查看: 743|回复: 0
[NI驱动程序] NI-Industrial Controller Device Drivers 2025 Q1 Win11 32/64bitEng NI工业控制器设备驱动程序25.0.0
     楼主| 发表于 2025-4-7 17:20:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI工业控制器设备驱动程序软件为客户使用NI工业控制器提供支持。
    NI工业控制器设备驱动程序是用于配置和编程工业控制器的驱动程序软件。该软件还可用于控制工业控制器的数字I/O。除了LabVIEW、LabVIEW Real-Time模块或NI自动化检测视觉生成器之外,您还必须安装此驱动程序才能开始编程工业控制器。
    发布日期:2025/1/23
    包含的版本:2025 Q1完整版,版本号25.0.0
    文件大小: 1789372416 字节 (1.67 GB)
    修改日期: 2025-03-12 18:01
    MD5: 9cad276b9fe78ffc97c9889daddf1887
    SHA1: 8d2dc079411eded81eaa3c05545679c50f1d9a8b
    SHA256: 8dca038085e4a88b4df73a7870238a0bc81d48ed6b336e075dcbce22d62db90f
    CRC32: b55f80c5
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    Industrial Controller Device Drivers2025Q1.txt (595 Bytes, 下载次数: 0, 售价: 10 圆)
    Industrial Controller Device Drivers 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for Industrial Controller Device Drivers 2023 Q1.
    • Industrial Controller Device Drivers Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • Industrial Controller Device Drivers Documentation: New features, behavior changes, and other documentation
    Application and Driver Software Support
    Industrial Controller Device Drivers allows you to configure Industrial Controller devices and control their digital I/O. This release supports the following hardware:
    • IC-3120
    • IC-3121
    • IC-3171
    • IC-3172
    • IC-3173
    Refer to the Industrial Controller website at ni.com/industrial-controller for the latest information about Industrial Controller Device Drivers.
    Industrial Controller Device Drivers 2023 Q1 has the following requirements:
    • Pentium 4 1 GHz or equivalent
    • 512 MB RAM
    • 1,024 × 768 resolution video adapter with a 16-bit display
    Industrial Controller Device Drivers 2023 Q1 supports the following operating systems:
    Note  Industrial Controller Device Drivers no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    Industrial Controller Device Drivers 2023 Q1 supports the following application software versions, including service packs.
    NI Application Software or Driver Software
    Versions Supported by Industrial Controller Device Drivers
    NI LabVIEW
    2020 and later
    NI LabVIEW Real-Time Module
    2020 and later
    NI LabVIEW Real-Time 64-Bit Module
    2021 64-bit and later
    NI LabVIEW FPGA Module
    2020 and later
    NI LabVIEW FPGA 64-Bit Module
    Vision Development Module
    2015 SP1 and later
    Vision Acquisition Software
    February 2016 and later
    NI Vision Builder for Automated Inspection
    IC-3120, 3121, and 3173—2015 or later
    IC-3171 and 3172—2015 f1 or later
    Download the Industrial Controller Device Drivers installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    • Added support for LabVIEW 2023 Q1 and later
    Documentation is installed onto your hard drive with Industrial Controller Device Drivers. To view the documentation, select Start»National Instruments»Industrial Controller Documentation.
    Refer to the NI Product Documentation Center at ni.com/docs for the most recent versions of product documentation.
    • Refer to the National Instruments Web site for information about the IEEE 1588 time synchronization capabilities of the Industrial Controllers.
    • IC-3120 Getting Started Guide, IC-3120 Specifications, and IC-3120 User Manual—These documents explain how to install and configure the IC-3120, and contain specifications and electrical and mechanical information.
    • IC-3121 Getting Started Guide, IC-3121 Specifications, and IC-3121 User Manual—These documents explain how to install and configure the IC-3121, and contain specifications and electrical and mechanical information.
    • IC-317x Getting Started Guide, IC-3171 Specifications, IC-3172 Specifications, IC-3173 Specifications, and IC-317x User Manual—These documents explain how to install and configure the IC-317x, and contain specifications and electrical and mechanical information.
    • Vision RIO VI Reference Help—This document contains reference information about NI Vision RIO VIs. Vision RIO VIs provide basic tools to configure input and output on FPGA-enabled devices to synchronize image acquisition with process control.
    Industrial Controller Device Drivers no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2016–2023 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-12-8 08:02
