查看: 1168|回复: 0
[驱动] 宝视纳Basler-blaze pylon补充软件包 1.7.1 - Linux x86_64 - Debian安装软件包~pylon-supplementary-package-for-blaze-1.7.1.8261b56b5_amd64.deb
    昨天 08:37
  • 签到天数: 3764 天
    连续签到: 15 天
     楼主| 发表于 2024-11-30 17:09:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    pylon Supplementary Package for ToF Camera / blaze 1.7.1
    2024年9月
    1.7.1
    Compatible with: pylon 6.2.0, 6.3.0, 7.0.0, 7.2.1, 7.3.0, 7.4.0, 7.5.0, 8.0.0
    在此处下载blaze pylon补充软件包,轻松设置和配置Basler blaze 3D相机。这个软件包包含blaze Viewer,以作为配置和可视化工具。
    安装要求
    blaze pylon补充软件包需要安装pylon相机软件套装6.2.0或更高版本。
    blaze pylon补充软件包1.7.1 - Linux x86_64 - Debian安装软件包
    文件名: pylon-supplementary-package-for-blaze-1.7.1.8261b56b5_amd64.deb
    文件大小: 83919994 字节 (80.03 MB)
    修改日期: 2024-10-24 18:26
    MD5: 9ea44a6a2ea04641eb1c9b2659466479
    SHA1: d6bba3f781a3931c78191448790216f8ce4f5a03
    SHA256: d2fa740c06368e1b9cf8521a1b185e95026d271f86752c72cba65a680f17aa03
    CRC32: df2d2e49
    Basler官方下载:
    链接:https://pan.baidu.com/s/1L2rgp3hfBtY2D6rnRKXltg
    RELEASE NOTES
    pylon Supplementary Package for blaze
    Version:           1.7.1
    Release date:      2024-09-27
    Preceding release: 1.7.0
    Products affected: blaze-101 (order number 107796), revisions 03 or above
                       blaze-102 (order number 108711)
                       blaze-112 (order number 109245)
    CHANGES
    * Added support for the Basler pylon Camera Software Suite version 8.0.
    KNOWN LIMITATIONS
    Windows, pylon versions below pylon 7.2.1:
    - Basler generally recommends using pylon 7.3 or above with blaze cameras.
    Linux:
    - Programming samples using the Point Cloud Library (PCL) may crash depending
      on the versions of the PCL and VTK libraries installed on your system. The
      crash is due to a bug in the VTK libraries that are used by PCL for 3D
      visualization.
      Source: https://github.com/PointCloudLibrary/pcl/issues/5237
      For example, Ubuntu 22.04 ships versions of the libraries showing the problem.
      Solution: PCL 1.13.1 and above contain fixes to work around the VTK bug.
      Uninstall the PCL libraries provided by your Linux distribution and build PCL
      version 1.13.1 or above from sources (these are available on
      https://github.com/PointCloudLibrary/pcl).
    GMT+8, 2026-1-7 06:20
