window menu of the pylon Viewer. This GUI tool displays the
brightness along a freely placeable line in the image window.
* pylon Viewer: [295575] When using Single Shot with line scan cameras with a
CoaXPress frame grabber that supports the height feature, the
pylon Viewer will use the continuous acquisition mode, resulting
in the acquisition of an image with the specified height instead
of a single line.
* pylon Viewer: [290499] The Color Calibrator now supports Basler ace 2 GigE
Vision and USB3 Vision and boost R CoaXPress color cameras.
* pylon Viewer: [275057] The docking framework used in the pylon Viewer has been
replaced. This results in a new look and feel and docking behaviour.
* pylon Viewer: [303875] The New Features tab in the 'Welcome to pylon' dialog
has been updated.
* pylon Viewer: [289871] The pylon Viewer GUI tools have been updated to Qt
6.5.3.
* vTools: [277423] The new OCR Basic vTool has been added.
* vTools: [297867] In vTool dialogs with image display, the pixel coordinates of
the current mouse pointer position are shown below the image.
* vTools: [282974] Improved Template Matching Basic with angle limitation and
wait indicator.
* vTools: [290464] vTools Starter: Improved recognition times for code reader
vTools.
* Workbench: [275056] The design of the vTools pane has been updated. vTools are
now grouped by use cases and can be added as favorites. A search
feature makes it easier to find the vTool you are looking for.
* Workbench: [275052] Results in the pin data view can now be matched to the
corresponding region in the image. If there are several results from
the same output pin, you can clickÂ′ "Show related Region" next to a
result to highlight the corresponding region.
* Data Processing: [275724] Added a generic output observer that collects recipe
outputs in a queue.
* Data Processing: [275631] Removed type names from the Data Processing SDK
interface and replaced them with EVariantDataType and
EVariantContainerType.
* Data Processing: [282500] The acquisition mode can now be set for Camera
and Image Loading vTools when starting a recipe (see
EAcquisitionMode for more details).
* Data Processing: [282501] Allowed using callables as observers in Data
Processing SDK.
* Data Processing: [302347] Added a sample showing how to handle region data.
* Data Processing: [299393] Added a sample demonstrating how to use the OCR Basic
vTool.
* Data Processing: [301327] Improved the documentation of ellipse and rectangle
data types regarding rotation.
* Data Processing: [300915] Simplified Barcode and Composite Data Types samples.
* Data Processing: [299163] Added information about the pylon Viewer Recipe Code
Generator to documentation and samples. Added overview
diagram to programmer's guide.
* BPD: The offline BPD has been updated.
CORRECTIONS
* GigE: [292109] An EmitResend is skipped for empty lists. This reduces the system
load. (Version 5.4.0.1250)
* GigE: [287757] Timeouts for read or write requests are no longer ignored.
* GenTL/USB: [305224] A GenTL Producer (USB) issue with with packed pixel formats
on ace 2 cameras has been fixed.
* GenTL/GigE: [305224] A GenTL Producer (GEV) issue with with packed pixel formats
* pylon C++ SDK: [302425] A potential memory leak of the CPylonDataComponent has
been fixed.
* pylon C++ SDK: [284623] Changed the "pylonutilitypcl" library from loading at
start-up to on demand at runtime.
* CXP: The maximum image width for mirroring has been improved.
* CXP: The FG_SYSTEMMONITOR_USED_CXP_CONNECTIONS did not show correct values
before. This has been fixed.
* CXP: An incorrect default for FG_LINETRIGGERINSRC and FG_SHAFTENCODERINSRC has
been fixed.
* CXP: [285576] When WaitForFrame returns, buffers are always fully
accessible by the application in all acquisition modes. This fixes issues
when re-queuing a buffer very quickly.
* CXP: Fixed an issue which caused wrong setting for FG_DIGIO_INPUT when
configuring a GPIO.
* GenTL/CXP: [274400] Fixed the length of CXP_BOOTREG_MANUFACTURE_INFO.
Fixed unset Camera Link config value. Fixed discovery for cameras
that start with 1.25 GB/s.
* GenTL/CXP: [291818] Fixed the Fg_unregisterApcHandler(), which has always been
waiting for a timeout.
* GenTL/CXP: [271134] The range verification when reading values from the camera
via GenAPI has been disabled to avoid caching issues.
* GenTL/CXP: [230948] A potential race condition have been fixed where a remote
device could have been considered as discovered before the internal
discovery has ended.
* GenTL/CXP: [270982] Changed the version of *.cti files.
* pylon Viewer: [295574] Improved the overall stability and performance when
images are acquired at high frame rates.
* pylon Viewer: [303499] Fixed a potential crash when opening a camera while a CXP
device was connected to the system.
* pylon Viewer: [300040] Fixed a potentially incorrect handling of camera grabbing
state in Static Defect Pixel Correction plugin when switching
cameras.
* pylon Viewer: [290499] Improved the way the Color Calibrator accesses cameras
to support more camera models.
* pylon Viewer: [292677] Fixed an issue where images with height or width
greater than 32767 would not be displayed.
* pylon Viewer: [303720] The behavior of the pylon Welcome dialog has been improved.
Now, it only stays on top application-wide rather than system-wide.
* pylon Viewer: [292316] Fixed potential crash after stopping a recording with
large images.
* pylon Viewer: [289709] Fixed an issue where moving the mouse in an empty image
window would display invalid coordinates in the status bar.
* pylon Viewer: [287963] Fixed an issue where the Welcome dialog was not on top.
* pylon Viewer: [305588] Fixed an issue where the correct BPD topic wasn't opened
when clicking the "Get help" link in the flat-field correction
wizard.
* pylon Viewer: [305815] Fixed an issue that caused tooltips to be incorrectly
displayed in some rare cases.
* Firmware Updater: [285018] Fixed an issue where cameras could not be
rediscovered after reset.
* vTools: [302805, 284218] Calibration Basic/Pro: Cosmetic improvements
of the GUI.
* vTools: [297120] Fixed zoom focus in vTools with image editors.
* vTools: [303232, 283992] Fixed limit handling and readability in Image
Enhancer Basic GUI.
* vTools: [303585] Fixed a typo in the feature documentation of the
Gray Value Transformer vTool.
* vTools: [289438] Improved error message for Template Matching Basic and
Image Morphology Basic if the format of the training image differed
from runtime data.
* vTools: [292333] Updated vTool documentation for Template Matching Basic.
* vTools: [295169] In the settings dialog of the Camera vTool it's not possible
anymore to change the selected camera while the recipe is running.
* vTools: [298850, 298846, 298792] Added missing icons in the settings dialog of
the Image Loading vTool.
* vTools: [298735] Fixed crash during refresh of the available camera devices in
the Camera vTool settings dialog.
* vTools: [290452] The type of output error for Gray Value Transformer Starter
was changed from RegionArray to Image (pin type is Image).
* vTools: [PYVTO-535] Updates for Image Sharpening Starter vTool documentation and
fixes for inaccuracies in vTool settings:
A maximum mask size has been introduced, the maximum sharpening filter
value is 25, and the maximum unsharp mask value is 101. The default factor
for the sharpening filter is set to 9.
* vTools: [PYVTO-537] Fixed inaccuracies in Image Sharpening Starter settings:
An error now appears in the pin data view if the mask size entered is
greater than the maximum size.
* vTools: [PYVTO-550] Fixed inaccuracies in Image Sharpening Starter settings:
When changing the mask height and width in the settings dialog, the
parameter values in the API are updated accordingly.
* vTools: [283821] Fixed some layout issues in the Template Matching Starter dialog.
* Workbench: [304765] Fixed an issue that prevented scrolling in the Statistics tab
of the Recipe Management pane.
* Workbench: [303281] Fixed an issue that could prevent recipes from being saved and
loaded correctly when the user interface language was set to Japanese.
* Workbench: [306122] Changed the Sales inquiry URL in the vTool Licensing window
for easier evaluation license access.
RESTRICTIONS
* GigE Vision: [259058] For optimum use of Basler's ace 2 5GigE and 1GigE cameras,
Basler recommends using dual-channel DDR4-3600 RAM or better.
Using slower RAM may cause buffer underruns and image loss.
In addition, Basler recommends using the pylon GigE Configurator
tool to optimize the complete setup.
* GigE: [259100] In case the error message "Failed to allocate ressources." has
been reported, Basler recommends using the pylon GigE Configurator tool
to optimize the IP configuration of NICs and cameras.
* GenTL/GigE: The GenTL producer for GigE Vision does not support action
commands.
* GenTL/GigE: The GenTL producer for GigE Vision does not support multicast
configurations.
* GigE Vision: Multiple IP configurations on a single network interface are not
fully supported by the IP Configurator tool.
* GigE Vision: Assigning a static IP address to a camera that is not in the same
subnet as the network adapter may make the camera unreachable. To prevent
this, set the rp_filter (reverse path filter) to 2 ("loose mode") on the
camera's network interface. For more information, see the Assigning an IP
Address to a Camera topic in the Basler Product Documentation.
* CXP IC: The Basler CXP-12 Interface Card 1C/2C/4C and imaWorx CXP-12 Quad acquisition cards
require a host interface with PCIe Gen 3 x8 (Direct Memory Access) or better.
Using slower host interfaces may reduce the camera's acquisition frame rate
and cause image loss.
* CXP IC: For line scan applets, ranges of line period and line exposure are not
handled properly. The maximum values may be lower than expected.
* CXP IC: For line scan applets with image mirroring enabled (VantagePont = TopRight
or BottomRight), the actual maximum image width may be smaller than
documented and depends on the applet and pixel format used. However,
all applets support the maximum camera width of the Basler racer 2 L
cameras (r2L8192-200cm). Contact Basler if a larger image width
is required.
* CXP IC: When the CXP link speed is changed frequently on one port, it may
happen that the speed change doesn't have any effect anymore. In that case,
the error messages "Failed to set bitrate of uplink transceivers" and
"Failed to set bitrate of downlink transceivers" are logged. Since the
camera discovery probes the unconnected ports and therefore changes their
link speed, this issue may occur when an application frequently tries to
discover new cameras on unconnected ports.
* GenTL/CXP: The actual buffer size limit is 2 GB, which consequently imposes
a restriction on the permissible values for Width and Height
in the producer and results in that the maximum size of image is 2 GB.
* GenTL/CXP: The fps limit is between 50000 and 90000 fps depending on the number
of buffers and image size.
Examples for approximate values: 10 buffers and a minimum
image size of 48x1 give a limit of approximately 50000 fps. 50
buffers and a minimum image size of 48x1 give a limit of about 90000 fps.
50 buffers and an image size of 8192x1 give a limit of approximately
50000 fps.
* GenTL/CXP: When camera parameters are changed during image acquisition, the
change isn't reflected in the frame grabber. This is because
the GenTL Producer retrieves the relevant parameters (width,
height, image format, etc.) before starting the acquisition and
synchronizes these with the frame grabber.
* GenTL/CXP: According to the GenTL standard, the device ID should remain
constant between two sessions. However, the GenTL device ID changes
when the applet is changed. Therefore, the device ID can only be
reused if the applet has the same name as the applet with which
the device ID was generated.
* CXP: If images are lost on the interface card due to a buffer overflow, e.g., when
the user application doesn't (re)queue buffers fast enough to deliver the images,
the images lost are indicated by the next delivered buffer. The lost images are
marked as INCOMPLETE, their file size will be 0, and the custom error code
BUFFER_INFO_BASLER_XAPI_ERROR_CODE is set to 42. Additionally, one lost frame is
added to the stream info. Note that exactly one lost frame is added regardless of
how many frames were lost due to the overflow.
* CXP: The GenTL BUFFER_INFO_FRAME_ID, which can be queried via DSGetBufferInfo, doesn't
contain the source tag from the CXP image header. Instead, it contains a counter for
all frames that have been delivered to the computer.
* CXP: During an applet change, the cameras attached to an interface card are still
displayed in the devices list even though they are not accessible anymore.
An attempt to open a camera in this state leads to an error message.
* CXP: When the DeviceUserID of a camera is changed, a restart of the GenTL Producer is
required for the change to be reflected via the GenTL API. When using a GUI to
interact with the camera via GenTL (i.e., the pylon Viewer), a restart of that
application is required for the change to become visible.
* CXP: In rare cases, the camera is not found after booting the computer. Power-cycle
the camera to resolve this.
* CXP: When changing the PCIe slot used by the Basler CXP-12 Interface Card 1C
in a computer, the computer must be in shutdown state. Problems may occur if the computer
is in hibernation state, where the state of the OS has been persisted to
disk.
* CXP: When allocating buffers used for grabbing, the buffer address must be
aligned to 8-byte increments. This is automatically the case if you use
heap memory.
* CXP: Under rare circumstances, when the CXP link speed is changed frequently on one port, at
some point a speed change has no effect anymore. To work around that,
either reload the applet by loading a different applet and then loading the original
one again or set the value of the SISO_FORCE_RELOAD_APPLET environment variable to 'yes'.
* CXP: Using secure boot (UEFI mode) with Linux requires a driver that is signed with a trusted
certificate. Since the driver is provided as source code, there is no way to sign it
with a trusted Basler certificate. To work with the driver, secure boot can be disabled.
Alternatively, the driver can be self-signed as described in this Ubuntu blog entry:
https://ubuntu.com/blog/how-to-sign-things-for-secure-boot
* CXP: If a version of the Basler Framegrabber SDK is installed on your computer,
you may experience incompatibility issues when using CoaXPress cameras
and interface cards. Therefore, Basler advises against installing pylon
in parallel to the Framegrabber SDK.
* GenTL: Limited GenTL support for producers with GenTL version 1.4 and below.
* 3D: Using Basler blaze 3D cameras requires the pylon Supplementary Package
for blaze to be installed. The pylon Supplementary Package for blaze is
available for download on the Basler website.
* pylon Viewer: A new image throttle has been implemented in the pylon Viewer to
improve overall stability and performance. This introduces a new
restriction which affects the video recording feature of the pylon
Viewer. Allowing only 250 images per second and camera in the
imaging pipeline limits the ability to record every frame when
exceeding this limit.
* pylon Viewer: The Color Calibrator does not support all Basler color cameras.
cameras are not supported.
* pylon Viewer: Under certain circumstances, e.g., a very slow or busy computer,
the Color Calibrator may not work if the camera has already been
opened in the pylon Viewer.
To prevent this, close the camera before using the Color Calibrator.
* pylon Viewer: To use the pylon Viewer, you must install the latest Mesa OpenGL driver for
your system. On Debian-based platforms, you also need to install the
following packages: libgl1-mesa-dri, libgl1-mesa-glx, libxcb-xinerama0,
and libxcb-xinput0
* pylon Viewer: Under circumstances, the pylon Viewer may experience issues when using
the Wayland display server protocol. It is recommended to use Xorg instead.
* Workbench: Using multiple pin data views actively displaying data in the Workbench
may cause an increase of the CPU load and degradation of the overall
performance. Basler recommends using fewer pin data views whenever
possible.
* Workbench: The Statistics feature of the Workbench measures the execution times
of vTools. The times measured by the Statistics feature may vary
depending on the configuration of your system and the overall CPU load.
This is so because CPUs may run with different frequencies depending on
the current load (e.g., due to dynamic frequency scaling).
* Workbench: Pixel values in the pin data view will not be updated if no new images are
acquired.
* Workbench: When switching to full screen in a pin data view, the screen will remain black
when no new images are acquired.
* Workbench: When loading recipes containing multiple pin data views, the limit of 16
pin data views will be reached early, even if there are fewer than 16 pin
data views present. Restarting the pylon Viewer may solve this issue.
* Workbench: The context menu in the Workbench may be too small to show all
vTools when it is opened near the edges of the Workbench.
* Workbench: The pin data view may not show RGB values in the status bar when recipe is not
running.
* Workbench: The pin data view may not allow cleaning up deleted pins.
* SDK: Under rare circumstances some SDK samples may terminate abnormaly. To workaround this,
you can either rename the "pylonutilitypcl.so" library located e.g., under
/opt/pylon/lib, unset the GenTL path, or prevent loading the U3V GenTL producer.
* SDK: Some ace 2 cameras may use a Boolean parameter instead of the usual enumeration
for event notifications. The following code snippets can be used to work around
this issue.
For C++ you can use:
CBooleanParameter(camera.GetNodeMap(), "EventNotification").TrySetValue(true);
in addition to:
* pylon C: The pylon C API doesn't provide convenient functions to use GenDC
* pylon C: For using the GenTL Consumer (e.g., with CoaXPress), additional functionality
was added to pylon C to be able to start and stop streaming explicitly. This
functionality has not been documented in the pylon C programmer's guides yet.
Refer to the pylon C++ programmer's guide (see chapter "Migrating
from Previous Versions - Changes in the IStreamGrabber API") or the
pylonC OverlappedGrab programming sample.
* SDK: Kernel 3.x or higher is required to use the pylon C API.
* MP4: MP4 video recording requires the pylon Supplementary Package for MPEG-4 to
be installed. The pylon Supplementary Package for MPEG-4 is available for
may fail, if the Quality parameter is set to 80 % or more. As a workaround,
set the Quality parameter to a lower value.
* MP4: [139274] The Recording feature doesn't support the Compression Beyond
feature in ace 2 Pro cameras. When recording is started and the Compression
Beyond feature is enabled, pylon first disables the Compression Beyond
* BPD: The Basler Product Documentation (BPD) requires advanced JavaScript support. Open the
Basler Product Documentation in a modern browser, e.g., Firefox 44 (or higher) or
Chrome 49 (or higher).
* BPD: On Ubuntu 22.04 (or higher), the offline Basler Product Documentation (BPD) may not be
accessible when using Firefox due to permission restrictions. To work around this issue, you can
set the environment variable TMPDIR to a location in the user's home directory, use a
different browser, or install Firefox from a different source than snap. |
