查看: 792|回复: 0
[NI驱动程序] NI-RDMA 2025 Q1 Win11 32/64bitEng NI远程直接内存访问25.0.0
    21 分钟前
  • 签到天数: 3774 天
    连续签到: 25 天
     楼主| 发表于 2025-4-15 09:44:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RDMA
    NI-RDMA支持远程直接内存访问(RDMA)可兼容的网络接口控制器。
    NI-RDMA是一种驱动软件,它为两个或多个使用RDMA技术的系统在以太网上交换数据提供支持。此外,NI-RDMA提取出了对RDMA可兼容接口进行编程的低级细节,并为传输数据提供了简单而高效的API。
    NI-RDMA 2025 Q1
    发布日期:2025/1/23
    包含的版本:2025 Q1完整版,版本号25.0.0
    文件大小: 1578592256 字节 (1.47 GB)
    修改日期: 2025-03-02 17:52
    MD5: 1e21f4eae35d6d7b43a0cf2434c1ad06
    SHA1: cb119cf8dc146fe4579f6d152cea68179451e326
    SHA256: 46ae6392e996397be37107b0209973b0aab0ddd12889d5ed958ed3173c964836
    CRC32: 330d5504
    请注册登录机器视觉论坛账号,购买附件查看下载地址下载地址
    RDMA2025Q1.txt (510 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q1版未更新自述文件,参考2023Q3版
    NI-RDMA 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-RDMA 2023 Q3.
    • NI-RDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RDMA Documentation: New features, behavior changes, and other documentation
    NI-RDMA 2023 Q3 supports the following operating systems:
    NI-RDMA 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RDMA 2023 Q3
    LabVIEW2020, 2020 SP1, 2021, 2021 SP1, 2022 Q3, 2023 Q1
    LabVIEW Real-Time (RT)2021 and later
    If you are using the NI-RDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RDMA 2023 Q3 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the NI-RDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    The "NI-RDMA Support for LabVIEW" package supports applications using NI-RDMA ​with LabVIEW 2022 or later. When installing NI-RDMA, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    Not Available
    NI-RDMA no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-1-16 11:51
