查看: 702|回复: 0
[驱动] 宝视纳Basler-pylon 8.0.0相机软件套装(Windows版)~Basler_pylon_8.0.0.exe
    4 小时前
  • 签到天数: 3724 天
    连续签到: 51 天
     楼主| 发表于 2024-11-30 11:45:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    pylon 8.0.0
    2024年9月
    8.0.0
    pylon相机软件套装(Windows版)的完整软件包。
    pylon相机软件套装包含易于使用的SDK、驱动程序和工具,让您可通过Windows PC来操作任意一款Basler相机。pylon采用最新GenICam技术,可无限制使用最新型号的Basler相机并使用相关的硬件功能。Basler pylon支持CoaXPress 2.0、GigE Vision、USB3 Vision、Camera Link和GenICam GenTL。
    pylon可为所有典型相机应用提供大量丰富的文档资料和示例程序以供参考,支持各种编程语言(C、C++、C#、VB.Net等),可大大促进应用的开发工作。
    Basler pylon支持所有当前的Windows版本,最高可支持Windows 11(64位)。由于pylon不仅支持Windows,还支持macOS和Linux(x86和ARM),因此在pylon下为Windows创建的应用程序可以轻松移植到其他操作系统和架构(如嵌入式系统)。
    文件名: Basler_pylon_8.0.0.exe
    文件大小: 914874624 字节 (872.49 MB)
    修改日期: 2024-10-24 19:01
    版本: 8.0.0.16021
    MD5: 06eca6f6e2e2e0d4ea1ea5f8fcd674e2
    SHA1: 54f43bcf8cf87f56746920718a2fd8865ec20ab5
    SHA256: 84545c50248e5439e14a43ee3dc2778795f9518a9afd7fb4fa47eb8ba461e2f5
    CRC32: 02b891c1
    Basler官方下载:
    链接:https://pan.baidu.com/s/1EGK3y6JQHgFANPq4IQj_dQ
    pylon 8 Software Suite for Windows
    RELEASE NOTES
    Note: Patch versions of pylon for Windows OS are not released publicly.
    RELEASE DATE:    2024-09-24
    VERSION:         8.0.0 (Windows)
    BINARY COMPATIBILITY
    * Data Processing = 3.0.1: Applications built with 3.0.x or earlier 3.x.x
                               versions of the Data Processing are compatible.
    * pylon C SDK = 9.0.0: Applications built with earlier versions of the pylon C
                           SDK are incompatible
    * pylon C++ SDK = 9.0.0: Applications built with earlier versions of the pylon
                             C++ SDK are incompatible
    * pylon .NET SDK = 1.2.0: Applications built with 1.2.x or earlier versions of the
                              pylon .NET SDK are compatible.
    NEW FEATURES / CHANGES
    * General: [311182] Following Semantic Versioning 2.0, the pylon SDK library
               names now only state the major version number and not the minor
               version number anymore.
    * pylon AI Agent: [286592] The pylon AI Agent is used to deploy models to AI
                      vTools. You can choose between deploying models via the pylon
                      AI Platform or from storage. Models can be deployed on local
                      or remote computers.
    * vTools: [286272, 286412, 285715, 285681] The following vTools have been added:
               - Object Detection
               - Classification
               - Semantic Segmentation
               - Instance Segmentation
    * pylon Viewer: [314565] Added pylon Event Logger as external tool in Tools
                    menu.
    * pylon Viewer: [311582] The Automatic Image Adjustment feature is now available
                    on dart M cameras.
    * pylon Viewer: [313572] Panes can now be closed via a context menu.
    * pylon Viewer: [308989] Added AI topics to the New Features and Learn More
                    dialogs.
    * pylon Viewer: [305588] The Line Profile can now be reset to its initial
                    position via the context menu of the image window.
    * pylon Viewer: [297026] Added a context menu to the Line Profile pane.
    * Workbench: [308021] The pin data view applies "Zoom to Fit" for the first
                 image displayed.
    * Workbench: [308968] The "Zoom to Fit" feature in pin data views now scales
                 seamlessly.
    * Workbench: [308991] On the Licensing tab of the Welcome dialog, added links
                 for AI vTools. In the Workbench menu, an entry for the pylon AI
                 agent has been added.
    * CXP IC: [298766] Added BoardStatus section with features providing information
              about the board status.
    * CXP IC: [298766] Added Errors section with features providing information
              about errors.
    * CXP IC: [298766] Added CameraStatus event to provide information about missing
              frames lost in transmission to the frame grabber.
    * CXP IC: [298766] Renamed CorrectedErrorCount to CameraCorrectedErrorCount.
    * CXP IC: [298766] Renamed UncorrectedErrorCount to CameraUncorrectedErrorCount.
    * CXP IC: [306774] Solved communication issue to Opto-Coupled Trigger 5 boards.
    * CXP IC: [220218] Fixed incorrect values in status operators which caused
              issues with CXP status and port status.
    * CXP IC: [303278] CustomSignalEvent0 and CustomSignalEvent1 now allow using
              FrontGPI2 and FrontGPI3 as source.
    * Data Processing: [289432] Improved performance by optimizing the internal
                       handling of data types.
    * Data Processing: [274754] CRegion::GetBuffer() behavior has been changed to
                       implement copy-on-write.
    * Data Processing: [300937] Added sample demonstrating how to receive chunks and
                       events from the Camera vTool.
    * pylon C SDK: [298881] There is now a separate CMake finder (pylonC) for the
                   pylon C interface. pylon C content has been removed from the
                   existing pylon CMake finder.
    * pylon C++ SDK: [296692] Added sample demonstrating the use of the shading
                     correction feature of racer 2 line scan cameras.
    * pylon C++ SDK: [314002] The CBaslerUniversalInstantCamera class has been
                     updated.
    * pylon C++ SDK: [303027] The GrabResult object now has an additional member,
                     and CPylonDataComponent was extended to support multipart data
                     components.
    * pylon C++ SDK: [298881] pylon C content has been removed from the pylon CMake
                     finder. There is now a separate CMake finder for pylon C.
    * pylon C++ SDK: [304030] Added new log4cpp logappender to support the new
                     Basler logging system ELT.
    * pylon C++ SDK: [303896,303897] Improved logging to support the pylon Event
                     Logger, especially with regard to GenTL and CXP.
    * vTools: [307646] Added more calibration plate sizes: 800 mm, 1200 mm, 1600 mm,
              and 2400 mm
    * vTools: [309025] Added the option to save absolute paths to image source
              folders in the Image Loading vTool.
    * vTools: [285172] In the Camera vTool, output pins can be added to output
              camera chunk data.
    * vTools: [285171] In the Camera vTool, output pins can be added to output
              camera event data.
    * vTools: [275698] The Image Loading vTool now supports using relative paths to
              image source folders in recipes.
    CORRECTIONS
    * pylon Viewer: [285047] When the Color Calibrator fails to successfully
                    complete the second step, the Continuous Shot check box remains
                    checked.
    * pylon Viewer: [312899] Fixed Histogram panning when using color images.
    * pylon Viewer: [312817] Fixed alignment of the Y axis label in the Line Profile
                    pane.
    * pylon Viewer: [308356] Increased the wait time to rediscover a camera after
                    performing a firmware update.
    * pylon Viewer: [290732] Improved error message when exceeding limits using
                    Static Defect Pixel Correction.
    * pylon Viewer: [307521] Line scan cameras will now use the correct acquisition
                    mode when using the single shot feature.
    * pylon Viewer: [304190] Fixed an issue which caused overlapping of the text and
                    buttons in the title of image window tabs.
    * Workbench: [291903] Fixed an issue which caused input pins of vTools being
                 added falsely as data source of pin data views.
    * Workbench: [312967] Fixed an issue which caused an error when loading recipes
                 without vTools.
    * Workbench: [311609] Fixed an issue that may have been causing the pylon Viewer
                 to crash when closing it while there is a Camera vTool with
                 allocated
    * Workbench: [299047] Fixed some display issues regarding the pin data view,
                 including the RGB info and the full-screen mode after a recipe has
                 been stopped.
    * Workbench: [307585] Fixed an issue that could cause the text in the pin data
                 view to be displayed incorrectly.
    * CXP: [304411] - 'Fixed: Before fixing this issue, applet event timestamps
           weren't correct. They were divided by 2. This has been fixed. Now, the
           applet event timestamps have the
            correct values.
    * Data Processing: [312880] Fixed an issue that prevented the renaming of input
                       and output terminal pins when the names of pins that were
                       created later started with the name of the first pin.
    * Data Processing: [309051] Changed nested namespace definition in
                       GenericOutputObserver.h to match other header files.
    * Camera Link: [307793] Added missing Basler_CameraLink.zip, which contains a
                   required XML file, to pylon runtime.
    * GigE: [314339] Fix for out of encoded data error when using Compression
            Beyond when using the Socket Driver. This is also fixed for pylon
            GEV Driver Version 5.4.1.1260.
    * Twain: [308082] Fixed a hang on load in the TWAIN driver.
    * vTools: [314717, 314714, 314713, 314707, 314716, 314724, 314710, 314709]
              Updated error handling for vTools that use Transformation Data.
    * vTools: [314724] Get help in the vTools-documentation for OCR-vTool opens the
              correct documentation-page.
    * vTools: [305245] In the Calibration Basic/Pro vTools, the graphical display of
              the image coordinates is correct if the operating system's screen-
              scaling feature is enabled.
    * vTools: [303977] Fixed dialog text for rotation angle in the Template Matching
              Basic vTool.
    * vTools: [311250] Removed obsolete node map entry and updated vTool
              documentation for the Document Cropper vTool.
    * vTools: [301657] Improved support for manual machine calibration in the
              Calibration Basic and Pro vTools.
    * vTools: [305510] Updated dialog appearance of the Template Matching Basic
              vTool.
    * vTools: [306903] In the Gray value Transformer Starter vTool, parameter names
              have been updated.
    RESTRICTIONS
    * pylon Viewer: A new image throttle has been implemented in the pylon Viewer to
                    improve overall stability and performance. This introduces a new
                    restriction which affects the video recording feature of the
                    pylon Viewer. Allowing only 250 images per second and camera in
                    the imaging pipeline limits the ability to record every frame
                    when exceeding this limit.
    * pylon Viewer: The Color Calibrator does not support all Basler color cameras.
                    cameras are not supported.
    * pylon Viewer: Under certain circumstances, e.g., a very slow or busy computer,
                    the Color Calibrator may not work if the camera has already been
                    opened in the pylon Viewer. To prevent this, close the camera
                    before using the Color Calibrator.
    * pylon Viewer: On computers with an Intel HD graphics card, it may be necessary
                    to update the graphics driver to the current version.
    * Workbench: Using multiple pin data views actively displaying data in the
                 Workbench may cause
                 an increase of the CPU load and degradation of the overall
                 performance. Basler
                 recommends using fewer pin data views whenever possible.
    * Workbench: The Statistics feature of the Workbench measures the execution
                 times of vTools.
                 The times measured in the Statistics feature may vary depending on
                 the configuration of your
                 system and the overall CPU load. This is so, because CPUs may run
                 with different frequencies
                 depending on the current load (e.g., due to dynamic frequency
                 scaling).
    * CXP IC: For line scan applets, ranges of line period and line exposure aren't
              handled properly. The maximum values may be lower than expected.
    * pylon C SDK: The pylon C API doesn't provide convenient functions to use GenDC
    * pylon C SDK: For using the GenTL Consumer (e.g., with CoaXPress), additional
                   functionality was added to pylon C to be able to start and stop
                   streaming explicitly. This functionality has not been documented
                   in the pylon C programmer's guide yet. Please refer to the pylon
                   C++ programmer's guide (see chapter "Migrating from Previous
                   Versions - Changes in the IStreamGrabber API") or the pylonC
                   OverlappedGrab programming sample.
    * pylon C++ SDK: When building samples using CMake, you may run into a path
                     length limitation of the operating system. You may get build
                     errors stating the paths exceed the maximum path length of 260
                     characters. This may happen if the absolute path of your CMake
                     build directory exceeds 80 characters. The build directory is
                     the current working directory or the directory specified by the
                     '-B' option when you call cmake. If you experience this error,
                     use a build directory with a shorter path not exceeding 80
                     characters, i.e., directly in your user profile
                     C:\Users\\Samples. You can enable long paths on
                     Windows 10, Version 1607, and later. See the Microsoft
                     documentation for more information.
    * pylon C++ SDK: Using Visual Studio 2017, you may get the MSB4211 warning. To
                     remove the warning, specify the version of the Windows SDK in
                     the Release and Debug project properties (Configuration
                     Properties -> General -> Windows SDK Version).
    * pylon C++ SDK: Some ace 2 cameras may use a Boolean parameter instead of the
                     usual enumeration for event notifications. The following code
                     snippets can be used to work around this issue. For C++ you can
                     use: CBooleanParameter(camera.GetNodeMap(),
                     "EventNotification").TrySetValue(true); in addition to:
    * GigE: In case the error message "Failed to allocate resources." has been
            reported, Basler recommends using the pylon GigE Configurator tool to
            optimize the IP configuration of NICs and cameras.
    * GigE: Multiple IP configurations on a single network interface are not fully
            supported by the IP Configurator tool.
    * pylon C++ SDK: The InstantCameraArray classes can acquire images from a
                     maximum of 21 cameras.
    * GigE: For optimum use of Basler's ace 2 5GigE and 1GigE cameras, Basler
            recommends using dual-channel DDR4-3600 RAM or better. Using slower RAM
            may cause buffer underruns and image loss. In addition, Basler
            recommends using the pylon GigE Configurator tool to optimize the
            complete setup.
    * GenTL: Limited GenTL support for producers with GenTL version 1.4 and below.
    * USB: The Power Management used by the Intel USB host must be turned off since
           Basler U3V devices may get desynchronized. If this is the case the Basler
           U3V devices may be not available after booting the system in some cases.
           Disable LPM packages on the USB3 bus with the following steps 1. Enable
           advanced settings by executing the following command powercfg -attributes
           2a737441-1930-4402-8d77-b2bebba308a3 d4e98f31-5ffe-
           4ce1-be31-1b38b384c009 -ATTRIB_HIDE 2. Change the LPM settings in the
           power options - Open the Power Options in the control panel. - Click
           "Change plan settings" for the selected power plan. - Click "Change
           advanced power settings". - In the "Power Options" dialog on the
           "Advanced settings" tab, select "USB settings". - Set "USB 3 Link Power
           Management" to "Off".
    * MP4: MP4 video recording requires the pylon Supplementary Package for MPEG-4
           to be installed in order to work. The pylon Supplementary Package for
           MPEG-4 is available for download on the Basler website.
           may fail, if the Quality parameter is set to 80 % or more. As a
           workaround, set the Quality parameter to a lower value.
    * MP4: The Recording feature doesn't support the Compression Beyond feature in
           ace 2 Pro cameras. When recording is started and the Compression Beyond
           feature is enabled, the pylon Viewer first disables the Compression Beyond
    * 3D: Using Basler blaze 3D cameras requires the pylon Supplementary Package for
          blaze to be installed. The pylon Supplementary Package for blaze is
    * Direct Show: CoaXPress cameras are not supported with DirectShow driver.
    * Twain: CoaXPress cameras are not supported with Twain driver.
    * pylon AI Agent: With certain resolutions and scaling settings, buttons may not
                      be visible.
    GMT+8, 2025-11-26 12:49
