查看: 1347|回复: 0
[驱动] 宝视纳Basler-blaze pylon补充软件包1.7.1 - Windows版~pylon_Supplementary_Package_for_blaze_1.7.1.exe
    昨天 08:37
  • 签到天数: 3764 天
    连续签到: 15 天
     楼主| 发表于 2024-11-30 17:05:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    pylon Supplementary Package for ToF Camera / blaze 1.6.0
    2023年9月
    1.6.0
    Compatible with: pylon 6.2.0, 6.3.0, 7.0.0, 7.2.1, 7.3.0, 7.4.0
    在此处下载blaze pylon补充软件包,轻松设置和配置Basler blaze 3D相机。这个软件包包含blaze Viewer,以作为配置和可视化工具。
    安装要求
    blaze pylon补充软件包需要安装pylon相机软件套装6.2.0或更高版本。
    文件名: pylon_Supplementary_Package_for_blaze_1.7.1.exe
    文件大小: 66039680 字节 (62.98 MB)
    修改日期: 2024-10-24 18:26
    版本: 1.7.1.0
    MD5: f4f22005811d499dc22eab0cc21129e6
    SHA1: 27a0d89a6c1c52357681bfe9338a12e8d9d2bae1
    SHA256: e1a812c33ac6efeeabb4f76f456650906fbdc84ae7c15fe103d3f3e243898113
    CRC32: 03b40f1b
    Basler官方下载:
    链接:https://pan.baidu.com/s/1fPIb0CL_OhIj_zftW6IHRg
    RELEASE NOTES
    pylon Supplementary Package for blaze
    Version:           1.7.1
    Release date:      2024-09-27
    Preceding release: 1.7.0
    Products affected: blaze-101 (order number 107796), revisions 03 or above
                       blaze-102 (order number 108711)
                       blaze-112 (order number 109245)
    CHANGES
    * Added support for the Basler pylon Camera Software Suite version 8.0.
    KNOWN LIMITATIONS
    Windows, pylon versions below pylon 7.2.1:
    - Basler generally recommends using pylon 7.3 or above with blaze cameras.
    Linux:
    - Programming samples using the Point Cloud Library (PCL) may crash depending
      on the versions of the PCL and VTK libraries installed on your system. The
      crash is due to a bug in the VTK libraries that are used by PCL for 3D
      visualization.
      Source: https://github.com/PointCloudLibrary/pcl/issues/5237
      For example, Ubuntu 22.04 ships versions of the libraries showing the problem.
      Solution: PCL 1.13.1 and above contain fixes to work around the VTK bug.
      Uninstall the PCL libraries provided by your Linux distribution and build PCL
      version 1.13.1 or above from sources (these are available on
      https://github.com/PointCloudLibrary/pcl).
    GMT+8, 2026-1-7 06:21
