查看: 992|回复: 0
[驱动] 宝视纳Basler-Basler blaze固件5.0.0~blaze-firmware-5.0.0.zip
    4 小时前
  • 签到天数: 3724 天
    连续签到: 51 天
     楼主| 发表于 2024-11-30 16:23:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Basler blaze Firmware 5.0.0
    2023年9月
    5.0.0
    Basler blaze ToF相机的固件版本中包括blaze固件更新包、固件更新工具指南以及安装说明。
    此固件版本支持HDR功能。
    在更新固件时,Basler建议也同时更新主机软件。如需详细了解固件和主机软件之间的依赖性关系,请参阅固件版本说明。
    Basler blaze固件5.0.0
    文件名: blaze-firmware-5.0.0.zip
    文件大小: 130590098 字节 (124.54 MB)
    修改日期: 2024-03-12 23:25
    MD5: bb345c0528a664637d59c818be0080f2
    SHA1: 392946e7ba73fe502bf9a53897079a4af9676520
    SHA256: 913397ec1bfb06bc8f11ecf789bef59d090418156921df4bcea086a2a9470360
    CRC32: 1e39f7fc
    Basler官方下载:
    链接:https://pan.baidu.com/s/1FLVpoJ246B6LcPCchCbAYw
    RELEASE NOTES
    Note: Firmware versions not listed in this document are not released publicly.
          They are created for internal purposes only and don’t contain any changes
          that would affect the behavior of the camera. On occasion, cameras with
          such a firmware version may be shipped to customers. Updating cameras to a
          higher version than the latest publicly available firmware is not required
          since such an update would not change camera functionality or add new
          features.
    Version:           5.0.0
    Release date:      2023-09-30
    Preceding release: 4.6.2
    Products affected: blaze-101 (order number 107796), hardware revisions 09 to 17
                       blaze-102 (order number 108711), hardware revisions 01 to 04
    NEW FEATURES
    *Note:* To use new features introduced by this firmware version,
    you have to update to pylon Supplementary Package for blaze 1.5.0
    or above or to Basler blaze SDK 4.5 or above.
    * Added the region of interest (ROI) feature. This allows you to specify the
      Width, Height, OffsetX, and OffsetY parameters as required.
    * Added the Binning feature. The following parameters allow you to enable and
      control the binning of pixels:
        - BinningHorizontalMode
        - BinningHorizontal
        - BinningVerticalMode
        - BinningVertical
    * Added the BslCenterX and BslCenterY parameters to automatically center the ROI
      horizontally and vertically.
    * Added the DeviceLinkHeartbeatTimeout parameter allowing you to control the
      length of the timeout used by the camera and the host application to detect a
      network connection loss.
    * Added the MinimumWorkingRange parameter, which allows you to shift the
      camera's working range. The working range can only be shifted when the Fast Mode
      feature is enabled and the Operating Mode is set to 'ShortRange'.
    * Added the Image Inpainting filter that fills in gaps by using the depth data
      calculated from neighboring pixels. Image Inpainting is enabled by default.
      If you want the Image Inpainting feature to be disabled by default, set the
      LegacyImagePainting parameter to 'true'. You only have to enable the legacy
      behavior once since the setting is stored permanently in the camera's flash
      memory.
    * Added the Illumination Position Correction feature that allows you to correct
      measurement errors caused by the offset between illumination and sensor. The
      feature is enabled by default. If you want the Illumination Position
      Correction feature to be disabled by default, set the
      LegacyIlluminationPositionCorrection parameter to 'true'. You only have to
      enable the legacy behavior once since the setting is stored permanently in the
      camera's flash memory.
    * Added the Multi-Part Streaming Mode feature. If the MultiPartStreaming
      parameter is set to 'On', the camera uses the GigE Vision multi-part
      format for streaming data. Multi-Part Streaming Mode is disabled by
      default.
      Note: This feature is only available when using 3rd-party software that
      accesses the camera directly as a GigE Vision device. When using the pylon
      Supplementary package for blaze or the blaze SDK, the feature is not
      available.
    * Added the Trigger Activation feature allowing you to control on which edges
      of an input signal a frame trigger is issued.
    * Added the Acquisition Status feature allowing you to check whether the camera
      is currently capturing a frame and whether it is currently waiting for the
      next frame trigger.
    * Added 'FrameTriggerWait' as additional source for the digital output.
    * Improved IoT security. Numerous measures have been taken for protection
      against attacks via the network and against firmware manipulation.
    * Added the WebServerEnable parameter, which can be used to disable the web
      server on the camera that is required for firmware updates and accessing
      diagnostic information.
    * Added the Legacy Behavior Control feature. The following parameters allow you
      to change the default behavior of the camera with respect to firmware versions
      below 5.0. Adjustments to these parameters are permanently stored in the
        - LegacyIntensityScaling
        - LegacyImageInpainting
        - LegacyIlluminationPositionCorrection
    * Added the 'IlluminationCalibration' error code to the list of error codes the
      Last Error feature can report.
    * Added the PtpClockID, PtpParentClockID, and PtpGrandmasterClockID parameters.
    * Added the StartupTime2 parameter allowing you to read out the length of the
      time gap inserted after every 4th image sub-frame.
    CHANGES
    * Reduced the execution time of the AcquistionStart command.
    * Reduced the delay between receiving a software or hardware trigger and
      starting exposure.
    * Further optimizations of depth calculation lead to reduced latency (timespan
      from trigger to data received by host).
    * Improved compatibility with the Aravis open source software. Aravis failed to
      open a stream when Aravis' access check policy was enabled.
    * The time needed for establishing a connection to the camera is slightly
      reduced by providing a compressed camera description XML file.
    * Fixed an issue causing streaming data throughput to be limited in case the
      link speed temporarily dropped from 1 GBit/s to 100 MBit/s.
    * Improved conformity with the GenICam Standard Feature Naming Convention (SFNC).
      The camera's feature set now complies with SFNC 2.7.
    * Reduced execution time of the PtpDataSetLatch command.
    * Improved management of bandwidth consumption in case of a high rate of network
      package drops.
    * Fixed an issue causing bright areas to be saturated too early by applying
      a reduced scaling factor to the intensity data. This change makes
      intensity images appear slightly darker compared to images taken with
      firmware versions below 5.0. If your software depends on the brighter images,
      you can set the LegacyIntensityScaling parameter to 'true' to apply the same
      intensity scaling value as in firmware versions below 5.0. You only have to
      the camera's flash memory.
    * Fixed an issue causing the frame rate to drop when issuing PtpDataSetLatch
      commands while the camera is streaming.
    * Fixed occasional camera crashes when accessing digital I/O-related parameters.
    * Fixed an issue causing some digital I/O-related parameters not being updated
      properly.
    * Fixed an issue caused by over-triggering the camera which prevented streaming
      from being restarted until a ClearLastError command was issued.
    * Fixed a rare issue causing the streaming to be stopped unexpectedly.
    COMPATIBILITY INFORMATION
    *WARNING:* Because of bugs in pylon 7.1 and pylon 7.2, avoid using the blaze
    camera with pylon 7.1. or pylon 7.2. Using the latest pylon version or using
    pylon 7.0 or below is recommended.
    When using pylon 7.1, image acquisition may stop unexpectedly. When using
    pylon 7.2, image acquisition may be unstable.
    *WARNING:* Once updated, the firmware can't be downgraded to a firmware
    version below 4.2.
    *WARNING:* To update the camera's firmware to firmware version 4.0 or above,
    the camera's current firmware version has to be at least 2.3.0.
    If the current firmware version is below 2.3.0, you first have to update
    the camera to firmware version 3.0.1. Afterwards, you can perform an update
    with the latest camera firmware version. Contact Basler support to get an
    update package for firmware version 3.0.1.
    The latest Basler software for blaze cameras can be downloaded here:
    http://www.baslerweb.com/blaze-software
    *Note:* Applications built using the Basler blaze SDK 3.0.0 or above or the
    pylon Supplementary Package for blaze 1.0.0 or above can't access cameras with
    firmware versions below 3.0.0. These cameras have to be updated to firmware
    3.0.0 or above when you migrate to the pylon Supplementary Package for blaze
    1.0.0 or above or to Basler blaze SDK 3.0.0 or above.
    Mixing 2.x cameras with 3.x cameras in the same application is not possible.
    Firmware update packages and update instructions can be downloaded here:
    GMT+8, 2025-11-26 12:50
