查看: 908|回复: 0
[驱动] 宝视纳Basler-pylon 8.0.0相机软件套装Linux x86(64位)- Debian安装软件包~pylon-8.0.0-linux-x86_64_debs.tar.gz
    4 小时前
  • 签到天数: 3724 天
    连续签到: 51 天
     楼主| 发表于 2024-11-30 11:58:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    pylon 8.0.0
    2024年9月
    8.0.0
    文件名: pylon-8.0.0-linux-x86_64_debs.tar.gz
    文件大小: 527364651 字节 (502.93 MB)
    修改日期: 2024-11-06 18:34
    MD5: cb033232c0e014f732602e7e86fdf618
    SHA1: 445a1a4a33f16f7f3e3179bea1f720dd29c20187
    SHA256: 7deee37e5d7b3e8f627c603d5cc0c6046bab9109e953901513c60f270c22bea4
    CRC32: b68b53fb
    Basler官方下载:
    链接:https://pan.baidu.com/s/1Iw4pv8UhlMUIkF8A0K-9bw
    pylon 8 Software Suite for Linux
    RELEASE NOTES
    Note: Patch versions of pylon for Linux OS are not released publicly.
    RELEASE DATE:    2024-09-24
    VERSION:         8.0.0 (x86_64, aarch64)
    BINARY COMPATIBILITY
    * Data Processing = 3.0.1: Applications built with 3.0.x or earlier 3.x.x
                               versions of the Data Processing are compatible.
    * pylon C SDK = 9.0.0: Applications built with earlier versions of the pylon C
                           SDK are incompatible
    * pylon C++ SDK = 9.0.0: Applications built with earlier versions of the pylon
                             C++ SDK are incompatible
    NEW FEATURES / CHANGES
    * General: [311182] Following Semantic Versioning 2.0, the pylon SDK library
               names now only state the major version number and not the minor
               version number anymore.
    * pylon AI Agent: [286592] The pylon AI Agent is used to deploy models to AI
                      vTools. You can choose between deploying models via the pylon
                      AI Platform or from storage. Models can be deployed on local
                      or remote computers.
    * vTools: [286272, 286412, 285715, 285681] The following vTools have been added:
               - Object Detection
               - Classification
               - Semantic Segmentation
               - Instance Segmentation
    * pylon Viewer: [314565] Added pylon Event Logger as external tool in Tools
                    menu.
    * pylon Viewer: [311582] The Automatic Image Adjustment feature is now available
                    on dart M cameras.
    * pylon Viewer: [313572] Panes can now be closed via a context menu.
    * pylon Viewer: [308989] Added AI topics to the New Features and Learn More
                    dialogs.
    * pylon Viewer: [305588] The Line Profile can now be reset to its initial
                    position via the context menu of the image window.
    * pylon Viewer: [297026] Added a context menu to the Line Profile pane.
    * Workbench: [308021] The pin data view applies "Zoom to Fit" for the first
                 image displayed.
    * Workbench: [308968] The "Zoom to Fit" feature in pin data views now scales
                 seamlessly.
    * Workbench: [308991] On the Licensing tab of the Welcome dialog, added links
                 for AI vTools. In the Workbench menu, an entry for the pylon AI
                 agent has been added.
    * CXP IC: [298766] Added BoardStatus section with features providing information
              about the board status.
    * CXP IC: [298766] Added Errors section with features providing information
              about errors.
    * CXP IC: [298766] Added CameraStatus event to provide information about missing
              frames lost in transmission to the frame grabber.
    * CXP IC: [298766] Renamed CorrectedErrorCount to CameraCorrectedErrorCount.
    * CXP IC: [298766] Renamed UncorrectedErrorCount to CameraUncorrectedErrorCount.
    * CXP IC: [306774] Solved communication issue to Opto-Coupled Trigger 5 boards.
    * CXP IC: [220218] Fixed incorrect values in status operators which caused
              issues with CXP status and port status.
    * CXP IC: [303278] CustomSignalEvent0 and CustomSignalEvent1 now allow using
              FrontGPI2 and FrontGPI3 as source.
    * Data Processing: [289432] Improved performance by optimizing the internal
                       handling of data types.
    * Data Processing: [274754] CRegion::GetBuffer() behavior has been changed to
                       implement copy-on-write.
    * Data Processing: [300937] Added sample demonstrating how to receive chunks and
                       events from the Camera vTool.
    * pylon C SDK: [298881] There is now a separate CMake finder (pylonC) for the
                   pylon C interface. pylon C content has been removed from the
                   existing pylon CMake finder.
    * pylon C++ SDK: [296692] Added sample demonstrating the use of the shading
                     correction feature of racer 2 line scan cameras.
    * pylon C++ SDK: [314002] The CBaslerUniversalInstantCamera class has been
                     updated.
    * pylon C++ SDK: [303027] The GrabResult object now has an additional member,
                     and CPylonDataComponent was extended to support multipart data
                     components.
    * pylon C++ SDK: [298881] pylon C content has been removed from the pylon CMake
                     finder. There is now a separate CMake finder for pylon C.
    * pylon C++ SDK: [309601] pylon now supports Linux Ubuntu 24.04.
    * pylon C++ SDK: [304030] Added new log4cpp logappender to support the new
                     Basler logging system ELT.
    * pylon C++ SDK: [303896,303897] Improved logging to support the pylon Event
                     Logger, especially with regard to GenTL and CXP.
    * vTools: [307646] Added more calibration plate sizes: 800 mm, 1200 mm, 1600 mm,
              and 2400 mm
    * vTools: [309025] Added the option to save absolute paths to image source
              folders in the Image Loading vTool.
    * vTools: [285172] In the Camera vTool, output pins can be added to output
              camera chunk data.
    * vTools: [285171] In the Camera vTool, output pins can be added to output
              camera event data.
    * vTools: [275698] The Image Loading vTool now supports using relative paths to
              image source folders in recipes.
    CORRECTIONS
    * pylon Viewer: [285047] When the Color Calibrator fails to successfully
                    complete the second step, the Continuous Shot check box remains
                    checked.
    * pylon Viewer: [312899] Fixed Histogram panning when using color images.
    * pylon Viewer: [312817] Fixed alignment of the Y axis label in the Line Profile
                    pane.
    * pylon Viewer: [308356] Increased the wait time to rediscover a camera after
                    performing a firmware update.
    * pylon Viewer: [290732] Improved error message when exceeding limits using
                    Static Defect Pixel Correction.
    * pylon Viewer: [307521] Line scan cameras will now use the correct acquisition
                    mode when using the single shot feature.
    * pylon Viewer: [304190] Fixed an issue which caused overlapping of the text and
                    buttons in the title of image window tabs.
    * Workbench: [291903] Fixed an issue which caused input pins of vTools being
                 added falsely as data source of pin data views.
    * Workbench: [312967] Fixed an issue which caused an error when loading recipes
                 without vTools.
    * Workbench: [311609] Fixed an issue that may have been causing the pylon Viewer
                 to crash when closing it while there is a Camera vTool with
                 allocated
    * Workbench: [299047] Fixed some display issues regarding the pin data view,
                 including the RGB info and the full-screen mode after a recipe has
                 been stopped.
    * Workbench: [307585] Fixed an issue that could cause the text in the pin data
                 view to be displayed incorrectly.
    * Data Processing: [312880] Fixed an issue that prevented the renaming of input
                       and output terminal pins when the names of pins that were
                       created later started with the name of the first pin.
    * Data Processing: [309051] Changed nested namespace definition in
                       GenericOutputObserver.h to match other header files.
    * GigE: [314339] Fix for out of encoded data error when using Compression
            Beyond.
    * pylon C++ SDK: [307534] Fixed filehandle leak on GigE device open / close.
    * vTools: [314717, 314714, 314713, 314707, 314716, 314724, 314710, 314709]
              Updated error handling for vTools that use Transformation Data.
    * vTools: [314724] Get help in the vTools-documentation for OCR-vTool opens the
              correct documentation-page.
    * vTools: [305245] In the Calibration Basic/Pro vTools, the graphical display of
              the image coordinates is correct if the operating system's screen-
              scaling feature is enabled.
    * vTools: [303977] Fixed dialog text for rotation angle in the Template Matching
              Basic vTool.
    * vTools: [311250] Removed obsolete node map entry and updated vTool
              documentation for the Document Cropper vTool.
    * vTools: [301657] Improved support for manual machine calibration in the
              Calibration Basic and Pro vTools.
    * vTools: [305510] Updated dialog appearance of the Template Matching Basic
              vTool.
    * vTools: [306903] In the Gray value Transformer Starter vTool, parameter names
              have been updated.
    RESTRICTIONS
    * pylon Viewer: A new image throttle has been implemented in the pylon Viewer to
                    improve overall stability and performance. This introduces a new
                    restriction which affects the video recording feature of the
                    pylon Viewer. Allowing only 250 images per second and camera in
                    the imaging pipeline limits the ability to record every frame
                    when exceeding this limit.
    * pylon Viewer: The Color Calibrator does not support all Basler color cameras.
                    cameras are not supported.
    * pylon Viewer: Under certain circumstances, e.g., a very slow or busy computer,
                    the Color Calibrator may not work if the camera has already been
                    opened in the pylon Viewer. To prevent this, close the camera
                    before using the Color Calibrator.
    * pylon Viewer: To use the pylon Viewer, you must install the latest Mesa OpenGL
                    driver for your system. On Debian-based platforms, you also need
                    to install the following packages: libgl1-mesa-dri, libgl1-mesa-
                    glx, libxcb-xinerama0, and libxcb-xinput0
    * pylon Viewer: Under circumstances, the pylon Viewer may experience issues when
                    using the Wayland display server protocol. It is recommended to
                    use Xorg instead.
    * pylon Viewer: On Ubuntu 22.04 (or higher), the offline Basler Product
                    Documentation (BPD) may not be accessible when using Firefox due
                    to permission restrictions. To work around this issue, you can
                    set the environment variable TMPDIR to a location in the user's
                    home directory, use a different browser, or install Firefox from
                    a different source than snap
    * Workbench: Using multiple pin data views actively displaying data in the
                 Workbench may cause
                 an increase of the CPU load and degradation of the overall
                 performance. Basler
                 recommends using fewer pin data views whenever possible.
    * Workbench: The Statistics feature of the Workbench measures the execution
                 times of vTools.
                 The times measured in the Statistics feature may vary depending on
                 the configuration of your
                 system and the overall CPU load. This is so, because CPUs may run
                 with different frequencies
                 depending on the current load (e.g., due to dynamic frequency
                 scaling).
    * Workbench: In case of display errors or missing symbols in the Workbench,
                 check and update
                 your graphics card driver or install the OpenGL software emulation
                 softpipe/llvmpipe.
    * CXP IC: For line scan applets, ranges of line period and line exposure aren't
              handled properly. The maximum values may be lower than expected.
    * CXP IC: Starting with version 24.04, Ubuntu no longer provides libtiff.so.5.
              This results in the following error when loading applets: "Unable to
              load module library". As a workaround, you can create a symlink to
              libtiff.so.6 in "/usr/lib/x86_64-linux-gnu" with the command "sudo ln
              -s libtiff.so.6 libtiff.so.5".
    * pylon C SDK: The pylon C API doesn't provide convenient functions to use GenDC
    * pylon C SDK: For using the GenTL Consumer (e.g., with CoaXPress), additional
                   functionality was added to pylon C to be able to start and stop
                   streaming explicitly. This functionality has not been documented
                   in the pylon C programmer's guide yet. Please refer to the pylon
                   C++ programmer's guide (see chapter "Migrating from Previous
                   Versions - Changes in the IStreamGrabber API") or the pylonC
                   OverlappedGrab programming sample.
    * pylon C++ SDK: Some ace 2 cameras may use a Boolean parameter instead of the
                     usual enumeration for event notifications. The following code
                     snippets can be used to work around this issue. For C++ you can
                     use: CBooleanParameter(camera.GetNodeMap(),
                     "EventNotification").TrySetValue(true); in addition to:
    * GigE: In case the error message "Failed to allocate resources." has been
            reported, Basler recommends using the pylon GigE Configurator tool to
            optimize the IP configuration of NICs and cameras.
    * GigE: Multiple IP configurations on a single network interface are not fully
            supported by the IP Configurator tool.
    * GigE: Assigning a static IP address to a camera that is not in the same subnet
            as the network adapter may make the camera unreachable. To prevent this,
            set the rp_filter (reverse path filter) to 2 ("loose mode") on the
            camera's network interface. For more information, see the Assigning an
            IP Address to a Camera topic in the Basler Product Documentation.
    * GigE: For optimum use of Basler's ace 2 5GigE and 1GigE cameras, Basler
            recommends using dual-channel DDR4-3600 RAM or better. Using slower RAM
            may cause buffer underruns and image loss. In addition, Basler
            recommends using the pylon GigE Configurator tool to optimize the
            complete setup.
    * GenTL: Limited GenTL support for producers with GenTL version 1.4 and below.
    * MP4: MP4 video recording requires the pylon Supplementary Package for MPEG-4
           to be installed in order to work. The pylon Supplementary Package for
           MPEG-4 is available for download on the Basler website.
           may fail, if the Quality parameter is set to 80 % or more. As a
           workaround, set the Quality parameter to a lower value.
    * MP4: The Recording feature doesn't support the Compression Beyond feature in
           ace 2 Pro cameras. When recording is started and the Compression Beyond
           feature is enabled, the pylon Viewer first disables the Compression Beyond
    * 3D: Using Basler blaze 3D cameras requires the pylon Supplementary Package for
          blaze to be installed. The pylon Supplementary Package for blaze is
    * pylon AI Agent: With certain resolutions and scaling settings, buttons may not
                      be visible.
    GMT+8, 2025-11-26 12:50
