查看: 1309|回复: 0
[LV工具模块] LabVIEW 2025 Q1 FPGA IP Export Utility Win11 64bitENG LV2025Q1 FPGA IP导出工具包IPEU25.1.0-64位
    昨天 16:03
     楼主| 发表于 2025-4-8 11:36:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW FPGA IP Export Utility可用于导出LabVIEW FPGA算法,以便在第三方硬件上进行部署。
    LabVIEW FPGA IP Export Utility是一个软件附件,可帮助您使用LabVIEW FPGA在NI FPGA硬件上对实时算法进行快速原型设计。然后,您可以将经过验证的设计导出为VHDL源代码或网表,以在第三方硬件上使用。使用LabVIEW FPGA IP Export Utility需要先安装LabVIEW FPGA模块。
    LabVIEW 2025 Q1 FPGA IP导出工具IPEU25.1.0
    发布日期:2025/1/23
    包含的版本:2025Q1完整版,版本号25.1.0
    文件大小: 723871744 字节 (690.34 MB)
    修改日期: 2025-03-03 15:56
    MD5: a1081c51e64798c93661e1f757eb08b9
    SHA1: 77320fbe9249443fb53929594e9d1ba0dacfdb8a
    SHA256: bbaca271ba4bb8101e7d6eceb3411799940b5e2ca9b91cd1457015d7e8ac7ef4
    CRC32: 5583a50f
    FPGA IP导出工具2025Q1x64.txt (628 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q1版自述文件未更新,参考2021版
    LabVIEW 2021 FPGA IP Export Utility Readme
    July 2021
    This file contains installation instructions and compatibility information for the LabVIEW FPGA IP Export Utility.
    • LabVIEW FPGA IP Export Utility Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • LabVIEW FPGA IP Export Utility Manuals: New features, behavior changes, and other documentation
    Activation Notice
    The LabVIEW FPGA IP Export Utility allows you to export your FPGA algorithm developed in LabVIEW FPGA as FPGA IP (Intellectual Property). You can then integrate the IP in your Vivado project and use the IP on any Xilinx Vivado FPGA device of the same family. The LabVIEW FPGA IP Export Utility provides the following editions:
    • LabVIEW FPGA Netlist Export Utility—Exports an FPGA algorithm as an encrypted netlist.
    • LabVIEW FPGA VHDL Export Utility—Exports an FPGA algorithm as an encrypted netlist or plaintext VHDL.
    The LabVIEW 2021 FPGA IP Export Utility has the following requirements:
    • LabVIEW 2021 Full or Professional Development Systems (32-bit or 64-bit)
    • LabVIEW 2021 FPGA Module (32-bit or 64-bit)
    • LabVIEW 2021 FPGA Compilation Tool for Vivado 2019.1
    Refer to the LabVIEW Readme, LabVIEW FPGA Module Readme, and Xilinx Compilation Tools Readme for additional system requirements and supported operating systems.
    The LabVIEW 2021 FPGA IP Export Utility supports the following operating systems:
    Download the LabVIEW FPGA IP Export Utility installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Activation Notice
    The LabVIEW FPGA IP Export Utility provides two purchase options: LabVIEW FPGA Netlist Export Utility and LabVIEW FPGA VHDL Export Utility. Depending on your purchase option, activate the LabVIEW FPGA IP Export Utility in the following ways:
    • LabVIEW FPGA Netlist Export Utility—Allows you to export your FPGA algorithm developed in LabVIEW FPGA to FPGA IP as an encrypted netlist. Activate or evaluate the LabVIEW FPGA IP Export Utility using NI License Manager.
    • LabVIEW FPGA VHDL Export Utility—Allows you to export your FPGA algorithm developed in LabVIEW FPGA to FPGA IP as an encrypted netlist or plaintext VHDL. Activate or evaluate the LabVIEW FPGA IP Export Utility using NI License Manager.
    Refer to the Getting Started with the LabVIEW FPGA IP Export Utility for information about using the LabVIEW FPGA IP Export Utility. Access this manual by navigating to the labview\manuals\LabVIEW FPGA IP Export Utility directory and opening FPGA_IP_Export_Getting_Started.pdf
    <;Product Name> no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    © 2021 National Instruments Corporation. All rights reserved.
    378241B-01
    GMT+8, 2026-2-24 23:25
