TA的每日心情 | 无聊 4 小时前 |
签到天数: 3724 天 连续签到: 51 天 [LV.Master]2000FPS
楼主 |
发表于 2024-11-30 11:56:49
来自:广东省东莞市 电信
宝视纳Basler-pylon 8.0.0相机软件套装Linux x86 (64位) - tar.gz~pylon-8.0.0-linux-x86_64_setup.tar.gz
pylon 8.0.0
2024年9月
8.0.0
文件名: pylon-8.0.0-linux-x86_64_setup.tar.gz
文件大小: 695677798 字节 (663.45 MB)
修改日期: 2024-10-24 18:19
MD5: 97ccf49ea755eb2ea2ca0cc045ab36a9
SHA1: 8705e13b9ec95fa78809e59d1c96672a0589b701
SHA256: 0c1b83f8b8ecaff44d8bd4a6ce1f57d110f8a0273af2e2ed411cc39e6fbf6063
CRC32: 8eb91575
Basler官方下载:
链接:https://pan.baidu.com/s/15qp8eK386XIfSD85H9t7vQ
pylon 8 Software Suite for Linux
RELEASE NOTES
Note: Patch versions of pylon for Linux OS are not released publicly.
RELEASE DATE: 2024-09-24
VERSION: 8.0.0 (x86_64, aarch64)
BINARY COMPATIBILITY
* Data Processing = 3.0.1: Applications built with 3.0.x or earlier 3.x.x
versions of the Data Processing are compatible.
* pylon C SDK = 9.0.0: Applications built with earlier versions of the pylon C
SDK are incompatible
* pylon C++ SDK = 9.0.0: Applications built with earlier versions of the pylon
C++ SDK are incompatible
NEW FEATURES / CHANGES
* General: [311182] Following Semantic Versioning 2.0, the pylon SDK library
names now only state the major version number and not the minor
version number anymore.
* pylon AI Agent: [286592] The pylon AI Agent is used to deploy models to AI
vTools. You can choose between deploying models via the pylon
AI Platform or from storage. Models can be deployed on local
or remote computers.
* vTools: [286272, 286412, 285715, 285681] The following vTools have been added:
- Object Detection
- Classification
- Semantic Segmentation
- Instance Segmentation
* pylon Viewer: [314565] Added pylon Event Logger as external tool in Tools
menu.
* pylon Viewer: [311582] The Automatic Image Adjustment feature is now available
on dart M cameras.
* pylon Viewer: [313572] Panes can now be closed via a context menu.
* pylon Viewer: [308989] Added AI topics to the New Features and Learn More
dialogs.
* pylon Viewer: [305588] The Line Profile can now be reset to its initial
position via the context menu of the image window.
* pylon Viewer: [297026] Added a context menu to the Line Profile pane.
* Workbench: [308021] The pin data view applies "Zoom to Fit" for the first
image displayed.
* Workbench: [308968] The "Zoom to Fit" feature in pin data views now scales
seamlessly.
* Workbench: [308991] On the Licensing tab of the Welcome dialog, added links
for AI vTools. In the Workbench menu, an entry for the pylon AI
agent has been added.
* CXP IC: [298766] Added BoardStatus section with features providing information
about the board status.
* CXP IC: [298766] Added Errors section with features providing information
about errors.
* CXP IC: [298766] Added CameraStatus event to provide information about missing
frames lost in transmission to the frame grabber.
* CXP IC: [298766] Renamed CorrectedErrorCount to CameraCorrectedErrorCount.
* CXP IC: [298766] Renamed UncorrectedErrorCount to CameraUncorrectedErrorCount.
* CXP IC: [306774] Solved communication issue to Opto-Coupled Trigger 5 boards.
* CXP IC: [220218] Fixed incorrect values in status operators which caused
issues with CXP status and port status.
* CXP IC: [303278] CustomSignalEvent0 and CustomSignalEvent1 now allow using
FrontGPI2 and FrontGPI3 as source.
* Data Processing: [289432] Improved performance by optimizing the internal
handling of data types.
* Data Processing: [274754] CRegion::GetBuffer() behavior has been changed to
implement copy-on-write.
* Data Processing: [300937] Added sample demonstrating how to receive chunks and
events from the Camera vTool.
* pylon C SDK: [298881] There is now a separate CMake finder (pylonC) for the
pylon C interface. pylon C content has been removed from the
existing pylon CMake finder.
* pylon C++ SDK: [296692] Added sample demonstrating the use of the shading
correction feature of racer 2 line scan cameras.
* pylon C++ SDK: [314002] The CBaslerUniversalInstantCamera class has been
updated.
* pylon C++ SDK: [303027] The GrabResult object now has an additional member,
and CPylonDataComponent was extended to support multipart data
components.
* pylon C++ SDK: [298881] pylon C content has been removed from the pylon CMake
finder. There is now a separate CMake finder for pylon C.
* pylon C++ SDK: [309601] pylon now supports Linux Ubuntu 24.04.
* pylon C++ SDK: [304030] Added new log4cpp logappender to support the new
Basler logging system ELT.
* pylon C++ SDK: [303896,303897] Improved logging to support the pylon Event
Logger, especially with regard to GenTL and CXP.
* vTools: [307646] Added more calibration plate sizes: 800 mm, 1200 mm, 1600 mm,
and 2400 mm
* vTools: [309025] Added the option to save absolute paths to image source
folders in the Image Loading vTool.
* vTools: [285172] In the Camera vTool, output pins can be added to output
camera chunk data.
* vTools: [285171] In the Camera vTool, output pins can be added to output
camera event data.
* vTools: [275698] The Image Loading vTool now supports using relative paths to
image source folders in recipes.
CORRECTIONS
* pylon Viewer: [285047] When the Color Calibrator fails to successfully
complete the second step, the Continuous Shot check box remains
checked.
* pylon Viewer: [312899] Fixed Histogram panning when using color images.
* pylon Viewer: [312817] Fixed alignment of the Y axis label in the Line Profile
pane.
* pylon Viewer: [308356] Increased the wait time to rediscover a camera after
performing a firmware update.
* pylon Viewer: [290732] Improved error message when exceeding limits using
Static Defect Pixel Correction.
* pylon Viewer: [307521] Line scan cameras will now use the correct acquisition
mode when using the single shot feature.
* pylon Viewer: [304190] Fixed an issue which caused overlapping of the text and
buttons in the title of image window tabs.
* Workbench: [291903] Fixed an issue which caused input pins of vTools being
added falsely as data source of pin data views.
* Workbench: [312967] Fixed an issue which caused an error when loading recipes
without vTools.
* Workbench: [311609] Fixed an issue that may have been causing the pylon Viewer
to crash when closing it while there is a Camera vTool with
allocated
* Workbench: [299047] Fixed some display issues regarding the pin data view,
including the RGB info and the full-screen mode after a recipe has
been stopped.
* Workbench: [307585] Fixed an issue that could cause the text in the pin data
view to be displayed incorrectly.
* Data Processing: [312880] Fixed an issue that prevented the renaming of input
and output terminal pins when the names of pins that were
created later started with the name of the first pin.
* Data Processing: [309051] Changed nested namespace definition in
GenericOutputObserver.h to match other header files.
* GigE: [314339] Fix for out of encoded data error when using Compression
Beyond.
* pylon C++ SDK: [307534] Fixed filehandle leak on GigE device open / close.
* vTools: [314717, 314714, 314713, 314707, 314716, 314724, 314710, 314709]
Updated error handling for vTools that use Transformation Data.
* vTools: [314724] Get help in the vTools-documentation for OCR-vTool opens the
correct documentation-page.
* vTools: [305245] In the Calibration Basic/Pro vTools, the graphical display of
the image coordinates is correct if the operating system's screen-
scaling feature is enabled.
* vTools: [303977] Fixed dialog text for rotation angle in the Template Matching
Basic vTool.
* vTools: [311250] Removed obsolete node map entry and updated vTool
documentation for the Document Cropper vTool.
* vTools: [301657] Improved support for manual machine calibration in the
Calibration Basic and Pro vTools.
* vTools: [305510] Updated dialog appearance of the Template Matching Basic
vTool.
* vTools: [306903] In the Gray value Transformer Starter vTool, parameter names
have been updated.
RESTRICTIONS
* pylon Viewer: A new image throttle has been implemented in the pylon Viewer to
improve overall stability and performance. This introduces a new
restriction which affects the video recording feature of the
pylon Viewer. Allowing only 250 images per second and camera in
the imaging pipeline limits the ability to record every frame
when exceeding this limit.
* pylon Viewer: The Color Calibrator does not support all Basler color cameras.
cameras are not supported.
* pylon Viewer: Under certain circumstances, e.g., a very slow or busy computer,
the Color Calibrator may not work if the camera has already been
opened in the pylon Viewer. To prevent this, close the camera
before using the Color Calibrator.
* pylon Viewer: To use the pylon Viewer, you must install the latest Mesa OpenGL
driver for your system. On Debian-based platforms, you also need
to install the following packages: libgl1-mesa-dri, libgl1-mesa-
glx, libxcb-xinerama0, and libxcb-xinput0
* pylon Viewer: Under circumstances, the pylon Viewer may experience issues when
using the Wayland display server protocol. It is recommended to
use Xorg instead.
* pylon Viewer: On Ubuntu 22.04 (or higher), the offline Basler Product
Documentation (BPD) may not be accessible when using Firefox due
to permission restrictions. To work around this issue, you can
set the environment variable TMPDIR to a location in the user's
home directory, use a different browser, or install Firefox from
a different source than snap
* Workbench: Using multiple pin data views actively displaying data in the
Workbench may cause
an increase of the CPU load and degradation of the overall
performance. Basler
recommends using fewer pin data views whenever possible.
* Workbench: The Statistics feature of the Workbench measures the execution
times of vTools.
The times measured in the Statistics feature may vary depending on
the configuration of your
system and the overall CPU load. This is so, because CPUs may run
with different frequencies
depending on the current load (e.g., due to dynamic frequency
scaling).
* Workbench: In case of display errors or missing symbols in the Workbench,
check and update
your graphics card driver or install the OpenGL software emulation
softpipe/llvmpipe.
* CXP IC: For line scan applets, ranges of line period and line exposure aren't
handled properly. The maximum values may be lower than expected.
* CXP IC: Starting with version 24.04, Ubuntu no longer provides libtiff.so.5.
This results in the following error when loading applets: "Unable to
load module library". As a workaround, you can create a symlink to
libtiff.so.6 in "/usr/lib/x86_64-linux-gnu" with the command "sudo ln
-s libtiff.so.6 libtiff.so.5".
* pylon C SDK: The pylon C API doesn't provide convenient functions to use GenDC
* pylon C SDK: For using the GenTL Consumer (e.g., with CoaXPress), additional
functionality was added to pylon C to be able to start and stop
streaming explicitly. This functionality has not been documented
in the pylon C programmer's guide yet. Please refer to the pylon
C++ programmer's guide (see chapter "Migrating from Previous
Versions - Changes in the IStreamGrabber API") or the pylonC
OverlappedGrab programming sample.
* pylon C++ SDK: Some ace 2 cameras may use a Boolean parameter instead of the
usual enumeration for event notifications. The following code
snippets can be used to work around this issue. For C++ you can
use: CBooleanParameter(camera.GetNodeMap(),
"EventNotification").TrySetValue(true); in addition to:
* GigE: In case the error message "Failed to allocate resources." has been
reported, Basler recommends using the pylon GigE Configurator tool to
optimize the IP configuration of NICs and cameras.
* GigE: Multiple IP configurations on a single network interface are not fully
supported by the IP Configurator tool.
* GigE: Assigning a static IP address to a camera that is not in the same subnet
as the network adapter may make the camera unreachable. To prevent this,
set the rp_filter (reverse path filter) to 2 ("loose mode") on the
camera's network interface. For more information, see the Assigning an
IP Address to a Camera topic in the Basler Product Documentation.
* GigE: For optimum use of Basler's ace 2 5GigE and 1GigE cameras, Basler
recommends using dual-channel DDR4-3600 RAM or better. Using slower RAM
may cause buffer underruns and image loss. In addition, Basler
recommends using the pylon GigE Configurator tool to optimize the
complete setup.
* GenTL: Limited GenTL support for producers with GenTL version 1.4 and below.
* MP4: MP4 video recording requires the pylon Supplementary Package for MPEG-4
to be installed in order to work. The pylon Supplementary Package for
MPEG-4 is available for download on the Basler website.
may fail, if the Quality parameter is set to 80 % or more. As a
workaround, set the Quality parameter to a lower value.
* MP4: The Recording feature doesn't support the Compression Beyond feature in
ace 2 Pro cameras. When recording is started and the Compression Beyond
feature is enabled, the pylon Viewer first disables the Compression Beyond
* 3D: Using Basler blaze 3D cameras requires the pylon Supplementary Package for
blaze to be installed. The pylon Supplementary Package for blaze is
* pylon AI Agent: With certain resolutions and scaling settings, buttons may not
be visible. |
