查看: 1058|回复: 0
[驱动] 宝视纳Basler-Basler blaze固件4.6.2~blaze-firmware-4.6.2.zip
    4 小时前
  • 签到天数: 3724 天
    连续签到: 51 天
     楼主| 发表于 2024-11-30 16:19:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Basler blaze Firmware 4.6.2
    2023年3月
    4.6.2
    Basler blaze ToF相机的固件版本中包括blaze固件更新包、固件更新工具指南以及安装说明。
    此固件版本支持HDR功能。
    在更新固件时,Basler建议也同时更新主机软件。如需详细了解固件和主机软件之间的依赖性关系,请参阅固件版本说明。
    文件名: blaze-firmware-4.6.2.zip
    文件大小: 129653958 字节 (123.65 MB)
    修改日期: 2023-04-04 21:00
    MD5: 82ce1a0538e4c4268390db845fc51444
    SHA1: bda79756ef7ea50e5b9ce84565956aee2066579c
    SHA256: 3aad05e60d4ed05d2e126ada47b4e3206e2374324e26aaa4f32344fdb16f5b2d
    CRC32: 3e5d5bc2
    链接:https://pan.baidu.com/s/1v2QA1tvQtCMoeJfZlS5kdg
    RELEASE NOTES
    Note: Firmware versions not listed in this document are not released publicly.
          They are created for internal purposes only and don’t contain any changes
          that would affect the behavior of the camera. On occasion, cameras with
          such a firmware version may be shipped to customers. Updating cameras to a
          higher version than the latest publicly available firmware is not required
          since such an update would not change camera functionality or add new
          features.
    Version:           4.6.2
    Release date:      2022-10-24
    Preceding release: 4.3.1
    Products affected: blaze-101 (order number 107796), hardware revisions 09..16
                       blaze-102 (order number 108711), hardware revisions 01..03
    NEW FEATURES
    * Added the Extrinsic Transformation feature that allows you to transform the
      position and orientation of the camera coordinate system.
      See https://docs.baslerweb.com/extrinsic-transformation for more details.
    * Improved the Outlier Removal feature by adding the OutlierRemovalTolerance
      parameter.
      See https://docs.baslerweb.com/outlier-removal for more details.
    * Added support for Basler pylon's firewall traversal functionality.
    * Provided more options for controlling the device network bandwidth
      consumption. The following camera parameters have been added:
        - DeviceLinkThroughputLimitMode
        - BslResultingAcquisitionFrameRate
        - BslDeviceLinkCurrentThroughput
        - GevSCBWR (Bandwidth Reserve)
        - GevSCBWRA (Bandwidth Reserve Accumulation)
    * Added support for Extended IDs as defined by the GigE Vision Streaming
      Protocol. Requires pylon 7.2 or above. If Extended IDs are enabled, the
      frame counter reported by pylon's grab result objects doesn't wrap around
      from 65535 to 1 anymore. Packet resend error handling is more efficient when
      Extended IDs are enabled.
      To enable Extended IDs, set the GevGVSPExtendedIDMode parameter to "On".
    CHANGES
    * Optimized depth calculation leads to reduced latency (timespan from trigger
      to data received by host). The typical latency is less than 85 ms. This can be
      reduced further by enabling the Fast Mode feature and/or disabling time-hungry
      camera features like the temporal filter.
    * Improved GigE Vision standard compatibility. The latest GigE Vision standard
      version 2.2 is supported.
    * Improved error handling when invalid camera parameters are set.
    * 100 MBit connections are detected, and the frame rate is automatically
      limited when a 100 MBit link instead of a 1 GBit connection is established.
    * Reduced number and length of streaming data network packet bursts to
      decrease the likelihood of network packets getting dropped by the receiving
      host.
    * Reduced bandwidth consumption when intensity images and confidence
      images are disabled.
    * Fixed bug: When the network connection was lost, camera settings were
      reset.
    * Fixed bug: Toggling the PtpEnable parameter caused grab failures.
    * Fixed bug: Fast toggling of the HDRMode parameter could cause the firmware to
      restart.
    * Fixed bug: Cancelling image acquisition in synchronous free run was not possible
      if the synchronous free run start time was set to a time in the future.
    * Improved third-party software support.
    * Further bug fixes and stability improvements.
    COMPATIBILITY INFORMATION
    *WARNING:* Because of bugs in pylon 7.1 and pylon 7.2, avoid using the blaze
    camera with pylon 7.1. or pylon 7.2. Using pylon 7.0 or below is recommended.
    When using pylon 7.1, image acquisition may stop unexpectedly. When using
    pylon 7.2, image acquisition may be unstable.
    *WARNING:* Once updated, the firmware can't be downgraded to a firmware
    version below 4.2.
    *WARNING:* To update the camera's firmware to firmware version 4.0 or above,
    the camera's current firmware version has to be at least 2.3.0.
    If the current firmware version is below 2.3.0, you first have to update
    the camera to firmware version 3.0.1. Afterwards, you can perform an update
    with the latest camera firmware version. Contact Basler support to get an
    update package for firmware version 3.0.1.
    *Note:* To use new features introduced by this firmware version,
    you have to update to pylon Supplementary Package for blaze 1.3.0
    or above or to Basler blaze SDK 4.3 or above.
    The latest Basler software for blaze cameras can be downloaded here:
    http://www.baslerweb.com/blaze-software
    *Note:* Applications built using the Basler blaze SDK 3.0.0 or above or the
    pylon Supplementary Package for blaze 1.0.0 or above can't access cameras with
    firmware versions below 3.0.0. These cameras have to be updated to firmware
    3.0.0 or above when you migrate to the pylon Supplementary Package for blaze
    1.0.0 or above or to Basler blaze SDK 3.0.0 or above.
    Mixing 2.x cameras with 3.x cameras in the same application is not possible.
    Firmware update packages and update instructions can be downloaded here:
    GMT+8, 2025-11-26 12:49
