查看: 919|回复: 1
[驱动] 宝视纳Basler-blaze pylon补充软件包1.6.0 - Windows版~pylon_Supplementary_Package_for_blaze_1.6.0.exe
    昨天 08:37
  • 签到天数: 3764 天
    连续签到: 15 天
     楼主| 发表于 2024-11-30 16:52:17 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    pylon Supplementary Package for ToF Camera / blaze 1.6.0
    2023年9月
    1.6.0
    Compatible with: pylon 6.2.0, 6.3.0, 7.0.0, 7.2.1, 7.3.0, 7.4.0
    在此处下载blaze pylon补充软件包,轻松设置和配置Basler blaze 3D相机。这个软件包包含blaze Viewer,以作为配置和可视化工具。
    安装要求
    blaze pylon补充软件包需要安装pylon相机软件套装6.2.0或更高版本。
    文件名: pylon_Supplementary_Package_for_blaze_1.6.0.exe
    文件大小: 64627928 字节 (61.63 MB)
    修改日期: 2024-10-24 17:54
    版本: 1.6.0.0
    MD5: 0f9718cd07e8acb8b20f1d70f77f66f7
    SHA1: 7bb4191740099fe1eacd28dec9c75e39e6a06658
    SHA256: 0d074d1ba4579e69738b106536f5a2f44be05c873c834afbfb1b119a8dee213f
    CRC32: 98522511
    Basler官方下载:
    链接:https://pan.baidu.com/s/1iWDuVaOCoHLOmyzA5A2sBw
    RELEASE NOTES
    pylon Supplementary Package for blaze
    Version:           1.6.0
    Release date:      2024-05-03
    Preceding release: 1.5.0
    Products affected: blaze-101 (order number 107796), revisions 03 or above
                       blaze-102 (order number 108711)
    NEW FEATURES
    * Improved handling of the GigE Vision heartbeat timeout. In case an application
      has been started under the control of a debugger, the connection to the camera
      is closed automatically when the application is terminated or crashes. This
      allows you to use the GigE camera again immediately after restarting the
      application. pylon 7.1 or above is required for the improved heartbeat timeout
      becoming effective.
    CHANGES
    * Updated OpenCV and Point Cloud Library installation topics in the blaze
      C++ Programmer's Guide.
    * Fixed an issue causing the producer to not acquire images when the Extended ID
      feature is enabled (under Windows with pylon GigE Vision Performance Driver).
      Note that the pylon GigE Vision Performance Driver has been discontinued.
      You should use the pylon GigE Vision Filter Driver instead.
    * Fixed an issue causing the blaze Viewer to crash when the content of the
      feature tree search box was deleted.
    * Fixed an issue causing the frame ID to only go up to 65535 when the Extended ID
      feature was enabled and then to overflow (under Windows with pylon GigE Vision
      Filter Driver).
    * Fixed an issue where the Gamma Correction feature didn't work properly when
      using camera firmware version 4.x.
    * Fixed the return type of GetBufferPartInfo BUFFER_PART_INFO_DATA_TYPE
      from int to size_t.
    * Added the AutoPacketSize and UseExtendedIdWhenSupported parameters. Usage of
      GigE Vision Extended IDs is enabled by default.
    KNOWN LIMITATIONS
    Windows, pylon versions below pylon 7.2.1:
    - Basler generally recommends using pylon 7.3 or above with blaze cameras.
    Linux:
    - Programming samples using the Point Cloud Library (PCL) may crash depending
      on the versions of the PCL and VTK libraries installed on your system. The
      crash is due to a bug in the VTK libraries that are used by PCL for 3D
      visualization.
      Source: https://github.com/PointCloudLibrary/pcl/issues/5237
      For example, Ubuntu 22.04 ships versions of the libraries showing the problem.
      Solution: PCL 1.13.1 and above contain fixes to work around the VTK bug.
      Uninstall the PCL libraries provided by your Linux distribution and build PCL
      version 1.13.1 or above from sources (these are available on
      https://github.com/PointCloudLibrary/pcl).
    发表于 2025-4-12 21:51:49 | 显示全部楼层 来自:江苏省苏州市常熟市 东方染整厂
    GMT+8, 2026-1-7 06:20
