查看: 927|回复: 0
[NI驱动程序] NI-FGEN 2025 Q1 Win11 32/64bitEng/Jpn NI-FGEN波形发生器仪器驱动程序25.0.0
     楼主| 发表于 2025-4-2 10:37:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-FGEN
    NI-FGEN为使用NI波形发生器产品的客户提供支持。
    NI-FGEN 2025 Q1
    发布日期:2025/1/23
    包含的版本:2025 Q1完整版,版本号25.0.0
    语言:英文English/日语Japanese
    文件大小: 3608625152 字节 (3.36 GB)
    修改日期: 2025-03-13 10:52
    MD5: d819a92ce1fc6b816a8ddb0bceb14cd9
    SHA1: 6e54c9f28511dde36fcec425669e5deef7b09de7
    SHA256: 12b2aaa26ba9fd173b36c260701a34d6404cc60e09d7e263a573be60cd88aeac
    CRC32: be67c663
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    FGEN2025Q1.txt (510 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q1版本未更新自述文件,参考2023Q3
    NI-FGEN 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-FGEN 2023 Q3.
    • NI-FGEN Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-FGEN Documentation: New features, behavior changes, and other documentation
    NI-FGEN is an NI instrument driver that enables you to implement frequency sweeping and hopping, waveform linking and looping, and frequency shift keying (FSK) modulation for complex measurement solutions. NI-FGEN is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the waveform or signal generator and includes an interactive soft front panel and examples.
    NI-FGEN 2023 Q3 has the following requirements:
    • Processor—1 GHz or faster 64-bit (x64) processor
    • RAM—2 GB RAM (64-bit)
    NI-FGEN 2023 Q3 supports the following operating systems:
    • NI Linux® Real-Time
    Note  NI-FGEN no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    NI-FGEN 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-FGEN 2023 Q3
    LabVIEW2020 and later
    LabVIEW Real-Time Module with NI Linux® Real-Time2020 and later
    LabWindows™/CVI™ Real-Time Module2019 and later
    If you are using the NI-FGEN .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-FGEN 2023 Q3 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Python Support
    For more information on installing and using Python, refer to the nifgen module.
    Download the NI-FGEN installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    NI Script Editor is no longer installed with NI-FGEN.
    The "NI-FGEN Support for LabVIEW" package supports applications using NI-FGEN ​with LabVIEW 2022 or later. When installing NI-FGEN, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    LVAddons directory location:
    • Windows C:\Program Files\NI\LVAddons
    • Linux /usr/local/natinst/share/lvaddons
    NI-FGEN no longer installs IVI Compliance Package (ICP). NI-FGEN supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    Onboard Signal Processing
    NI-FGEN driver when used with NI Linux® Real-Time will not support Onboard Signal Processing. This feature remains supported on Windows.
    Upgrading Firmware
    The PXIe-5442, PXIe-5450, and PXIe-5451 have upgradeable device firmware. It is highly encouraged and may be required that you upgrade the firmware on these devices; newer firmware contains new features and important bug fixes. To update the firmware, run the Firmware Updater application for your device (54xxFirmwareUpdater_X.Y.Z.exe, where 54xx is the name of the device and X.Y.Z is the firmware version) that is installed in the Program Files (x86)\National Instruments\NI-FGEN\ directory. This application upgrades your firmware to the latest available version that works with this driver. After the application runs, you are required to power down your computer and PXI Express chassis to complete the firmware update.
    • The NI-FGEN Soft Front Panel has been replaced by InstrumentStudio, which is automatically installed when you install the NI-FGEN driver. You can access InstrumentStudio in one of the following ways:
      • From the Windows start menu, select National Instruments»InstrumentStudio [year]. This launches InstrumentStudio and runs a soft front panel populated with devices detected on your system.
    Note   The deprecated NI-FGEN Soft Front Panel remains available for download. Visit Legacy Soft Front Panels for NI-FGEN for more information.
    Refer to the NI Signal Generators Help, accessible from Start»All Programs»National Instruments»NI-FGEN»NI-FGEN Documentation, for information about NI-FGEN.
    You can access all the installed NI-FGEN examples for LabVIEW, LabWindows/CVI, C, and .NET at Start»All Programs»National Instruments»NI-FGEN»NI-FGEN Examples and online at ni.com/examples. Examples also are available online that demonstrate integrating NI waveform generators with NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-FGEN are located in the LabVIEW XXXX\examples\instr\niFgen directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Search tab to search all installed examples by keyword. For example, search for "FGEN" to locate all waveform generator examples.
    NI-FGEN no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-8 08:02
