查看: 793|回复: 0
[驱动] 宝视纳Basler-blaze pylon补充软件包 1.7.1 - Linux x86_64~pylon-supplementary-package-for-blaze-1.7.1.8261b56b5_x86_64_setup.tar.gz
    昨天 08:37
  • 签到天数: 3764 天
    连续签到: 15 天
     楼主| 发表于 2024-11-30 17:07:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    pylon Supplementary Package for ToF Camera / blaze 1.7.1
    2024年9月
    1.7.1
    Compatible with: pylon 6.2.0, 6.3.0, 7.0.0, 7.2.1, 7.3.0, 7.4.0, 7.5.0, 8.0.0
    在此处下载blaze pylon补充软件包,轻松设置和配置Basler blaze 3D相机。这个软件包包含blaze Viewer,以作为配置和可视化工具。
    安装要求
    blaze pylon补充软件包需要安装pylon相机软件套装6.2.0或更高版本。
    文件名: pylon-supplementary-package-for-blaze-1.7.1.8261b56b5_x86_64_setup.tar.gz
    文件大小: 81939489 字节 (78.14 MB)
    修改日期: 2024-10-24 18:27
    MD5: e99cfa0d6e375f67fbcbe768505870c3
    SHA1: 196f8965bc4e0682dd451528081d20767aa281f2
    SHA256: 1fd8094916904ab97386da61d6529d37a44223b2ff2386853df634df9545e4c7
    CRC32: 897ca13e
    Basler官方下载:
    链接:https://pan.baidu.com/s/10tyje-ZvCvrmQTQIi5se6A
    RELEASE NOTES
    pylon Supplementary Package for blaze
    Version:           1.7.1
    Release date:      2024-09-27
    Preceding release: 1.7.0
    Products affected: blaze-101 (order number 107796), revisions 03 or above
                       blaze-102 (order number 108711)
                       blaze-112 (order number 109245)
    CHANGES
    * Added support for the Basler pylon Camera Software Suite version 8.0.
    KNOWN LIMITATIONS
    Windows, pylon versions below pylon 7.2.1:
    - Basler generally recommends using pylon 7.3 or above with blaze cameras.
    Linux:
    - Programming samples using the Point Cloud Library (PCL) may crash depending
      on the versions of the PCL and VTK libraries installed on your system. The
      crash is due to a bug in the VTK libraries that are used by PCL for 3D
      visualization.
      Source: https://github.com/PointCloudLibrary/pcl/issues/5237
      For example, Ubuntu 22.04 ships versions of the libraries showing the problem.
      Solution: PCL 1.13.1 and above contain fixes to work around the VTK bug.
      Uninstall the PCL libraries provided by your Linux distribution and build PCL
      version 1.13.1 or above from sources (these are available on
      https://github.com/PointCloudLibrary/pcl).
    GMT+8, 2026-1-7 06:20
