TA的每日心情 | 怒 昨天 08:37 |
签到天数: 3764 天 连续签到: 15 天 [LV.Master]2000FPS
楼主 |
发表于 2024-11-30 16:28:36
来自:广东省东莞市 电信
宝视纳Basler-Basler blaze固件6.0.0~blaze-firmware-6.0.0.zip
Basler blaze Firmware 6.0.0
2024年1月
6.0.0
Basler blaze ToF相机的固件版本中包括blaze固件更新包、固件更新工具指南以及安装说明。
此固件版本支持HDR功能。
在更新固件时,Basler建议也同时更新主机软件。如需详细了解固件和主机软件之间的依赖性关系,请参阅固件版本说明。
Basler blaze固件6.0.0
文件名: blaze-firmware-6.0.0.zip
文件大小: 131253809 字节 (125.17 MB)
修改日期: 2024-10-24 18:29
MD5: 138fc21dac092c61f9159eff2d656b06
SHA1: 9659d20f87e99b84cbfae4203ba6275289408089
SHA256: 732c46fb7e2515661f6a0b2cdc7e944e8be5324887cac728d64dedf6d6f1dca7
CRC32: 101f9821
Basler官方下载:
链接:https://pan.baidu.com/s/1lDa5FW3-kBAazP_eTQWN5g
RELEASE NOTES
Note: Firmware versions not listed in this document are not released publicly.
They are created for internal purposes only and don’t contain any changes
that would affect the behavior of the camera. On occasion, cameras with
such a firmware version may be shipped to customers. Updating cameras to a
higher version than the latest publicly available firmware is not required
since such an update would not change camera functionality or add new
features.
Version: 6.0.0
Release date: 2024-09-10
Preceding release: 5.1.0
Products affected: blaze-101 (order number 107796), hardware revisions 09 to 20
blaze-102 (order number 108711), hardware revisions 01 to 07
blaze-112 (order number 109245), hardware revisions 01 to 03
NEW FEATURES
* Added the ComponentIDValue parameter. This is a unique identifier that
indicates the type of the component selected by the ComponentSelector
parameter.
* Added the Scan3dProjectionModel parameter that describes the mapping
function used for distortion correction.
* Added the Trigger Thermal Drift Stabilization feature. If the trigger mode with
thermal drift stabilization is enabled, the camera continuously acquires
images in the background at a constant frame rate (fps) and sends the next
available image when triggered. This reduces the thermal offset error and
improves the absolute accuracy.
CHANGES
* Fixed the ZOffsetOriginToCameraFront parameter. It now describes the distance
between the front of the housing and the optical center of the camera.
* Fixed a bug that sometimes caused FrameTriggerWait not to be set to true
when executing AcquisitionStart.
* Fixed a bug that caused the upper limit to be adjusted incorrectly when
using the shiftable working range and the entire measuring range couldn't
be used.
COMPATIBILITY INFORMATION
*WARNING:* Because of bugs in pylon 7.1 and pylon 7.2, avoid using the blaze
camera with pylon 7.1. or pylon 7.2. Using the latest pylon version or using
pylon 7.0 or below is recommended.
When using pylon 7.1, image acquisition may stop unexpectedly. When using
pylon 7.2, image acquisition may be unstable.
*WARNING:* Once updated, the firmware can't be downgraded to a firmware
version below 4.2.
*WARNING:* To update the camera's firmware to firmware version 4.0 or above,
the camera's current firmware version has to be at least 2.3.0.
If the current firmware version is below 2.3.0, you first have to update
the camera to firmware version 3.0.1. Afterwards, you can perform an update
with the latest camera firmware version. Contact Basler support to get an
update package for firmware version 3.0.1.
The latest Basler software for blaze cameras can be downloaded here:
http://www.baslerweb.com/blaze-software |
