查看: 664|回复: 0
[驱动] 宝视纳Basler-pylon 7.5.0相机软件套装Linux x86 (64位) - tar.gz~pylon-7.5.0.15658_linux-x86_64_setup.tar.gz
    4 小时前
  • 签到天数: 3724 天
    连续签到: 51 天
     楼主| 发表于 2024-11-30 11:35:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    pylon 7.5.0
    2024年3月
    7.5.0
    文件名: pylon-7.5.0.15658_linux-x86_64_setup.tar.gz
    文件大小: 640620971 字节 (610.94 MB)
    修改日期: 2024-10-24 17:35
    MD5: 31223a576da03796489a3e4a3da51fcb
    SHA1: c9f5b0b5498296b1847fa95f5922d599dc2b952b
    SHA256: 69b1cf08f05e0cbf27ff5ac6cfb447b57a375c94bfa1797e2db6fb0719633cb2
    CRC32: 5ec0e3a0
    Basler官方下载:
    链接:https://pan.baidu.com/s/10xahPVlxzUyewUPZfzMpqw
    pylon 7 Camera Software Suite for Linux
    RELEASE NOTES
    Note: Patch versions of pylon for Linux OS are not released publicly.
    RELEASE DATE:    2024-05-21
    VERSION:         7.5.0 (x86_64, aarch64)
    BINARY COMPATIBILITY
    * pylon C++ SDK = 8.0.0: Applications built with earlier versions of the pylon C++ SDK
                             are incompatible.
    * pylon C SDK = 8.0.0: Applications built with earlier versions of the pylon C SDK
                           are incompatible.
    * Data Processing SDK = 2.0.0: Applications built with earlier versions of the Data
                               Processing SDK are incompatible
    NEW FEATURES / CHANGES
    * General: The versioning scheme of some pylon modules, e.g., C++ SDK, has been changed
               and has been decoupled from the pylon release version.
    * CXP: Added support for Basler racer 2 L CoaXPress line scan cameras. These cameras
           are for use with the Basler CXP-12 Interface Card 2C/4C or imaWorx CXP-12
           Quad acquisition cards, which require a host interface with PCIe Gen 3x8
          (Direct Memory Access) or better.
    * CXP: Added support for Basler ace 2 V CoaXPress cameras. These cameras
           are for use with the Basler CXP-12 Interface Card 1C/2C/4C or imaWorx CXP-12
    * GigE: Added support for Basler dart M GigE Vision cameras.
    * GenTL/CXP: New line scan applets (version 1.1.1.0) for Basler CXP-12 Interface
                 Card 1C/2C/4C and imaWorx CXP-12 Quad have been added.
    * GenTL/CXP: The applets for Basler CXP-12 Interface Card 2C/4C and
                 imaWorx CXP-12 Quad with static version S1.0 have been updated to
                 version 2.3.7.
    * GenTL/CXP: The applet for Basler CXP-12 Interface Card 1C with static
                 version S1.2 has been updated to version 5.3.7.
    * CXP/GenTL: [269821] The CXP GenTL Producer, ProducerCXP.cti, has been updated to
                 version 1.0.2.
    * GenTL/CXP: [269821] The CXP driver has been updated to version 5.4.0.
    * CXP: The CoaXPress trigger packets have been updated to CoaXPress version 2.1.
    * CXP: Some missing features for CXP 2.0 have been implemented.
    * CXP: [292767] Added an alternative handler for IOCTL_QUEUE_BUFFER that is
           called when a transfer length has been provided.
    * CXP: Added firmware files to upgrade Interface Card 1C to Static 1.2 P0.
    * GigE: [300043] The PylonGigEConfigurator now sets the interrupt moderation
            rate of NICs  to 'High' by default. This has shown to deliver a better
            performance and a lower CPU load in some cases.
    * pylon Viewer: [290156] The pylon Line Profile tool has been added in the
                    Window menu of the pylon Viewer. This GUI tool displays the
                    brightness along a freely placeable line in the image window.
    * pylon Viewer: [295575] When using Single Shot with line scan cameras with a
                    CoaXPress frame grabber that supports the height feature, the
                    pylon Viewer will use the continuous acquisition mode, resulting
                    in the acquisition of an image with the specified height instead
                    of a single line.
    * pylon Viewer: [290499] The Color Calibrator now supports Basler ace 2 GigE
                    Vision and USB3 Vision and boost R CoaXPress color cameras.
    * pylon Viewer: [275057] The docking framework used in the pylon Viewer has been
                    replaced. This results in a new look and feel and docking behaviour.
    * pylon Viewer: [303875] The New Features tab in the 'Welcome to pylon' dialog
                    has been updated.
    * pylon Viewer: [289871] The pylon Viewer GUI tools have been updated to Qt
                    6.5.3.
    * vTools: [277423] The new OCR Basic vTool has been added.
    * vTools: [297867] In vTool dialogs with image display, the pixel coordinates of
              the current mouse pointer position are shown below the image.
    * vTools: [282974] Improved Template Matching Basic with angle limitation and
              wait indicator.
    * vTools: [290464] vTools Starter: Improved recognition times for code reader
              vTools.
    * Workbench: [275056] The design of the vTools pane has been updated. vTools are
                 now grouped by use cases and can be added as favorites. A search
                 feature makes it easier to find the vTool you are looking for.
    * Workbench: [275052] Results in the pin data view can now be matched to the
                 corresponding region in the image. If there are several results from
                 the same output pin, you can clickÂ′ "Show related Region" next to a
                 result to highlight the corresponding region.
    * Data Processing: [275724] Added a generic output observer that collects recipe
                       outputs in a queue.
    * Data Processing: [275631] Removed type names from the Data Processing SDK
                       interface and replaced them with EVariantDataType and
                       EVariantContainerType.
    * Data Processing: [282500] The acquisition mode can now be set for Camera
                       and Image Loading vTools when starting a recipe (see
                       EAcquisitionMode for more details).
    * Data Processing: [282501] Allowed using callables as observers in Data
                       Processing SDK.
    * Data Processing: [302347] Added a sample showing how to handle region data.
    * Data Processing: [299393] Added a sample demonstrating how to use the OCR Basic
                       vTool.
    * Data Processing: [301327] Improved the documentation of ellipse and rectangle
                       data types regarding rotation.
    * Data Processing: [300915] Simplified Barcode and Composite Data Types samples.
    * Data Processing: [299163] Added information about the pylon Viewer Recipe Code
                       Generator to documentation and samples. Added overview
                       diagram to programmer's guide.
    * BPD: The offline BPD has been updated.
    CORRECTIONS
    * GigE: [292109] An EmitResend is skipped for empty lists. This reduces the system
            load. (Version 5.4.0.1250)
    * GigE: [287757] Timeouts for read or write requests are no longer ignored.
    * GenTL/USB: [305224] A GenTL Producer (USB) issue with with packed pixel formats
                 on ace 2 cameras has been fixed.
    * GenTL/GigE: [305224] A GenTL Producer (GEV) issue with with packed pixel formats
    * pylon C++ SDK: [302425] A potential memory leak of the CPylonDataComponent has
                     been fixed.
    * pylon C++ SDK: [284623] Changed the "pylonutilitypcl" library from loading at
                     start-up to on demand at runtime.
    * CXP: The maximum image width for mirroring has been improved.
    * CXP: The FG_SYSTEMMONITOR_USED_CXP_CONNECTIONS did not show correct values
           before. This has been fixed.
    * CXP: An incorrect default for FG_LINETRIGGERINSRC and FG_SHAFTENCODERINSRC has
           been fixed.
    * CXP: [285576] When WaitForFrame returns, buffers are always fully
           accessible by the application in all acquisition modes. This fixes issues
           when re-queuing a buffer very quickly.
    * CXP: Fixed an issue which caused wrong setting for FG_DIGIO_INPUT when
           configuring a GPIO.
    * GenTL/CXP: [274400] Fixed the length of CXP_BOOTREG_MANUFACTURE_INFO.
                 Fixed unset Camera Link config value. Fixed discovery for cameras
                 that start with 1.25 GB/s.
    * GenTL/CXP: [291818] Fixed the Fg_unregisterApcHandler(), which has always been
                 waiting for a timeout.
    * GenTL/CXP: [271134] The range verification when reading values from the camera
                 via GenAPI has been disabled to avoid caching issues.
    * GenTL/CXP: [230948] A potential race condition have been fixed where a remote
                 device could have been considered as discovered before the internal
                 discovery has ended.
    * GenTL/CXP: [270982] Changed the version of *.cti files.
    * pylon Viewer: [295574] Improved the overall stability and performance when
                    images are acquired at high frame rates.
    * pylon Viewer: [303499] Fixed a potential crash when opening a camera while a CXP
                    device was connected to the system.
    * pylon Viewer: [300040] Fixed a potentially incorrect handling of camera grabbing
                    state in Static Defect Pixel Correction plugin when switching
                    cameras.
    * pylon Viewer: [290499] Improved the way the Color Calibrator accesses cameras
                    to support more camera models.
    * pylon Viewer: [292677] Fixed an issue where images with height or width
                    greater than 32767 would not be displayed.
    * pylon Viewer: [303720] The behavior of the pylon Welcome dialog has been improved.
                    Now, it only stays on top application-wide rather than system-wide.
    * pylon Viewer: [292316] Fixed potential crash after stopping a recording with
                    large images.
    * pylon Viewer: [289709] Fixed an issue where moving the mouse in an empty image
                    window would display invalid coordinates in the status bar.
    * pylon Viewer: [287963] Fixed an issue where the Welcome dialog was not on top.
    * pylon Viewer: [305588] Fixed an issue where the correct BPD topic wasn't opened
                    when clicking the "Get help" link in the flat-field correction
                    wizard.
    * pylon Viewer: [305815] Fixed an issue that caused tooltips to be incorrectly
                    displayed in some rare cases.
    * Firmware Updater: [285018] Fixed an issue where cameras could not be
                        rediscovered after reset.
    * vTools: [302805, 284218] Calibration Basic/Pro: Cosmetic improvements
              of the GUI.
    * vTools: [297120] Fixed zoom focus in vTools with image editors.
    * vTools: [303232, 283992] Fixed limit handling and readability in Image
              Enhancer Basic GUI.
    * vTools: [303585] Fixed a typo in the feature documentation of the
              Gray Value Transformer vTool.
    * vTools: [289438] Improved error message for Template Matching Basic and
              Image Morphology Basic if the format of the training image differed
              from runtime data.
    * vTools: [292333] Updated vTool documentation for Template Matching Basic.
    * vTools: [295169] In the settings dialog of the Camera vTool it's not possible
              anymore to change the selected camera while the recipe is running.
    * vTools: [298850, 298846, 298792] Added missing icons in the settings dialog of
              the Image Loading vTool.
    * vTools: [298735] Fixed crash during refresh of the available camera devices in
              the Camera vTool settings dialog.
    * vTools: [290452] The type of output error for Gray Value Transformer Starter
              was changed from RegionArray to Image (pin type is Image).
    * vTools: [PYVTO-535] Updates for Image Sharpening Starter vTool documentation and
              fixes for inaccuracies in vTool settings:
              A maximum mask size has been introduced, the maximum sharpening filter
              value is 25, and the maximum unsharp mask value is 101. The default factor
              for the sharpening filter is set to 9.
    * vTools: [PYVTO-537] Fixed inaccuracies in Image Sharpening Starter settings:
              An error now appears in the pin data view if the mask size entered is
              greater than the maximum size.
    * vTools: [PYVTO-550] Fixed inaccuracies in Image Sharpening Starter settings:
              When changing the mask height and width in the settings dialog, the
              parameter values in the API are updated accordingly.
    * vTools: [283821] Fixed some layout issues in the Template Matching Starter dialog.
    * Workbench: [304765] Fixed an issue that prevented scrolling in the Statistics tab
                 of the Recipe Management pane.
    * Workbench: [303281] Fixed an issue that could prevent recipes from being saved and
                 loaded correctly when the user interface language was set to Japanese.
    * Workbench: [306122] Changed the Sales inquiry URL in the vTool Licensing window
                 for easier evaluation license access.
    RESTRICTIONS
    * GigE Vision: [259058] For optimum use of Basler's ace 2 5GigE and 1GigE cameras,
                   Basler recommends using dual-channel DDR4-3600 RAM or better.
                   Using slower RAM may cause buffer underruns and image loss.
                   In addition, Basler recommends using the pylon GigE Configurator
                   tool to optimize the complete setup.
    * GigE: [259100] In case the error message "Failed to allocate ressources." has
            been reported, Basler recommends using the pylon GigE Configurator tool
            to optimize the IP configuration of NICs and cameras.
    * GenTL/GigE: The GenTL producer for GigE Vision does not support action
                  commands.
    * GenTL/GigE: The GenTL producer for GigE Vision does not support multicast
                  configurations.
    * GigE Vision: Multiple IP configurations on a single network interface are not
                   fully supported by the IP Configurator tool.
    * GigE Vision: Assigning a static IP address to a camera that is not in the same
                   subnet as the network adapter may make the camera unreachable. To prevent
                   this, set the rp_filter (reverse path filter) to 2 ("loose mode") on the
                   camera's network interface. For more information, see the Assigning an IP
                   Address to a Camera topic in the Basler Product Documentation.
    * CXP IC: The Basler CXP-12 Interface Card 1C/2C/4C and imaWorx CXP-12 Quad acquisition cards
              require a host interface with PCIe Gen 3 x8 (Direct Memory Access) or better.
              Using slower host interfaces may reduce the camera's acquisition frame rate
              and cause image loss.
    * CXP IC: For line scan applets, ranges of line period and line exposure are not
              handled properly. The maximum values may be lower than expected.
    * CXP IC: For line scan applets with image mirroring enabled (VantagePont = TopRight
              or BottomRight), the actual maximum image width may be smaller than
              documented and depends on the applet and pixel format used. However,
              all applets support the maximum camera width of the Basler racer 2 L
              cameras (r2L8192-200cm). Contact Basler if a larger image width
              is required.
    * CXP IC: When the CXP link speed is changed frequently on one port, it may
              happen that the speed change doesn't have any effect anymore. In that case,
              the error messages "Failed to set bitrate of uplink transceivers" and
              "Failed to set bitrate of downlink transceivers" are logged. Since the
              camera discovery probes the unconnected ports and therefore changes their
              link speed, this issue may occur when an application frequently tries to
              discover new cameras on unconnected ports.
    * GenTL/CXP: The actual buffer size limit is 2 GB, which consequently imposes
                 a restriction on the permissible values for Width and Height
                 in the producer and results in that the maximum size of image is 2 GB.
    * GenTL/CXP: The fps limit is between 50000 and 90000 fps depending on the number
                 of buffers and image size.
                 Examples for approximate values: 10 buffers and a minimum
                 image size of 48x1 give a limit of approximately 50000 fps. 50
                 buffers and a minimum image size of 48x1 give a limit of about 90000 fps.
                 50 buffers and an image size of 8192x1 give a limit of approximately
                 50000 fps.
    * GenTL/CXP: When camera parameters are changed during image acquisition, the
                 change isn't reflected in the frame grabber. This is because
                 the GenTL Producer retrieves the relevant parameters (width,
                 height, image format, etc.) before starting the acquisition and
                 synchronizes these with the frame grabber.
    * GenTL/CXP: According to the GenTL standard, the device ID should remain
                 constant between two sessions. However, the GenTL device ID changes
                 when the applet is changed. Therefore, the device ID can only be
                 reused if the applet has the same name as the applet with which
                 the device ID was generated.
    * CXP: If images are lost on the interface card due to a buffer overflow, e.g., when
           the user application doesn't (re)queue buffers fast enough to deliver the images,
           the images lost are indicated by the next delivered buffer. The lost images are
           marked as INCOMPLETE, their file size will be 0, and the custom error code
           BUFFER_INFO_BASLER_XAPI_ERROR_CODE is set to 42. Additionally, one lost frame is
           added to the stream info. Note that exactly one lost frame is added regardless of
           how many frames were lost due to the overflow.
    * CXP: The GenTL BUFFER_INFO_FRAME_ID, which can be queried via DSGetBufferInfo, doesn't
           contain the source tag from the CXP image header. Instead, it contains a counter for
           all frames that have been delivered to the computer.
    * CXP: During an applet change, the cameras attached to an interface card are still
           displayed in the devices list even though they are not accessible anymore.
           An attempt to open a camera in this state leads to an error message.
    * CXP: When the DeviceUserID of a camera is changed, a restart of the GenTL Producer is
           required for the change to be reflected via the GenTL API. When using a GUI to
           interact with the camera via GenTL (i.e., the pylon Viewer), a restart of that
           application is required for the change to become visible.
    * CXP: In rare cases, the camera is not found after booting the computer. Power-cycle
           the camera to resolve this.
    * CXP: When changing the PCIe slot used by the Basler CXP-12 Interface Card 1C
           in a computer, the computer must be in shutdown state. Problems may occur if the computer
           is in hibernation state, where the state of the OS has been persisted to
           disk.
    * CXP: When allocating buffers used for grabbing, the buffer address must be
           aligned to 8-byte increments. This is automatically the case if you use
           heap memory.
    * CXP: Under rare circumstances, when the CXP link speed is changed frequently on one port, at
           some point a speed change has no effect anymore. To work around that,
           either reload the applet by loading a different applet and then loading the original
           one again or set the value of the SISO_FORCE_RELOAD_APPLET environment variable to 'yes'.
    * CXP: Using secure boot (UEFI mode) with Linux requires a driver that is signed with a trusted
           certificate. Since the driver is provided as source code, there is no way to sign it
           with a trusted Basler certificate. To work with the driver, secure boot can be disabled.
           Alternatively, the driver can be self-signed as described in this Ubuntu blog entry:
           https://ubuntu.com/blog/how-to-sign-things-for-secure-boot
    * CXP: If a version of the Basler Framegrabber SDK is installed on your computer,
           you may experience incompatibility issues when using CoaXPress cameras
           and interface cards. Therefore, Basler advises against installing pylon
           in parallel to the Framegrabber SDK.
    * GenTL: Limited GenTL support for producers with GenTL version 1.4 and below.
    * 3D: Using Basler blaze 3D cameras requires the pylon Supplementary Package
          for blaze to be installed. The pylon Supplementary Package for blaze is
          available for download on the Basler website.
    * pylon Viewer: A new image throttle has been implemented in the pylon Viewer to
                    improve overall stability and performance. This introduces a new
                    restriction which affects the video recording feature of the pylon
                    Viewer. Allowing only 250 images per second and camera in the
                    imaging pipeline limits the ability to record every frame when
                    exceeding this limit.
    * pylon Viewer: The Color Calibrator does not support all Basler color cameras.
                    cameras are not supported.
    * pylon Viewer: Under certain circumstances, e.g., a very slow or busy computer,
                    the Color Calibrator may not work if the camera has already been
                    opened in the pylon Viewer.
                    To prevent this, close the camera before using the Color Calibrator.
    * pylon Viewer: To use the pylon Viewer, you must install the latest Mesa OpenGL driver for
                    your system. On Debian-based platforms, you also need to install the
                    following packages: libgl1-mesa-dri, libgl1-mesa-glx, libxcb-xinerama0,
                    and libxcb-xinput0
    * pylon Viewer: Under circumstances, the pylon Viewer may experience issues when using
                    the Wayland display server protocol. It is recommended to use Xorg instead.
    * Workbench: Using multiple pin data views actively displaying data in the Workbench
                 may cause an increase of the CPU load and degradation of the overall
                 performance. Basler recommends using fewer pin data views whenever
                 possible.
    * Workbench: The Statistics feature of the Workbench measures the execution times
                 of vTools. The times measured by the Statistics feature may vary
                 depending on the configuration of your system and the overall CPU load.
                 This is so because CPUs may run with different frequencies depending on
                 the current load (e.g., due to dynamic frequency scaling).
    * Workbench: Pixel values in the pin data view will not be updated if no new images are
                 acquired.
    * Workbench: When switching to full screen in a pin data view, the screen will remain black
                 when no new images are acquired.
    * Workbench: When loading recipes containing multiple pin data views, the limit of 16
                 pin data views will be reached early, even if there are fewer than 16 pin
                 data views present. Restarting the pylon Viewer may solve this issue.
    * Workbench: The context menu in the Workbench may be too small to show all
                 vTools when it is opened near the edges of the Workbench.
    * Workbench: The pin data view may not show RGB values in the status bar when recipe is not
                 running.
    * Workbench: The pin data view may not allow cleaning up deleted pins.
    * SDK: Under rare circumstances some SDK samples may terminate abnormaly. To workaround this,
           you can either rename the "pylonutilitypcl.so" library located e.g., under
           /opt/pylon/lib, unset the GenTL path, or prevent loading the U3V GenTL producer.
    * SDK: Some ace 2 cameras may use a Boolean parameter instead of the usual enumeration
           for event notifications. The following code snippets can be used to work around
           this issue.
           For C++ you can use:
             CBooleanParameter(camera.GetNodeMap(), "EventNotification").TrySetValue(true);
           in addition to:
    * pylon C: The pylon C API doesn't provide convenient functions to use GenDC
    * pylon C: For using the GenTL Consumer (e.g., with CoaXPress), additional functionality
               was added to pylon C to be able to start and stop streaming explicitly. This
               functionality has not been documented in the pylon C programmer's guides yet.
               Refer to the pylon C++ programmer's guide (see chapter "Migrating
               from Previous Versions - Changes in the IStreamGrabber API") or the
               pylonC OverlappedGrab programming sample.
    * SDK: Kernel 3.x or higher is required to use the pylon C API.
    * MP4: MP4 video recording requires the pylon Supplementary Package for MPEG-4 to
           be installed. The pylon Supplementary Package for MPEG-4 is available for
           may fail, if the Quality parameter is set to 80 % or more. As a workaround,
           set the Quality parameter to a lower value.
    * MP4: [139274] The Recording feature doesn't support the Compression Beyond
           feature in ace 2 Pro cameras. When recording is started and the Compression
           Beyond feature is enabled, pylon first disables the Compression Beyond
    * BPD: The Basler Product Documentation (BPD) requires advanced JavaScript support. Open the
           Basler Product Documentation in a modern browser, e.g., Firefox 44 (or higher) or
           Chrome 49 (or higher).
    * BPD: On Ubuntu 22.04 (or higher), the offline Basler Product Documentation (BPD) may not be
           accessible when using Firefox due to permission restrictions. To work around this issue, you can
           set the environment variable TMPDIR to a location in the user's home directory, use a
           different browser, or install Firefox from a different source than snap.
    GMT+8, 2025-11-26 12:45
